Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
Print Cartridge in Right Stall not Supported.
After installing a new Black Ink (98) cartrige I have been receiving the following error messge: Print Cartridge in Right Stall not Supported.
  • hoggies Jun 03, 2008
    was printing some documents ok then went to print another and have received the message 'print cartidgei n righ stall not supported' have turned it on and off taken out the cartridge but to no avail.
  • myster843 Nov 04, 2008
    I have been printing on this printer for a few weeks and after updates to my computer it will not print. I have remanufactured cartridges in and it says that I have the incorrect cartridge Print cartridge in right stall not supported. I have vista and an HP photosmart C4180 all in one printer. Can you help???
Print cartridge colour ink is not workink fix with hp print
Posted on Jun 26, 2008
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
May 15, 2011 | Lexmark X4650 InkJet Printer
Black ink won't print . have put in new cartridge still doesn't print
Try the following:
1. Remove the black cartridge
rub your finger against the small round opening at the bottom of the cartridge to see if you get ink on your finger.
- If you do not get ink, you have a problem with the cartridge
2. If you got ink on your finger perform the following:
Be sure that the Cartrige is inserted correctly and is perfectly inserted - Press lightly on both sides of the cartridge to ensure it is fixed in position.
a. open the Lexmark printwer home page. It should have been installed when you setup your computer
b. Open the maintenance Tab
c. Press "Clean Cartridge
d. Press "Print test page"
e. If Necessary Press "Align Cartridge"
- Hope that Helps
May 02, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
I refilled my black cartridge of Pixma iP 1600. I have done it 3 times before and it worked perfectly until yesterday. Now when I refilled it the 4th time, the yellow LED blinks 5 times and then the green...
The manual for the PIXMA iP1600 says the following concerning the 5 blinks:
The ink cartridges are not properly installed, or a non-supported ink cartridge is installed (the ink cartridge EEPROM data is abnormal). Install the ink cartridges properly. Or, confirm that the supported ink cartridges are installed.
If you haven't already I would take a look at the electrical contacts on the cartridge to make sure they are clean (free of dust and ink) and then reinstall them in the printer. If the printer gives the same error, it's time to buy a new cartridge. 3 refills from a cartridge is not bad at all.
Hope this helps,
Steve
Feb 10, 2011 | Canon PIXMA iP1600 Printer
Dell A940 prints black but doesn't print in color. I installed a new color cartrige and the 50c error went away, but still doesn't print in color...
Hi there Error 50c
This is for yours.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Nov 20, 2009 | Dell A940 All-In-One InkJet Printer
Query msge: Insert black or photoprint cartridge in right stall
REMOVE both cartriges then insert it again correctly in proper places
May 06, 2009 | HP Officejet 7210 All-In-One InkJet...
Are these genuine HP ink. If not try using Original ink.
If its already the original ink then check the Exp date of the ink and try cleaning the copper contacts of the ink ( not the nozzles ) of the ink and the printer
All the best
Sep 24, 2008 | HP PSC 2410 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Cartridge Problems.
    Go to Printer & Faxes locate your printer> Right Click go to properties and maintenance you can reset the ink counter. hat should solve the problem.
    Dec 05, 2007 | Dell Photo 964 All-In-One InkJet Printer
    No black ink print. Prints in light blue
    Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
    Nov 06, 2007 | Office Equipment & Supplies
    HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
    591 people viewed this question
    Vinaya Kumar...
    Vinaya Kumar...
    Seeker5211
    Seeker5211
