Welcome to FixYa.
Based on your description you`re experiencing the same thing 99% of folks with this type of dishwasher do...eventually.
The good news is it is likely just a clogged up or dirty sump assembly.
Here`s what you can do, I find removing the top rack to be the best place to start.
However I also find sometimes visual "how to" instructions are better than explanations, therefor I`ve attached a video for you to check out.
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
This should help you get to the pump filter, spray arm and check for food deposit, broken glass, undissolved detergent and general water deposit built up in the sump well.
The key is to get in there and clean it all out, This will be applicable to most Whirlpool, Inglis, Kenmore, Kitchen-Aid, Jenn-Air.
When you`re finished run it through a test cycle and see how it goes. You may even want to run it empty with just a bowl of "white vinegar" on the top rack for a dishwasher bath.
Let me know how you make out and what you find.
Good luck.
Regards,
Macmarkus :)
The scum, film and white
residue problems have started since the reduction of
phosphates in dishwasher detergents.
Here is a tip that
will help you to solve the problem of films, residue, and scum in
your dishwasher.
Dishwasher
Residue and Film on Dishes
heatman101
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
zzty
