Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
My model is 795-75542401 Bottom Freezer
I have a problem with water leaking in the freezer drawer. It's coming from
the back wall from what looks like vent panels. HELP
Ron. D
  • pavedrvr Jul 03, 2008
    I have the same problem. I was getting a build-up of up to 3/4 inch of ice on the bottom of the freezer in about 3 weeks time and then it would spill out when the freezer was opened. I tried checking the drain pipe and quick-defrosting of the freezer. I still have water that comes in a pretty steady trickle from the top inside corner of those vents, that then runs down the inside groove of the vents to the freezer floor. Any other suggestions.
  • kaza999 Jul 21, 2008
    I have a similar problem with water leaking - both in the freezer and also from the left door - it suddenly has gotten worse over the past week or so - specifically from the bottom of the left door. Any suggestions?
My freezer drain hose was plugged with small pieces of tempered glass which was causing the drain to back up into the freezer. With a small 1/4" socket,screwdriver I was able to get the drain hose off and clear the glass out. We did not have any broken shelves in the 8 years we have had this fridge so it is a mystery. Must have broke a shelf during production. As of this post I still need to defrost the freezer to make sure all is OK.
Posted on Aug 31, 2008
I had a problem simular to this but the water was coming from the ice maker. The valves were not closing all the way after it filled the tray for cubes it continued to drip enough to build an ice block in the bottom, on the back wall, in the ice tray. Replaced the water valves, problem solved. By the way I purchased my fridge from the outlet store with no warranty and this happed within 6 months of owning it.
Good Luck
Posted on Jul 14, 2008
  • 828 Answers
Sounds like the freezer drain is plugged. Behind the refrigerator is a removable panel which will give you access to the drain hose. Make sure any trap is free of any buildup. You will have to defrost the freezer section to clear the ice from the inside drain area. Make sure there is no paper or other things that may restrict the water from draining.
Posted on Jun 03, 2008
Water leaking inside my vegetable drawer
Just above the drawers is a drain hole on the back wall. Push a drinking straw or very thin brush down to unblock the drainhole and the water will drain away outside the rear into a pan on top of the compressor
Apr 30, 2014 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerator leaks alot of water from freezer area
Most of the time you have a clogged/frozen drain. If this is a freezer on top model, you need to remove the back wall or floor and defrost the drain with warm water or hair drier ... I find that warm water and a turkey baster works best.. just keep shooting the water down the drain hole until it takes the water down on its own. If the problem returns sometimes you will need to install a drain heater or conductor kit. If this is a side by side model the repair is about the same ..just remove the freezer back wall and melt the ice and flush the drain.
Mar 08, 2014 | Westinghouse Refrigerators
My Lg bottom freezer refrigerator, model # LFC21770ST leaks constantly down in the bottom of the freezer and comes out onto the floor. Ice dams build up under the freezer drawer. I take out the ice, but it...
The drain for the auto defrost water is plugged up somewhere.You will need to look at the very back and bottom inside the freezer to see if you can locate it and clean it out.Also you may have to pull the refrig out from the wall and try to get to it from the back.Hope this aleast gets you looking in the right direction.
Jun 29, 2011 | LG Bottom Freezer Refrigerator w/...
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Freezer leak, Ice inside the freezer (AMADA ARB220ZC)
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
Jul 08, 2010 | Amana ARB220ZC Bottom Freezer Refrigerator
My side by side GE is leaking water on the freezer side. It is coming in from bottom and water is freezing under the drawer.
You have a stopped up and or frozen defrost drain line. Pull the bottom drawer out and look for ice underneath the bottom of the back wall. This is where the drain hole is. Thaw this out and make sure that the drain hole is not blocked. Water should pour through this hole freely when it is working properly.
Jun 27, 2010 | Refrigerators
Water is leaking into shelf and bottom drawer
its in the freezer part open the back wall of your freezer and you see the hole that the ice should melt into.. if its clog then clean it with water pump....
Dec 30, 2009 | Refrigerators
Leaking by freezer door in bottom
your drain line is clogged remove back wall and trow hot water in hole please unplug unit
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
Water drains internally at back of freezer drawer
Check the drain.
Take the bottom drawer out of the freezer and look in the very back for a drain hole. It may be covered with ice. A hair dryer will melt the ice so you can unclog the drain.
Dec 30, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
229 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
