Canon s750 wont print black text
Help I have cleaned out the printer heads and ran a test in service mode where it did return black text. But I cannot print black text.
  • 563 Answers
Hi lilshygurl
I would suggest you to repost this question , but in the PC & Printer division of this site as this requested ended up in the Multimedia and Projector side of things and will most probably not get answered in this section at all.
Thanks for Fixya and good luck !
Posted on May 20, 2008
I have a Canon MP730 and it has always worked great - until. I ran out of black ink and replaced tank. Tried to align the print head, but none of the black samples are even close to being a solid color -...
Hi There,
I believe that the printer head which feeds the ink dried out and clogged at the ink dispersal point. I'd suggest you take it to your nearest printer service capable repair center and just have them unblick the clog.
Regards,
Selk
Mar 25, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MultiPass MP730 purchased 2004 NOT Printing Black INK- did: new canon ink tank inserted (never used refills) ran: printhead maintenance mannually cleaned print head w/ rubbing...
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Dec 02, 2010 | Canon Office Equipment & Supplies
Only prints black ink text; cartridges full and good.
Run head cleaning and deep head cleaning for few times. If it doesnt help, you can try to remove print head, and clean the nozzles with distiled water.
And after that also run few times head cleaning mode.
Jul 17, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Prints purple instead of black on photos only
My Canon printer has TWO slots for black ink cartridges. I assumed one was extra and didn't replace it when I ran out. Text printed just fine with only one installed, but my photos were printing with purple instead of black. I looked into it, and the two cartridges are different: one holds dye-based ink, the other has pigment based. Photos must require both kinds. If your printer is the same as mine, use both!
Jul 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
My Canon S750 Bubble Jet Printer does not print with black ink. It seems to print all other colors though.
Replace and install the black ink cartridge with this Black Ink Tank BCI-3eBK Ifyou have done this and is still missing the black ink on print, clean the print heads. 1. Right-click the printer icon, and then select 'Properties'.
2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'. 3. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
That should most likely work. If deep cleaning did not help, you may need to replace the print head.
Nov 25, 2008 | Office Equipment & Supplies
Canon S750 printer not printing black ink well
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It's best to do this each time you install a new cartridge. get more information and help from here .
Oct 01, 2008 | Office Equipment & Supplies
Ckeck printer ##343
its a printer reset error press
*AF-Key = Additional Functions key = the black button with the star in a head above it.
1) Enter SERVICE MODE. (Press AF-Key, followed by "scan", "copy", "scan" -Keys)
2) Select TEST MODE (press right arrow button 13 times).
3) Hit -OK-
4) Select [8] PRINTER TEST
5) Hit -OK-
6) It'll now say "- 8-2 +" press the right arrow key once to get "- 8-3 +"
7) Hit -OK-
8) Select 0. [INK COUNT].
9) Hit -OK-
10) It should return to showing the "8: Printer Test - 8-3 +"
11) Press the [Stop/Reset]key - (black key with triangle and circle on it) - (returning to the state of 4), and then press the [ON/OFF] key.
Cleaning the print head:
At any time, DO NOT wipe the actual print head with your fingers. Use ONLY water.
-Remove print head assembly from printer.
-Remove ink tanks.
-Use running warm water, wash away the exess ink that is dried around the print head.
-Take one disposable mug, fill with hot water, drop the print head assembly in there, and let it soak for an hour, or so.
(-IF you have massaging shower head, with spray jet -function, use this to deep clean the actual print head.)
-Dry it up carefully, do not wipe actual print head, just tap gently with soft paper.
-Install ink tanks, install assembly to printer, let it settle for some time (5-30 minutes)
-Run Nozzle check, cleaning, print head alignment
hope this helps if you have further problem do let me know
pls appreciate by rating this solution
Aug 13, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Canon i560 won't print black text anymore
I have now found the solution elsewhere in the internet: black text only prints on the Canon i560 if selct "normal paper", but not,for instance, if you have "professional photo-paper" selected.
Apr 16, 2008 | Canon BubbleJet i560 InkJet Printer
Is it time to Replace my S200Print Head?
YES, IT IS EASY TO REPLACE THE CARTRIDGE, JUST PRESS DOWN A LEVER FOUND ON THE RIGHT SIDE OF THE PRINT HEAD AND EVERYTHING LOOSENS UP... YOU COULD ALSO CHANGE THE CARTRIDGE BY REPLACING IT WITH A BC-20 CARTRIDGE... IT'S A PURE BLACK CARTRIDGE.
Jan 05, 2008 | Canon BJC S200 InkJet Printer
Canon IP3000, problem printing black
Try to change the default printer and check ...
Also try printing from other documents see if you facing the same problem
What version of Works you using ?
Do you have the Dic for Works ?
Apr 14, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
144 people viewed this question
jasbo
jasbo
