Question about HP OfficeJet 6210 All-In-One InkJet Printer
Ink leaking inside printer
3 black printer cartridges have leaked inside the printer. We can see the ink. How can we fix this problem? We thought at first the problem was with the cartridge, but after seeing 3 leak, it's not the cartridges.
    Scholar:
  • 87 Answers
Can u elaborate a little on "leaked inside the printer". Where is the ink. Are u using compatible cartridges...?
Inkworks
Posted on May 27, 2008
    Novelist:
  • 79 Answers
As discribed by you , the issue is certainly with the printer , in case unit is under warranty u call hp technical support for assisstance ( as printer needs to be replaced) . In case its out of warranty u can try to get in touch with a local reseller . or repair center.
HP On-Site Service Dispatch Center at 800-633-3600.
HP RESELLER SUPPORT: 1-800-544-9976.
Thanks
MAC .
How can I fix my ink problem?
It is possible the ink carriage and print head are very dirty and needs servicing.
Aug 25, 2014 | Brother LC51BK Print cartridge, Inkjet...
HP 1010 12-A CARTRIDGE...
Hi
Replace the ink cartridge with another
Jan 14, 2014 | HP 12A Black Laser Toner Cartridge...
Leaking blank ink
take a lint free cloth and then clean the copper contacts of the ink cartridge.. if it does not work then try with a different black ink and then contact HP for replacement of the black ink if the ink cartridge is in warranty
Nov 15, 2012 | HP Photosmart C7180 All-In-One InkJet...
Purging air from ink tubes z2100
While printing,air pump pushing pressured air in to the cartridge bank to force ink out through ink tubes tubes..During this process any leak at the cartridge neck or blockage in cartridge needle causes leak. Remove all cartridges check two needles inside the ISS unit for each.. upper needle allows the ink flow in to the pipes and below needle pumping the air inside the cartridge bank..If any blockage in upper needle causes ink leak. My sincere advise to the users better replace ISS unit & stop printing for further damages..For Tech guys only: Remove ink supply station along with ink tubes out,gently detach both tubes(magenta), you can see the needle other end pump syringe alcohol with the help of syringe, do this process up to free flow.. once confirmed refix tubes back, ensure that no leak should not happen.. fix all back.. try...This advise purely professionals can perform.. others strongly cautioned.
Jan 31, 2012 | HP Designjet 4000ps InkJet Printer
Canon Pixma Mp250 leaks ink
cartridges tend to bleed when the ink waste pad gets full canon ink
Jan 11, 2012 | Canon Pixma Mp250 Allinone Inkjet Photo...
Black ink leaked on inside of printer.
try to replace the defective cartridge by a new one and see printing test result
Nov 18, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
HP DeskJet 930c is leaking black ink
The printer primes and cleans the cartridges when the cartridges go to the right side of carriage. Sounds like a cartridge has either leaked or you have used it enough the the ink pool is full, or you have layed the printer on its side or back. From experence, if ink is leaking out of the printer, your probley better off getting anithe printer. I have tried to take the covers off and clean inside print, and it is a messy job.
Mar 06, 2009 | HP DeskJet 930c InkJet Printer
Leaking Black Colour
REPLACE THE PRINTER AND SAVE YOURSELF A HUGE MESS
Understand when I suggest replacing the printer, it isn't that you can't fix it or that I'm not answering your question. But to do so will require cleaning every inch of the internal components. The ink will stain everything it touches and you'll need a smock, a work area, and probably gloves.
See what happens is that where the print head parks there is an ink absorber and below it is an ink well. The ink absorber is a sponge like arm that cleans off the cartridge and the well catches the loose ink. Inkjet printers are for the most part not designed to last past a few years, so few printers have a method for emptying these. When they become full the printer will start leaking ink in torrents but will continue to function normally for quite a while until it fills every nook and cranny of the printer. While all you notice is a sightly higher consumption of ink.
By the time you start visibly seeing the ink come out of the printer, the inside is a huge mess, and when I say huge I mean without cursing, words just can't express how nasty and ink smeared it is.
Aug 04, 2008 | HP Photosmart C6180 All-In-One InkJet...
Newly Installed 7680
probably you did nothing wring, I seen a few of these cartridges leak - HP should replace the machine if the damage was caused by original cartridges.
Apr 21, 2008 | HP Officejet Pro L7680 All-In-One Printer
Black ink leaking from bottom of printer!
There is a small hopper inside of the printer, called the cartridge holder, this is where the excess ink is wiped off of the cartridges, and is just left there. it is usually on the side where the cartridges stay when they are idle. The easiest thing to do, is take the cover of the printer off, and blot the ink out of the hopper, do not use any detergents, or liquid cleaners, as this will ruin the cleaner head for the cartridges.
Jan 18, 2008 | HP PhotoSmart 1315 InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
378 people viewed this question
Seeker5211
Seeker5211
