Question about NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive
External hard drive enclosure
I have a nexxtech external hard drive enclosure that i put a maxtor 20 gig hard drive into,but everytime i power up the external srive it reboots my system and continues to reboot in a loop until i turn the power off.
i have tried placing the jumper in all of the settings it doesnt change anything, is there something i am missing???
my system....
asrock mobo-pentium D 3ghz-2gigs dual channel pc3200-windows xp pro- 160 gig and 30gig internal drives- 500 watt power supply.
    Problem Solver:
  • 8 Answers
I too purchased a Nexxtech Hard Disk Enclosure and my Vista-based computer keeps telling me to try a USB 2.0 setup...the USB's ARE 2.0...did you try the setup disk that came with your unit?...I tried on mine but still a no go...I may have to return it to Best Buy & try somrthing different.
Posted on Jul 21, 2008
  • JoeRoscoe Jul 23, 2008
    A follow up to the previous post...I set the jumper on the enclosed HD to "master" and everything is working fine now.
My pc and laptop not detect my Maxtor OneTouch III Mini External 100GB USB 2.0 Hard Drive R01E100 what can i do please help me soon as possible
Good Day Anantsharma8!
If your PC and Laptop can not detect your external hard drive, I do suggest you check its usb cable. A substitute cable will confirm if your current usb cable is faulty or has an open wire.
Most common reason why the external hard drive is not recognize by PC or Laptop is due to loose connection of the hard disk inside the connectors of the enclosure.
Anantsharma8, if you have a small precision screw, I recommend you open the enclosure of the external hard drive. Remove the front face where usb and power plug connects, then slide it out to expose the hard disk also. You will see two connectors. These are the ones that always loosen. Please disconnect both the connectors and then connect it again properly. Put the hard disk back, close the enclosure and try to connect again with your PC or laptop via usb cable.
Good Luck! I hope that it will soon recognize your external hard drive.
Jun 10, 2011 | Maxtor OneTouch III Mini Edition R01E100...
Hi there we purchased a maxtor basics 500gb hard drive about 3 years ago. we have had children in that time and unfortunetly our two year old daughter dropped it. we have taken it to a service store but...
If it is the external hard drive enclosure that is broken then yes. But if it is the hard drive itself that is broken then no.
From what happened I'm thinking that it is the external hard drive enclosure that is broken. That being said, you can easily buy one without the hard drive online. When doing this be sure you know what kind of hard drive is in your Maxtor enclosure. This is important because you need to be sure that your hard drive and enclosure are compatible. Check to see if it uses SATA, ATA, or PATA connectors and then buy the corresponding external hard drive enclosure.
Once you have bought your new empty external hard drive enclosure, it is simply a matter of opening up your Maxtor enclosure and moving the hard drive inside to your newly purchased enclosure and connecting it to your computer.
To avoid problems like this in the future, look into "cloud based storage" to back up all of your data securely online.
Mar 29, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
I have pluged in the usb plug and plug the maxtor to the electrical plug but nothimg happens. How do I get it going?
Take a multi-meter, and test the voltage and amperage outputs from the power-supply, to confirm that the readings match the specifications on the label on the power-supply.
If the power-readings are correct, then when you connect the power to the external enclosure, you should either hear the disk-drive start to spin, or feel the vibrations as the disk-drive spins.
If you don't, then the disk-drive inside the enclosure has "died".
If the device is still under warranty, MAXTOR will replace the disk-drive, for minimal costs to you.
If the warranty has ended, then open the enclosure, remove the disk-drive, purchase a new, compatible, disk-drive, install it into the enclosure, and thus "revive" your external storage device.
Nov 04, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Hi My Maxtor External Hardrive is connected to my laptop the green light is on but its not recognised by the laptop.
Welcome to fixya,
The main caused of the problem is the enclosure of your Maxtor ext drive you need to change ot replace it to a new one. Take your hadridsk out of the enclosure and buy new enclosure and then put your hardisk back on to the new enclosure.
Aug 13, 2010 | Maxtor BASICS Personal Storage 3200...
Maxtor 3200
Seagate troubleshooting Error Code 10, states that drive has failed. (Seagate bought out Maxtor)
Before you resign yourself to everything is lost on this harddrive, how about trying one more thing?
How about putting the harddrive inside in a new external enclosure, and see if it works? I suggest that perhaps the external enclosure it's in, is bad.
The harddrive inside is a 3.5 inch harddrive. Same width as used by a desktop computer. It is a Sata harddrive.
Here's an example of a 3.5 inch Sata, external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3901268&CatId=2780
Just pop the external enclosure open that holds it now, take it out, and install it into an external enclosure like the example above. Plug in the USB cable.
Don't know if this applies to your particular Maxtor Personal Storage 3200, but when I went to search for the type of harddrive it uses just now, I ran into thsi, and thought I would pass it along. http://www.seagate.com/www/en-us/support/downloads/personal_storage/ps3200-sw)
May 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Can a external hard drive with a power supply issue be fixed?
the data on the drive should hopefully be safe as it sounds like it is the drive enclusure that has failed here (not the drive)
your data should be intact if the drive hasn't failed.
however to access the data is a different matter, as I am unsure how maxtor deal with this, to do it manually you would put the drive into a working enclosure or connect it to a functioning HDD adapter (for your drive type)
however to do this the drive would need to be removed from the enclosure (voiding the warranty)
hope this helps
Apr 14, 2009 | Maxtor OneTouch III 300 GB Hard Drive
My old Dell HD will not fit in HP w/vista
i see..well..was the old hard drive running xp by chance?..seems that with the new vista, that each application would need to be upgraded with drivers to pull the old data..another option is to use a data recovery service.
May 10, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Maxtor 500 gig internal diamondmax 21
external USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
May 04, 2008 | Maxtor Hard Drive
3.5 hard drive enclosure
Try a different USB cable. Try a different computer. If those don't solve it, it a defective enclosure. I seem to have a handful of defective ones myself. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | NexxTech Portable Hi-Speed USB 2.0 Kit...
NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive Logo
258 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Joe Goldman
Joe Goldman
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
