posted by drp5862 on May 19, 2008
Panasonic NN-P294SF, no dsiplay on keypad, no fan, no lights. Just walked by it yesterday and noticed. Power ok at box. Is there an internal fuse that could take out everthing?
Thanks
Dave
Best Solution
posted on May 22, 2008
Yes, there will be a fuse and also on or above the magnetron, there will be a thermal cutout or thermostat, and one on the top of the cavity.
But here is our long answer on a dead microwave:
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
prototech@usa.net
Rating Locked! (?) drp5862 has rated this solution as FixYa!
Suggest a new solution for this problem
Post a New problem for Panasonic NN-P294SF 1250 Watts
Email this problem
Email this problem
Can you Help with these Microwave Ovens problems?
Panasonic NN-P294SF 1250 Watts Microwave Oven
LCD display blinks & marks...
The LCD disply blinks with the... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
