Question about NexxTech NSFTMD1
Installing modem I bought the modem because it dioesnt have one . I am not sure how to take the computer apart ( the shell) to put the modem in. Its a dell optiplex DX1.......Can you help.......Pam
  • 593 Answers
Most newer cases have a side panel that slides off, look in the back and there should be a screw or a latch that secures the side panel, remove and the panel will slide back about 1 inch and then off. Older ones have the entire top 3 sides formed as one piece and the 3 sided top comes off.
Posted on May 19, 2008
I bought it used and it shot well put 4 38sp wadcutters in it when i pulled lever back it locked up one shell fell out. can i tak it apart? what do i do?
Still this Marlin '92? It's not made to shoot wadcutters in. Try 158 gr. round nose. The overall length of the cartridge has to be long enough to give the shell stop time to work. You see what happens when it doesn't.
Mar 06, 2015 | Optics
I see that people are asking about driverss for the RCA dcm425 cable modem. I just bought a new computer, and I connected it to the my old dcm425 modem through a router and it works just fine. I didn't...
The trick about all this is that the software does not configure the computer, but the modem.
So once it has been configured through a computer then plugged to a router, any computer plugged to the said router will have access to the Internet.
The whole process of installing/configuring will happen if you replace the old modem and/or plug a new computer directly to the modem.
May 07, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I need to take apart my Brother XR-52 sewing maching to replace the spool pin. I have removed all the screws and cannot figure out how the case comes apart. Thank you.
XR-52 (and probably similar) has 9 screws on the back and bottom that needto be undone - be sure to keep track of which screw goes where becausethey're almost all different. One other screw is under the "nose" piece which holds the front shell to the back - it just needs to be loosened. After you haveremoved the 9 screws and loosened the one I mentioned you start at the bottom and pry apart carefully of course, noticing that the last part comes apart at the top where the three wheels go thru the back shell. In order to take off the front shell you need to remove two more screws, also fairly obvious. Reassembly is opposite order being sure when you get ready to put the back on that you align the three wheels at the top first, then work down to the bottom, replacing all the screws. That's really it - not rocked science. Just be sure not to over-tighten screws going into plastic. Have fun!
Feb 27, 2011 | Brother Sewing Machines
Modem will connect to router but not to computer
This is mostly because it has not adapted to the changes when using another device aside from the router, especially a router. What I have done with internet modems is when you are removing a router, or if you are installing a router is allow that modem to be shut down for about 10 - 20 minutes before you use other devices it does not recognize right away.
May 05, 2010 | Toshiba PCX2600 (c40054) Modem
Removing/installing door components from/to door shell
sorry i cant tell u how to exactly howto take the old door apart NICELY without just having a light touch and the experience of doing other doors, but i would like to ask where u got ur door shell, i need one badly myself to and have had no luck so far finding one. any knowlage u have would be awsome, thanks
Mar 24, 2009 | 2003 Toyota Corolla
Does a router or combo need to be connected to computer?
As you already have the modem you only need a router. In all cases the modem connects to the WAN port on the router.
I think your best bet surely would be to go for a wireless router though? Then you wouldnt have to trail ethernet cables all round the house. I'm sure your laptop has a wireless adaptor built in unless it;s very old.
I always use Netgear networking stuff so forgive me posting a link to a nice 54G wireless router :-) :
http://www.amazon.co.uk/Netgear-WGR614UK-Wireless-Cable-Router/dp/B0000C1WO2#moreAboutThisProduct
Dec 27, 2008 | Toshiba PCX 5000 Wireless Cable Modem...
Putting new shell on ds lite
There out are plenty of DS and DS lite dissasembling guides with photos and even videos. I had posted some in previous problems so try searching here, if cant find here just use google.
Dec 18, 2008 | Nintendo DS Lite Console
I bought my modem at my local walmart in August of 08. Now the modem cannot detect a dial tone. I have had it at two different houses to make sure that it's not my phone line and it is still the same. I...
you might need to contact a computer technician because if it has no dial tone means, your are not installing the modem correclty (if modem is good).
Oct 20, 2008 | Gateway Computers & Internet
Unable to put my modem in my computer
Give me more details on the modem , is it a internal modem or external.
Dec 29, 2007 | U.S. Robotics Modem: U.S.Robotics 56K V.92...
CAN'T GET AOL DIAL UP CONNECTION TO WORK
This error message normally happens because of a corrupted driver. Reinstall the driver for your modem.If you do not have cd's that came with your computer go too acer's website to download here
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=4309542&CFTOKEN=82834010
Now if that is not the cas maybe you are incorrectly installing aol. Start up your aol. If it specifies broadband at login box change to dialup or go to setup and let aol automactically detect your modem. If problem still persists. Reinstall software when prompted make sure you select dialup. Now if you are using broadband and asking for dialup. Or go to the control panel and remove your modem driver, shut down and restart. It should put the modem back.  Any more questions post comment.
Hope this helps you
Oct 25, 2007 | Acer Aspire 3680 Laptop
NexxTech NSFTMD1 Logo
77 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Joe Goldman
Joe Goldman
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
