I need a new frothing attatchment for my Braun espresso machine #3062. It is a white plastic 2 piece screw on diffuser that fits on the end of the steamer part. sent mine through the garbage disposal and it no longer fits on the machine. Any ideas? I've ben to many sites with replacement parts-I have not seen this one. I need the 8c. two cup adapter and 5b. mini turbine blades and 5c. air vent openings, for the Braun expresso machine 3062.
If you are unable to get the part directly from BRAUN by calling 1-800-272-8611 (if your machine still falls within the warranty they will usually replace it for free) then I would recommend that you try Ebay as corny as it sounds because you could likely buy a used/new set for not much more than you would pay for the "ordered part" from replacement part sites.
Also, if Braun no longer carries the part you need you could also try asking them if they have a diffuser from a different model that would work with your machine.
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
Flavia is not doing second burst or final steam to end the brewing. There is a usually a second...
(More)
Flavia is not doing second burst or final steam to end the brewing. There is a usually a second blast of steam or water through the coffee packet to end the coffee makeing. As a result there is not a final emptying of the coffee in the packet. What can i do to remedy this?
My Gaggia evolution espresso machine basically stopped working because water comes out so slowly...
(More)
My Gaggia evolution espresso machine basically stopped working because water comes out so slowly that it would take an hour to make an espresso. I tried to take off the unit where the water comes out using allen wrenches but then did not know what to do. Please help! Thanks!!
