Question about Indesit W 123 Front Load Washer
Indesit w123 put dial to 4 it just goes round and stops. Is it worth cost wise to try and repair ?
  • Anonymous Mar 12, 2014
    ingest w123 dial turns round
  • 66 Answers
Not really worth replacing timer as many problems can cause this
Posted on Jun 15, 2008
Indesit w123. motor burnt out?
If your seeing flashes from behind the dial I'm thinking that the timer needs to be changed. Even with the motor shorted out, it still wouldn't cause that effect to happen.
Jun 17, 2012 | Indesit Door Handle Kit for W123, W133,...
I have a indesit w123 and when i put it on it starts to fill up and then the dial keeps going round, can you help please...
try and clear prog memory .what to do is set prog knob to an off position where the black spot is then switch on machine the red light will flash quickly then slow down. when it does switch machine off then select program and switch on and it should be ok.if not it could well be a main fault on pcb .indesit boards are not very good .hope this helps.
Jun 07, 2011 | Indesit W 123 Front Load Washer
My W123 machine programmer keeps going round
Unfortunately you'll have to replace the dial unit, or we can try to repair the dial gearbox. But you'll need some mechanical skills for that.
Update me about your decision and progress
Jul 22, 2009 | Washing Machines
W123 holding some water and dial keeps spinning around checked the filter all clear
may be a blockage in the sump hose or pump feed hose or the pump itself may be faulty. the dial will click round to tell you there is a fault. to reset turn the dial onto every DOT and turn on for 10 secs then off and onto the next dot it will flash for a couple of seconds to confirm.
Mar 17, 2009 | Indesit W 123 Front Load Washer
Dial keeps rotating
This a common problem with Indesit washers..
It is not a timer but a programme selector switch.
What you need to do is the following.
Switch the m/c on, let the drain pump empty the water, then switch the m/c off.
set the selector switch to one of the black dots on the dial, which is stop/reset.
Then switch washer back on, if the dial still keeps going round and round, then you are going to have to call an engineer, as you have what is called an Anomaly (fault).
Plz leave feedback for this solution.
Thanks
Dec 09, 2008 | Indesit W 123 Front Load Washer
Indesit W123 5 flashes error!!
The F05 fault means the pump is blocked, check the filter at the front bottom right of the machine behind the plinth and if its connected under a sink check the hose & connection
Nov 03, 2008 | Indesit W 123 Front Load Washer
My indesit washer/dryer model w10 ,is not working.the programme dial keeps cliking round wont start a programme or take in water.
probably a main module fault but worth while checking for continuity thro the heater and that the pump and filter are ok. the idea is that when a fault is detected, the dial will click round indicating a fault but usually it is the module itself. expensive part. not worth repair
Jul 04, 2008 | Indesit Washing Machines
Indesit w123 prog dial goes round but does not do anything else?
It's the motor brushes that are worn and taking down the neutral side of the circuit hence nothing else works !
May 19, 2008 | Washing Machines
Indesit w123 front load
would check pressure switch and the pipe that goes down to the drum for blockages if not may be faulty water valve unplug first regards jason
Apr 28, 2008 | Indesit W 123 Front Load Washer
Indesit W123 s UK water overflows from the detergent draw
My machine clicked round, although I did not have the water overflow. I managed to unlock the pump filter, on the front of the machine under the lower panel. This was fiddly. I removed a coin. The machine worked again, but two cycles later starting clicking round the timer. I called an engineer - it worked when he was here, he checked the element and pump and said it was OK. When he had gone, it clicked round the timer again! He came again, and once again it worked perfectly when he was here. Eventually I checked the pump filter again, and removed another two coins. At the moment - it is working!
Oct 11, 2006 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
239 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
neilmoto
Chris Hall
Chris Hall
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
