Question about GE JASHO97985 Mouse
Mouse not connecting.
I have plugged in the USB port and the computer has recognized the new hardware, but mouse is still not operating.
  • Bilal Anwar Nov 27, 2008
    Windows is detecting the mouse but it is still not working.Neither a PS/2 nor a USB mouse is working.
    President:
  • 8,637 Answers
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 20, 2009
Need to be able to connect to my computer . plugged it in but computer does not recognize the mouse . red light is on
My computer doesn't recognize my mouse and its not listed in ...
www.tomshardware.com > ... > Windows 2000/NT
Tom's Hardware Guide
Mar 25, 2012 - 9 posts - ‎7 authors
please help.....I am using my keyboard to move my mouse keys and it really sucks. After a storm everything came out fine on my diagnostic ... My computer doesn\'t recognize my mouse and its not ...
Feb 28, 2013
Mylaptop doesnt recognize the usb for my mouse ...
Jan 27, 2013
Computer won't recognize keyboard or mouse - Mice ...
Aug 27, 2012
Computer won't recognize keyboard or mouse? [Solved ...
Aug 6, 2011
More results from www.tomshardware.com
Mouse doesn't work in any USB port - Tom's Hardware
Jan 21, 2016 | Onn Optical Mouse
MOUSE IS NOT RECOGNIZED NEW BATTERIES CHECKED ,
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Feb 25, 2011 | Logitech Cordless Mouse
I have a new Dell computer, which has no PS2 port.
No, unfortunatly there is none unless you specificaly ask Dell for a usb driver.
It's a common myth that users think USB has built in drivers in it's hardware. The only resolution to this issue is to ask the manufacturer for a new driver for this specific item to run under usb.
Mar 05, 2010 | Fellowes Touchpad STD PC (platinum)...
Ps2 port doesn't recognize Microsoft Optical mouse
You might think about a USB hub for all your USB devices. ps2 port is more or less dedicated for mouse, which is why your mouse pointer is stuck in the middle of the screen. Go ahead and get an externally powered USB Hub to power other USB devices. To answer, ps2 for mouse needs just a mouse, not USB device.
Sep 28, 2009 | Microsoft Windows XP Professional
Microsoft wireless mouse 3000; put in new battery, still nothing
nikcorra2488,
try this: plug in the USB key & check for the green light. Then go to start, control panel, & double click mouse (with whatever mouse works). Check the hardware tab and see it the computer is recognizing that the mouse is there. If it is there, it should be working fine. If not, then perhaps you need to reinstall the USB port drivers. Sometimes this will happen when you've upgraded from 1.0 to 2.0 USB ports.
Hope this helps.
-samson39
Jul 26, 2009 | Microsoft Wireless Notebook Optical Mouse...
Spyder mouse won't work
I had a similar problem. I corrected by performing a manual connect as listed in the manual that came with the mouse.
Manual reconnect:
1. Plug in the receiver.
2. Turn on the mouse.
3. Press the button on the receiver.
4. Press the connect button on the mouse once within five seconds of pressing the button on the receiver.
This worked for me, and the mouse has worked fine since.
If this doesn't work. The manual suggested taking the batteries out of the mouse for 20 seconds and unplugging the receiver, then repeat the steps above.
If that doesn't work. reboot the computer and repeat the steps above.
Hope this helps.
Jul 21, 2009 | AVENUES The SPYDER SwissGear Wireless...
After rebooting my cpu my mouse stopped working. My cpu does not recognize my mouse? The mouse works because i tried it on a different cpu. what can be causing this?
Did you try to reboot?
Do you have an optical mouse? (if yes: is the red light on?
(Then the mouse is recognized and you must configure your mouse options)
Did you try to connect your USB mouse to another connector?
Or if PS2 connector: Turn of the pc and connect the mouse and power on.
Did you install a new driver? (then uninstall this driver)
Try looking for the most recent mouse driver on the manufacturer site.
Jul 13, 2009 | HP Pavilion a1610n PC Desktop
USB device not recognized
try another usb port also try booting without it plugged in when booted plug in it may recognize it as new hardware
Jul 31, 2008 | Verbatim 95208 Mouse
Switching keyboard and mouse
Mice and keyboard are the two most basic input devices for the modern computer. Not much is needed to change them out.
Turn your computer off. Remove the old keyboard and mouse. Connect the new keyboard and mouse into an available usb port. Restart your computer.
You may have to wait anywhere from 30 seconds to a few minutes, depending on your computer, before the operating system recognizes the new hardware, but once it does, it will start responding.
Jul 03, 2008 | Dell 2 Button Mouse 6u226
Laptop does not recognize wireless mouse
Most wireless mouse are not plug and play.
Try this:
May 28, 2008 | Bluetake (bt500+bt009x) Mouse
GE JASHO97985 Mouse Logo
161 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
