Question about Okia 250w UL Approved ATX Computer Power supply (OKIA300ATX) Power Supply
Fan Hi, My fan is not working, and my power supply heats up. Please advise on what to do. My power supply model is : OKIA-420ATX
  • 101 Answers
Hi replace the fan by opening the power supply with a new fan if your power supply is under warranty period still get it exchanged.
Posted on May 24, 2008
I have a Okia 420ATX power supply. I had it
Based on the additional information that the power supply fan turns on for a few seconds and then goes off indicates to me you have a motherboard or processor problem. I would have a service center check the computer for you.
Feb 03, 2010 | Okia 420w UL Approved ATX Computer Power...
Need fan for Okia 350 ATX
its the bearings in the fan starting to pack up, best way is to stop the fan spinning when its on with a small pencil and this should re- align the bearings in the fan and stop the noise, you will need a new powersupply the fan is on the way out, just a temp. fix for you to stop the irritating noise
Jan 28, 2010 | Okia 350w UL Approved ATX Computer Power...
I have an OKIA power supply that was installed last September. The fan has stopped working allowing the tower to overheat. Is this model OKIA 350-ATX still in warranty?
Yes, the factory provides a 1 year warranty. Since you installed it some 11 months ago I suggest you contact them asap. You'll probably need to provide the serialnumber to them as part of the procedure.
Okia is not actually the full name, the company that makes them is called Broadway Com Corp and their (powersuplly) website is: http://www.bccpc.com/bccpc/power_all.htm
The contact information can be found at: http://www.bccpc.com/bccpc/contact.htm
Aug 12, 2009 | Okia (OKIA550WP4PS) Power Supply
Dead Computer
Is the fan of the power supply still circulating?
If not, your power supply needs replacement.
Jul 24, 2009 | Okia 420w UL Approved ATX Computer Power...
No power to motherboard
Could be one of these:
1. Lead Fuse could of blone
2. Fan broken
3. Insted of the power, it could be your motherboard
4. THE WHOLE THING
Im sure your get it fixed soon and i hope me telling you what it could be has helped you.
DigicalJAI
May 19, 2009 | Okia / 450-Watt / ATX / 80mm Fan /...
I have a okia 500atx power supply. When I attempt to turn on the computer, it will stay up for about 3 seconds then turn off. is the power supply the problem?
CHECK THE FAN REMOVE ANY DUST AND SPIN THE FAN PLUG IT IN AND TURN IT ON IF SAME PROBLEM THAN THE FAN IS BAD IN THE POWER SUPPLY AND YOU NEED A NEW POWER SUPPLY TAKE IT WITH YOU WHEN YOU GO TO THE COMPTER STORE FOR A NEW ONE
CANDYMANGANDY
Jan 27, 2009 | Okia / 450-Watt / ATX / 80mm Fan /...
Where to plug case side fan
Pinout Pin number Wire color Description 1 yellow +12 volts 2 black ground 3 black ground 4 red +5 volts
My computer turns on but wont turn hdd all the way on it starts then clicks and stops goes to a black screen. and there is a smell coming from the computer. i put the hdd in another tower and it worked.....
If you have a standard atx case then any standard atx power supply should work. Yes you can upgrade to one with more wattage as long as it has all the connectors you need. Hope this helps.
Dec 24, 2008 | Okia / 450-Watt / ATX / 80mm Fan /...
Humming noise
IT sounds like the fan bearings are going out already, or have flat spots on them that cause vibration at speed. Try calling the manufacturer and tell them the fan either quit working or is about to quit.
May 08, 2008 | Okia / 450-Watt / ATX / 80mm Fan /...
Power Supply Warrenty
I couldn?t find a web site for Okia either; however, I did note that the venders that sold them usually guaranteed them for one year themselves. I would at least try that route, that and not buy Okia power supplies. There are lots of stories and physical examinations of how poorly they are designed and manufactured.
Sep 19, 2006 | Okia / 450-Watt / ATX / 80mm Fan /...
Computers & Internet Logo
250 people viewed this question
Top Okia Computers & Internet Experts
David Payne
David Payne
Are you an Okia Computer and Internet Expert? Answer questions, earn points and help others
