Indesit w123 prog dial goes round but does not do anything else?
  • tracyparker Jun 11, 2008
    my washing machine starts emptying and half way through stops and the programme button just keeps clicking around can u help plz
It's the motor brushes that are worn and taking down the neutral side of the circuit hence nothing else works !
Posted on Oct 08, 2010
Indesit w123. motor burnt out?
If your seeing flashes from behind the dial I'm thinking that the timer needs to be changed. Even with the motor shorted out, it still wouldn't cause that effect to happen.
Jun 17, 2012 | Indesit Door Handle Kit for W123, W133,...
I have a indesit w123 and when i put it on it starts to fill up and then the dial keeps going round, can you help please...
try and clear prog memory .what to do is set prog knob to an off position where the black spot is then switch on machine the red light will flash quickly then slow down. when it does switch machine off then select program and switch on and it should be ok.if not it could well be a main fault on pcb .indesit boards are not very good .hope this helps.
Jun 07, 2011 | Indesit W 123 Front Load Washer
W123 holding some water and dial keeps spinning around checked the filter all clear
may be a blockage in the sump hose or pump feed hose or the pump itself may be faulty. the dial will click round to tell you there is a fault. to reset turn the dial onto every DOT and turn on for 10 secs then off and onto the next dot it will flash for a couple of seconds to confirm.
Mar 17, 2009 | Indesit W 123 Front Load Washer
Dial keeps rotating
This a common problem with Indesit washers..
It is not a timer but a programme selector switch.
What you need to do is the following.
Switch the m/c on, let the drain pump empty the water, then switch the m/c off.
set the selector switch to one of the black dots on the dial, which is stop/reset.
Then switch washer back on, if the dial still keeps going round and round, then you are going to have to call an engineer, as you have what is called an Anomaly (fault).
Plz leave feedback for this solution.
Thanks
Dec 09, 2008 | Indesit W 123 Front Load Washer
Indesit W123 5 flashes error!!
The F05 fault means the pump is blocked, check the filter at the front bottom right of the machine behind the plinth and if its connected under a sink check the hose & connection
Nov 03, 2008 | Indesit W 123 Front Load Washer
Replace door rubber W123
how do I replace the door rubber on Indesit W123
Oct 26, 2008 | Indesit Washing Machines
Indesit w123
not really worth replacing timer as many problems can cause this
May 19, 2008 | Indesit W 123 Front Load Washer
Indesit w123 front load
would check pressure switch and the pipe that goes down to the drum for blockages if not may be faulty water valve unplug first regards jason
Apr 28, 2008 | Indesit W 123 Front Load Washer
Indesit W123 - 8 Flashes Error Code
thats a problem with your heater, or the heater relay on the main pcb. best off replacing heater first as its the cheapest option.
hope this helps
kj
Oct 26, 2007 | Indesit W 123 Front Load Washer
Indesit W123 s UK water overflows from the detergent draw
My machine clicked round, although I did not have the water overflow. I managed to unlock the pump filter, on the front of the machine under the lower panel. This was fiddly. I removed a coin. The machine worked again, but two cycles later starting clicking round the timer. I called an engineer - it worked when he was here, he checked the element and pump and said it was OK. When he had gone, it clicked round the timer again! He came again, and once again it worked perfectly when he was here. Eventually I checked the pump filter again, and removed another two coins. At the moment - it is working!
Oct 11, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
198 people viewed this question
Top Washing Machines Experts
