Question about Mitsubishi VS-50705 50" Rear Projection Television
Mitsubishi VS-50705 50 in apparent convergence problem.
Some times my picture will look fine. Then, now more often, it appears the red, green and blue convergence split. It seems to go in and out. Around peoples heads you can see the red, green, blue ghost effect. Now if you use the display button the words for input and time appear to only see red and green split not blue. When it is out I attempt to go into the convergence with the + sign and even in advanced where you can do sections of the screen. But it doesn't appear to have any adjustment capabilities at all. In this adustment I can see all three color cross hatch patterns. Any ideas on something easy like capacitors, etc? I have a service manual and have been looking at the convergence section but nothing jumps out just yet. I'm looking around IC801,802,803 and the amp chips etc. All suggestions welcomed.
    Genius:
  • 1,153 Answers
First thing a tech would do is solder around Convergence amps then check to see if you can align by menu then if can not. Change amps and maybe resistors.
Posted on May 19, 2008
Hello I have a mitsubishi vs-45603 with what appears to be a convergence problem.
You may have bought bad chips or your soldering...
This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
Mar 22, 2012 | Mitsubishi VS-45603 45" Rear Projection...
I thought i might need a lamp for my mitsubishi tv--model VS 60607 when my tv is fuzzy when turned on.should i simply replace the lamp or is there something else i should try? thank you!
This TV is a rear projection television and does not have a lamp. It has three CRT color guns (Red, Blue, and Green). You have a convergence issue (the red, blue and green color guns aren't aligned properly) and it doesn't sound like a very big one. You should be able to adjust this through the CONVERGENCE Menu in ADVANCED SETTINGS.
More details can be found in your manual, here. The model number isn't exactly the same but I'm sure the process is identical or really close. The other option would be a bad IC (integrated circuit) for the convergence control. This is unlikely unless your picture looks something like this: captainhawk1_15.jpg
May 29, 2011 | Mitsubishi VS-60607 TV
Mitsubishi VS50805 Serial # 102718 No red in picture
Replace the convergence ICs your model uses two STK392-040 Convergence ICs. You can get replacements at the following link with instructions.
http://servicemanuals.vstore.ca/
Dec 28, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-5006R picture Ghosting
Since the problem corrected itself initially, it may just be poor solder connections. Try resoldering the pins on the convergence ICs. These are large black ICs attached to a heatsink and should be marked STKxxx. If resoldering does not resolve the problem, replace the ICs.
Dan
Jun 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi Vs-6047 Convergence Problem...Please Help!
usally convergence green is split between 2 ics. so if your blue and red are still good. it might be the green output resistors. The
Jan 08, 2008 | Mitsubishi VS-6047 60" Rear Projection...
I have red green and blue lines thru the screen
Difficult repair = requires chassis pull and convergence circuit
repair.....Replace convergence IC's and any bad soldered in fuses..........then check alignment.................T.
Nov 30, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Blue, red and green ghosting, curves in picture
convergance amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 30, 2007 | Mitsubishi VS-45609 TV
Mitsubishi 50 in vs-5043
Needs convergence circuit O/h==replace convergence IC's & any damaged/over-heated resistors.re-align as needed.
Oct 01, 2007 | Mitsubishi VS-50502 50" Rear Projection...
Mitsubishi VS 4552A
One of your convergence IC's has either cracked loose or burned out. The IC will have to be resoldered or replaced and then the convergence circuits realigned. If you do not have experience in repairing convergence circuits then have a qualified tech handle it for you. This is by far the most common failure in the projection sets and a good tech can have it fixed in about an hour and a half. I charge $150 for that but shops in your area will vary, so call around.
Jul 30, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-50705 50" Rear Projection Television Logo
115 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
