Question about Xerox FAXCENTRE 2218 18PPM FAX
Toner how in the heck do i replace the toner? i can't even find it! this is the closest machine to the one i have as the only identifying information on it is WorkCentre M15i not listed. this one is similar.
  • 2,072 Answers
Push up on the release latch on the Right Side Cover to open the cover
  1. CAUTION: Ensure the side cover is always open before opening the front cover.
  2. Open the Front Door.
    Turn the orange Toner locking lever up to unlock the Toner Cartridge.
    Pull the Toner Cartridge out of the machine.
  3. Remove the new Toner Cartridge from the box. Save the box and the packaging for storing the old cartridge.
  4. Gently shake the new cartridge horizontally 4 or 5 times to loosen the toner. Be careful of any Toner spill.
    NOTE: Shaking the cartridge will ensure maximum copies per cartridge.
  5. Slide the new cartridge into the machine until it locks in place
  6. Turn the Toner locking lever down until it locks in place.
    IF it is not sliding in. remove the cartridge and on the back of it, there is a round drive you may have to spin a quarter turn and reinsert. Sometimes that doesnt line up
Posted on May 19, 2008
Am getting error-toner cartridge is not compatible check users guide.even if i put a new toner
Cannot guess the reason unless you identify the brand / make / model of your printer.
Most new toners have an embedded chip to recognize if they are genuine to prevent refill of toner
Jun 08, 2016 | Office Equipment & Supplies
There is no toner when there is in the toner cartridge
replace the image unit for that color and replace the toner cartridge with oem cartridge
Jan 30, 2014 | Konica Minolta magicolor 2430 DL Laser...
Help with error code SC547-01
sc 547 mean fixing unit error ,you can reset by simply getting into simulation mode and then switch off an the machine ,getting into the simulation mode is simply by pressing 107 and press and hold c ,
Jun 19, 2013 | Ricoh Aficio 450 Copier
Replaced toner cartridges magenta, yellow cyan printer display now says replace cyan cart. i have reloaded and even put in the old one i even replaced the drum with the pevios one. same message
Hi Camru,
Can you tell me the exact model of Cyan toner you are using as there are two for this model a high and a low capacity one, and I also would like to know if you are using original brother branded toners or refill or aftermarket/non brother/"for use in toners". If you are using after market toners then the toner itself is probally faulty, these machines dont just sence new powder they look for a new chip to tell machine it has had its toner replaced, then the chip is blown so it cant reset the machine again, refillers have to put in a new chiop and powder if the chip they use fails then it doesn'r reset the machine, exactly like your problem.
If your are using brother branded original not refilled toners then we could have other issues so please then try the following. Please ensure the contacts on the drum and coresponding ones on the front door are clean. Gently tiny wipe metal wire contacts with a lint free cloth or a cotton bud with metho/alcohol, dont bend them they are delicate, see pic at end for location
Please also try to reset the toner manually, do this by openning front door and pressing clear/back button, a menu will appear, we want to select C-TNR-S or C-TNR-H depending on if you are using Cyan/TonerStandard or Cyan/Toner/High Capacity, so use arrows to go to correct one then press ok to select it, then a new menu appears, we want to select 1 asnd ok to reset, then it should just go back to cover open.
Also you could let me know what code comes up if you press menu * 2 8 6 and 4 real quick!!, if you do fast enough its tricky but then you should see maintence in display and it will beep, then select 82, and it will show eroor ?? let me know the code...also try to do a 80 it will print out a code sheet that I would normally read to identify problem, and finally in maintence mode select 99 to perform reset, you machine should go back to normal and out of service mode.
Hope this helps, or if required give me more detailed info and we will dig deeper.
Contact locations10_17_2011_2_10_25_am.jpgn
Oct 17, 2011 | Brother DCP-9040CN Laser Printer
Hi, I have kyocera km c850D. Please could you explain why machine keeps saying replace waste toner box although it is quite empty. please advise if tere are any other parts of the machine to clean or...
Are you using a new waste toner container or did you empty the one that was already in the machine?
The machine uses a sensor that looks at the container to determine if it is full of waste toner. If there is toner on the inside sides of the container were it looks for toner it will indicate that it needs to be replaced even if you have emptied the toner out.
It is a good practice to replace the waste toner container with a new one, that is the way the machine is meant to be used.
If you have correctly installed a new waste toner container and the message hasn't cleared you may have a faulty sensor.
I hope this information is helpful,
Jan 26, 2011 | Kyocera Mita (km-c850d) All-In-One Printer
What kind of tail light bulb do i need for 1984 buick lesabre its the first of the four on the passenger side closest to tire one of the right turn signals
Use the little machine at Walmart. You tell it your vehicle information and it will identify which bulbs are used with your vehicle.
Jul 30, 2010 | 1984 Buick LeSabre
E019As many as 50,000 have been made after detecting a waste toner full condition.Extract the block of the scene and free the container with perfected by toner. Good luck
Sep 20, 2009 | Canon NP 6085 Copier
Need to locate PC's on our network, accurate to the switch port.
If its not to many computers , tone out the lines with a network toner
Jul 06, 2009 | Cisco Catalyst 3750G-24T SMI...
Toner and Imaging Unit issues
If this IS a CLP-510, first make an information confirmation print.
Press MENU, then press ENTER, and ENTER again.
Look at the counter for the imaging unit, is it a low count confirming that you have indeed replaced it ?
If not you will need to reset the counter.
Check the counters for the toner cartridges, and check the capacity of the cartridge. On a CLP-510 the image counter for the toner is held on the chip on the cartridge (which also identifies the capacity of the cartridge).
There have been some faulty (oiginal Samsung chips), and of course re-manufactured cartridge chips could fail (many re-manufacturers don' test their cartridges before dispatch, they don't have the facility to do so without starting the count on the chip (or 'bowing' the reset fuse on a CLP-500 cartridge). VERY few re-manufacturers can test these cartridges without starting the count.
Sometimes the 'replace xxxxx toner' messages are caused by toner on the three contacts on the side of the cartridge, or their mating contacts inside the printer. Rarely, this can be caused by a faulty circuit board.
Dec 20, 2007 | Samsung CLP-510 Laser Printer
Samsung clp-510n printer
1 Could be toner on the contacts (inside the printer) that mate with the contacts on the cartrdige.
2 Are you sure they are 510 toners and not 500 ones ?? 510 toners have a chip that identifies the cartridge (Colour, Capacity) and maintains a count of the pages printed.
500 toners have a reset fuse that resets the toner counter in the printer, and a resitor that identifies the capacity
3 Are they new cartridges, remanufactured, or 'home refiled'.
if either of the later two, were the chips replaced ? - if not the cartridge still thinks it has printed its full life of pages.
Nov 28, 2007 | Samsung CLP-510 Laser Printer
Xerox FAXCENTRE 2218 18PPM FAX Logo
100 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
