Windows XP using Wireless Intelimouse with KVM switch exhibits erratic behavior
I have a few computers setup using a KVM switch. Mouse will not work in XP. I have other computer Running windows 2000 and I have no issues I have to use 2 separate mouses. Makes for a cluttered desk.Your help would be greatly appreciated.
  • longlanky May 19, 2008
    The KVM is 4 port switch from Compaq. It is PS2 the mouse is Microsoft Wireless Intelimouse Explorer 2.0. I am using an adapter to go from USB to PS2 . The mouse is part of a wireless desktop. Microsoft Wireless Elite Desktop. Thanks
  • longlanky May 20, 2008
    The adapter is the problem. You can delete the driver for the mouse in XP and reboot. Once you reboot XP reinstalls driver. Mouse will work the way it should until next reboot. Thats the only way I have been able to get switch to work in XP. It does not work in Vista either. 2000 and 98 are fine.
  • 22 Answers
Hi
What type of mouse do you have plugged into the KVM ?? PS2 or USB and what type of KVM switch are you using.
Respond back and I will look into it for you.
/SPH
Posted on May 19, 2008
  • Shawn Hartman
    Shawn Hartman May 19, 2008
    Hi
    The adapter may be the culprit. Try to isolate the setup by removing the adapter USB to PS2 and then try a traditional PS2 mouse.
    After changing the layout to isolate reboot the computers and then switch to see if the mouse works on both.
    Let me know if you need more assistance.
    /SPH
USB Mouse works, keyboard does not
You will need to update the drivers on the computer for the docking station. It will be the windows seven drivers or lack of them that is causing a failure to remap the usb ports that the wireless dongle is plugged into.
May 25, 2017 | IOGear GCS632U 2-port KVM Switch
Wireless keyboard and mouse works fine with computer but when I attempt to use it on the f1dh104l switch it does not recognize the mouse or keyboard. it is a dell e6400 laptop that i'm attempting to...
the problem is that most Wireless Keyboard and Mice combos use Composite USB, the KVM however is expecting one signal on each entry port (one for mouse, and one for Keyboard).
replace yoru wireless Combo for a standard Keyboard and Mouse to make this work.
A work around would be using a MS Wireless Mouse and a different brand of Wireless Keyboard using both Wireless receivers and plug them into different ports on the KVM
Jun 05, 2011 | Computers & Internet
The mouse goes in the opposite direction from i where i'm trying to navigate it.
Check whether you have switched the Primary and Secondary buttons of the Mouse. Please click on Start>Control Panel>Hardware and Sound>Mouse. Then Uncheck the Primary and Secondary buttons of the Mouse to resolve the issue.
Mar 02, 2011 | Logitech Cordless Mouse
All Keys do not work on keyboard with KVM switch
GCS632U is designed to work with standard USB keyboard an mouse only. You have to make sure that you are not using any type of adapter such as PS/2 to USB adapter. To further isolate the problem, please follow the steps below:
1. Connect the USB keybord directly to th computer to make sure that the keyboard is working properly.
2. Make sure that the keyboard is connected to the keyboard port on your KVM switch. You may take a look under neath this GCS632U (near the USB ports) and you will see an icon where to connect the keyboar and mouse.
3. If you're still gettings the same problem, Try power cycling this kvm switch by disconnecting if from the computers and disconnect also the keyboard and mouse from the KVM switch and leave them disconnected for a minute or two.
4. Reconnect everything after two minutes and then reboot the two computers.
5. If same problem exist, try using different USB keyboard.
NOTE: This KVM swith does not work correctly with wireless, gaming and smart keyboards because it's designed to work with standrd USB keyboard only.
Mar 23, 2009 | IOGear GCS632U 2-port KVM Switch
4-port usb kvw switch #GCS634U
The GCS634U is designed and tested to work only with a standard USB keyboard and mouse. However, most wireless keyboards and mice work with it, but they cannot guarantee any specific model or brand that would work correctly.
As you can see, this KVM switch is a bus powered device (meaning it only gets power from the USB ports of the computers). If the computer cannot provide enough power for the KVM switch to function correctly, then the wireless keyboard will be affected.
You may try using the IOGEAR GKM541RA. It's tested to work with the GCS634U. Or you may also try using a self-powered USB hub (meaning, it has it's own power adapter) and connect it in between the KVM switch and the computer. That self-powered USB hub will be the one that will add up power to the KVM switch and help it to function properly.
Jan 12, 2009 | IOGear GCS634U KVM Switch
Belkin 2-Port KVM Switch
It is compatible with a wireless mouse, as long as it is a PS2 mouse.  if it is USB you could try using a converter, but it may not work.
Nov 04, 2008 | D-Link AirPlus G DWL-G122 802.11g/b...
Mouse and keyboard not recognized on second computer
Solution for the mouse. I have 8 KVM's. Most of my computers work with the KVMs. On 1 inland KVM the logitect and Microsoft optical mice do not work on one computer (but work with the other computers). They both are USB. I hook them up with a USB to PS2 adapter. If I use a ps2 ball mouse connected to the KVM the mouse works. All the Mice work if I directly connect them. Since I do not want a ball mouse I got a Frisby optical PS2 mouse. It works with all the computers on the KVM's.
I do not have a solution for the Keyboard yet. 1 computer (ASUS MB) on my trendnet or belkin 4 postion KVM does not recognize the keyboard.
Aug 25, 2008 | D-Link DKVM 2K (DKVM-2K) 2-port KVM Switch
GCS5632u KVM swith working with Vista
Make sure the keyboard/mouse receiver is connected to the keyboard port on the KVM -- there is an embossed icon near each port -- mouse and keyboard.
Jan 01, 2008 | IOGear GCS632U 2-port KVM Switch
KVM freeze, mouse and keyboard failure upon keypress
When ever trouble shooting a KVM that has a problem with one computer always swap the cables at the computer end -- that will tell you if you have a computer or KVM issue.
Nov 07, 2007 | IOGear MiniView GCS62 2-port KVM Switch
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
