Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
Won't turn on
The battery is fully charged and when i put it in, the camera won't turn on.  so i put the battery back on the charger and the light is orange for about 5 min and then it turns green. i try it again in the camera and it won't turn on.  this is the 2nd time this has happened. the 1st time i took it in and they fixed it with but they won't tell ,me what the problem is.  i'm tired of taking this camera in.  what can i do to avoid this again?  i have never dropped the camera before either.
  • jyvette May 29, 2008
    I dropped my camera on my desk at work as I was viewing photos on the screen..When it fell, it shut off and I tried to turn it back on but it didn't work. I thought it may have been the battery so I charged the battery and tried to turn the camera on again. Its still not working.
    What can I do (if anything) to try and make it work?
  • Anonymous May 31, 2008
    I used Smar T-Arse's suggestion. With the battery door open I pushed the little switch beside the memory card with a wooden toothpick and could power up the camera. I then closed the door just to see if I could press on the battery door to make the switch contact but it did not work.. The battery door has a small protrusion that must depress this switch but mine is either worn or a piece is missing from the top of the switch. I made a small rectangle of aluminum foil and inserted it above the switch with the toothpick and now the camera works fine. I guess that this would be considered a temporary fix that will get you up and running until you can get it properly serviced, but for me, it's fixed..
    Scholar:
  • 46 Answers
Dear Michibear
Open the battery door , there should be a small button
( right next to SD Memory card on my IXUS 60 )
It tells the camera when door is open & disables power to the camera .Its very weakly made & is responsible for alot of people's problems I have seen so far,including myself !!
The one on my IXUS 60 just magically fell out and landed down the drain whilst I was just changing a battery , and the camera ceased to function. With the button itself gone the copper wire terminals were visible. I used a small pair of scissors and pushed them together and it instantly resumed working, & still does.
I'd recommend using a piece of aluminium foil , or any other conductive material folded up and inserted into the cavity to connect all the copper prongs together.
Im not going to tell you to pull your button out, BUT,
Upon seeing inside it, I'm confident that even when still intact , it'd be really easy for it to malfunction....
Posted on May 26, 2008
  • SmarT-Arse
    SmarT-Arse Jun 08, 2008
    HeeHee Glad to have helped out :)
    Thanks for posting your successfull results to help others !!!
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
I have a Samsung PL100 digital camera. I dropped it while at beach, it was switched off. When I went to switch it on the lens came out but then it made a buzzing sound and switched itself off. The lens is...
I had the same exact issue.... try putting it on the charger, even if you think it's fully charged... If the light is red, leave it on the charger until it turns green, and then remove the battery for a second and then put it back in the camera before turning it back on..... try turning it on. If it still won't close, put it back on the charger. If the charger is automatically indicating a red light, that means you have exhausted your battery and will nee a new one... they cost about 5-11 dollars on amazon...... hope that helps...
Jul 20, 2012 | Cameras
I have a Sanyo Xacti VPC-E60 EX Digital Camera.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jun 16, 2012 | Sanyo Xacti VPC-E60 EX Digital Camera
Won't turn on
I had this same problem! Scoured the web and found no solution. This is what I did to fix it...
Remove battery. Unplug charger. Press and hold the power button for 20 - 30 seconds. While still holding the power button, re-insert the battery and/or plug in the charger. Voila! Came back to life and worked like nothing ever happened.
I also did the same thing with the record button, but it was the power button that got the result.
Hope this helps!
Feb 29, 2012 | Toshiba Camileo S30 HD Camcorder -...
I have a brand new Nikon D3100. The battery was fully charged and placed in the camera. I took about 4 photos, and then turned the camera off. When I turned it back on the battery wasn't working to...
The solution to your problem is simple, Kathrynbax.
The battery never comes in fully charged. It's always charged only so you may be able to check if your camera is working. I suggest, you take out your battery and put it to charge for exactly 90 minutes as the manual says. Then I'm sure you won't face any such problems.
Hope this solves your problem.
Good day!
Rebel
Sep 17, 2011 | Nikon D3100 Digital Camera
How do you get the camera to charge? I put in new batteries and it still says battery low and shuts off. I have plugged it into the computer and it still won't charge. It won't even turn on.
Some camera will not turn on (Turn on but not take pictures etc) when you plug it in USB, it will only communicate with the camera PC suite software to transfer pictures.
Regarding the battery, if your camera has mobile phones type lithium ion batteries then you can either charge these batteries outside if you have a charger for them or put the battery in camera and plug the camera with its charger that came with it. Its just like charging mobile phone.
If your camera uses AA size (pencil cell) batteries then you will need to either buy Duracell batteries (or any other good Alkaline battery, Duracell is good) and throw them when they stop working or
Buy rechargeable AA size Ni-MH or Li-Ion batteries with charger. Charge the battery with its charger for at least 12 hours before first use or follow the instruction written on battery pack.
I think you are either using normal carbon AA size batteries that are used in clocks or toys, these will not work in digital camera.
May 15, 2011 | Cameras
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
Jul 22, 2010 | RIM BlackBerry Pearl 8100
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
99 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
