Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
Can't seem to fax...
And can't seem to find the manual for this fax machine model, It has been working and now it's not...tried turning it off and unplugging it but that didn't help...
please e-mail me if you can the manual for it at my6pkpepsi2@yahoo.com
Thank you in advance
  • Anonymous May 21, 2008
    Will receive but can't seem to get it to fax How do you adjust it so that it will send faxes
  • 4jjjj Jun 03, 2008
    how to make a fax I have a brither 575
How do i set my fax machine to send and recieve faxes.which is the right setting for it.
Posted on Aug 01, 2008
Cant send or recieve fax
Might be silly question but is it setup to auto transmit and receive? And have you tried to operate it manually? + take out the inline filter fax machines operate on volume'db' to soft and it can't hear, to loud and it can distort sound.
Dec 28, 2013 | HP Office Equipment & Supplies
Fax thru Internet help
Magic Jack is lying to you. ALL fax machines are Analog devices, Magic Jack is Digital
Jun 21, 2010 | Muratec M1250 Fax
Using MagicJack with Network ''all in one'' Printer/Fax
MagicJack does not work with all fax machines. If you can find it you must turn off ECM or error correction mode. Also select the slowest transmission speed possible. If you have the manual for it you should be able to find the settings in there.
Oct 17, 2009 | Office Equipment & Supplies
Need instructions for fax features
Use the manual AR-F151 it seems to use the same functions as the AR-F152
I set up my fax machine using this manual, and all the instructions worked so far.
Good Luck,
Bob
Jan 05, 2009 | Sharp AR-F152 Fax
Fax problem
There doesn't seem to be a manual for the ux 178 listed but here is the site for the pdf formats of the similar models, try the ux 100 series
http://search.sharpusa.com/search/?sp_i=1&sp_q=ux+178&sp_a=sp10009e61&sp_k=&sp_n=21&sp_f=ISO-8859-1
hope this helps :)
Nov 07, 2008 | Sharp UX 510 Plain Paper Thermal transfer...
Fax machine
you did not mention the model.
Most faxes you have to put the documents face Down, and hit the Start button
Sep 16, 2008 | Lexmark Office Equipment & Supplies
Fax machine
1)Disconnect the power cord from the rear of the HP Fax machine.
2)Verify that the phone cable is fully inserted into the fax machine. If your model has a removable Line Interface Unit (LIU) where the phone line plugs into, verify that it is securely snapped in place.
3)If the HP Fax model belongs to the HP Officejet R80 Series , verify that the cable which goes from the Automatic Document Feeder assembly to the rear of the HP All-in-One base is connected.
4)Reconnect the power cord.After the fax reinitializes and it is ready, try to send and receive faxes again.
Sep 15, 2008 | Office Equipment & Supplies
FAX, MODEL 920 NOT RECEIVING
Try calling your fax machine from a cell phone. If the fax doesen't answer, or if the line is busy, the phone line may be bad. Also check that the phone line to the fax is plugged into the receptical marked LINE, not PHONE. The PHONE receptical is to connect a telephone to the fax machine. If it still does not answer, try going into the fax menu and go to RECEIVE settngs. Try changing each setting, then call the fax with the cell to see if it answers. Write down each setting before you change it, so you can set it back if changing it does not solve the problem.
Jul 10, 2008 | HP 920 Plain Paper Fax
Fax Machine freezing
TRY REPLACING SMPS (MAIN FILTER CAPACITOR) --IF NOT SOLVED THEN REPLACE THE MAIN PBA(MAIN BOARD), HAPPY FAXIONG OMNIPRESENT
Apr 13, 2007 | Samsung SF-330 Plain Paper Inkjet Fax
Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
52 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
