Question about Car Audio & Video
Somebody attemted to install the radio and now it is draining the batery
    Novelist:
  • 170 Answers
You'll have to open the dash and get to the radio wiring for these solutions.
Solution #1: Sounds like the ACC lead (yellow) and the Power lead (red) are both connected to the same power wire.
If the radio is able to be turned on and played while the vehicle is off and the key is out, then both of these leads have been wired together. That's bad. There are two different leads for this...one is for power when the vehicle is turned on to operate the radio/CD, and the other is a trickle to keep station presets, personal settings, and clock accurate.
These wires need to be separated.
Solution #2: It is possible that the ground wire was not connected correctly and needs to be connected securely to the ground wire. Does the unit get hot? If so, there may be a grounding issue that needs to be taken care of or run the risk of damage to the radio and possible the vehicle.
Solution #3: Inspect the wiring job. Are the wires twisted in-line or are they twisted and poking up like small antennas? Are they wraped securely with tape? Were thread nuts used (very bad)? Are there any exposed wires at all that you can see in the wiring job? Any exposed wires can cause shorts in your electrical system and drain your battery. You will need to get some electrical tape, shrink tube, or in-line wire clamps for the job.
For all of these solutions you will need to get a wiring diagram for the car, the radio, and the wiring harness that was used. Trace all the leads and make sure they are all correct. Usually you will see them in two blocks, one for power and the other for speakers.
Power: Red (positive charge), Yellow (AAC), Black (Ground/Negative power). You can also find a dimmer lead and a power antenna lead here. If you don't have these capabilities in the vehicle, cap and ignore these.
Speakers: There will be a solid color for one wire (the positive) and the same color with a stripe (negative) for each speaker.
Most systems will print the positive/negative and which speaker they go to on the wires themselves.
Be sure to thank the "somebody" for this stellar install job. I hope you find the problem and get it worked out.
Posted on May 19, 2008
My daihatsus batery ceeps on running flat i charge it and 2days later its flat bouget a new batery still thasame thing kaas on going flat
If the alternator is charging correctly then you have something that is draining the battery when turned off! The usual causes are a glovebox or boot light staying on! Check these lights are not staying on!
Jan 04, 2015 | Daihatsu Charade Cars & Trucks
Front windows wont roll up after battery drain.
Hi Mathew I need a bit more information to be able to help you ! It should not matter about the code the radio has nothing to do with the front windows unless somebody has wired it incorrectly ! Draining the battery down should not affect the windows once power is restored
Apr 11, 2014 | 1994 Land Rover Range Rover County
Bought a new radio and had somebody put it in .it started to drain my battery down,now i need a boost off every time i get ready to go so i just got a boost off and now my car will not go forward .i...
the park ave wiring is really easy to screw up when you install an after market radio,
i would have the radio taken out and disconnected and then see if the car goes forwards
also check all of your fuses in the 2 fuse boxes under the hood and the one under the dash and see if he blew any when installing the radio
Sep 19, 2011 | 1999 Buick Park Avenue
Hi, we have a 2004 TD5 and somebody attemted to open the back door whilst locked, then the card was locked, unlocked on the key and the back door will not now open. When locking and unlucking the...
probally a broken spring in door lock if you hold the lock up from the inside while somebody opens from outside it should if you let go and they cant open it ,its the sping broken
Jan 30, 2011 | 2002 Land Rover Discovery Series II
Had dead battery in 2002 honda civic got jump now word CODE in radio display
try disconecting the positive terminal of the batery for sevral minets (5-10) this will reset the brain box memory for the stero aswell as for the car it self.
what caused the batery to go dead in the first place?
things that i can think of :
1) left headlights on over night
2) bad altenator not charging batery
3) battery is old and not taking a charge anymore
4) new stero installed incorectly and drainging the batery
have you resently installed a new stero or amplifyer?
is the turn key igntion system hooked into the amp/stero antena lead so that thy are shut of when the ignition is?
of note: new streo >theres a blue wire marked ant that goes to the amplifyer if not there you need to find the orange accsesory wire coming from the turn key igntion>check for power when ignition is in the on & off states could be yellow in some cars but is usaly orange if this wire has on and of state controled by the turn key igntion this would be the wire to tap into for the amplyfire and the radio main power
check your radio's instaltion guide for code errors
its posible that when hooking up the jump it was done incorectly and blew up the radio
ie postive and negative where fliped
hope this helped :)
Feb 24, 2010 | 2002 Honda Civic
Radio controls inop .2008 mini cooper. radio got wet in a rain storm now the controls are inop. cd plays but wont eject.
elctrionics and water dont mix u need new radio
u might get lucky and be able to take radio out and blow compressed air into the vents of the radio in attemt to dry it out and make it work have 50/50 chance that work
Feb 09, 2010 | 2003 Mini Cooper
I need to know how to wire rk 56 mics for cobra,uniden and galaxy radios?
Thank You for your responce but I have already solved the problem by way of trial and error! It took me several attemts but I got the job done.
Apr 17, 2009 | Magnum DeltaForce CB Radio
ICOM IC-F11
Bad battery, Buy new one on ebay. Carl
May 17, 2007 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
