Question about Philips Televison & Video
Phillips 42" flat screen ty
Has two very wide horizontal bars across the screen, the lower one being wider. When the situation first began, there were random and MANY red (mostly) and black pixels splashed across the screen which seem to be organized in "blocks" of space. The turning off and on, checking it against how it displays DVDs, completely unplugging it to allow the capacitors to discharge (which usually works very well, but when it has happen before, it's been when we turn it on. We just turn it off, wait and start over and things work. This time it had been on for about 6 hours and suddenly, this failure. Husband is searching for manuals at the moment, as we have moved things... any ideas?
Well, I spent $20 on FixYa which did absolutely nothing and now and waiting for the Phillips to show up to take my TV to their shop (which alone will cost me $100 in itself) and wait for approximately 2 weeks to find out if the fix costs more than the TV is worth, in which case, I'll be out thousands of dollars, plus $20 to you, plus the Phillips charges AND whatever a replacement TV costs.
Did that answer your question?
Posted on May 21, 2008
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Intermittent black or snowy horizontal bar across the top
You're somewhat sound in electronics I assumes. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 17, 2013 | JVC PD-42WV74 42 in. Plasma EDTV
Insignia 42 tv horizontal line problems
One among the back-light CCFL lamp has burned out. Replace it.
Jan 23, 2013 | Samsung LN-T4661F 46 in. LCD HDTV
Hi have a samsung 42 inch plasma, all of a sudden it has a band 20cm wide of dotted lines going across the whole screen, some channels or when playstation in use the band gets wider, does not seem to...
if the band is horizontal your tv has bad y-buffer board. Usually there are 2 buffer boards- top and bottom. if the problem is in the top half of the screen replace the top board, otherwise replace bottom board.
but better to replace both a the same time.
if the tv has a vertical lines from top to bottom it may have bad plasma panel and can be considered as not economical to repair.
Oct 03, 2012 | Samsung SPN4235 42 in. Plasma HDTV
Wide horizontal bars ghosting across screen
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .also check you warrenty its usually 3 years
Apr 12, 2010 | Acer AL1916W 19" LCD Monitor
I have an LG Plasma "RU-42PX10C" i have sound but the picture is a lot of Horizontal colored lines
Please check if you have turned the wide feature ON. Wide feature would make the picture wider.
Hope this helps.
Regards,
HP
Aug 28, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
I have a red and green bar rolling across my screen
call HP case management 877-917-4380, tell them you want this fixed and be firm. They are being very helpful with my problem and keep sending parts until it's fixed , all free of charge with tech at my house
Dec 03, 2008 | HP PL4260N 42 in. Plasma HDTV
Red in picture
Have you tried with a new scart or htm lead?
Sep 23, 2008 | LG 50PX4DR 50 in. Plasma TV
Phillips 42in plasma lines ocross screen
Are the solid horizontal black lines or colored lines. If colored lines there is a posibility that your Y-main, and upper and lower Y-buffers are bad. If black you have a bad plasma panel.
Oct 08, 2007 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
89 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
