Question about Syntax SVX400 (SYSVX400) Motherboard
Motherboard Hello all I have a P4SVX400 motherboard for a 2.8 Ghz Intel - 184 pin memory. I tried to install a vid card and I think I ruined it cause no picture would show up. I tried the other vid card that had worked and nothing came into the screen, I took it into the shop and they said thawt the motherboard was not working. Should I get a new board? What model would work with what I need . I am having a hard time finding it- or should i get the board repaired thanks
  • 37 Answers
New motherboards cost like 35 pounds, so repair is out of the question, when replacement will give you up to date technology, and much more features.
I can see your motherboard supports only 'AGP' video cards, which are both older, of lower performance, and quite often more expensive. If you choose to upgrade your motherboard, choose one with 'PCI-Express' video card capability.
In addittion, your board supports only Intel Socket 478 CPU's, these are beginning to show their age in performance terms now, so I'd suggest you consider a CPU & Motherboard bundle, which saves you money, and you can even get one that can use your old DDR memory from the other motherboard.
As a video card choice, there is only ATI, and Nvidia chips out there, so if ATI, you need at least an X1900 series or better, if Nvidia, you need at least an 8700 GT series or better.
Good luck.
Posted on May 19, 2008
184-pin DIMM sockets support up to 2GB
system memory using unbuffered non-ECC PC2100
Aug 02, 2013 | ASUS P4VP-MX Motherboard
Tried to upgrade my ram modules from 512 to 2gb. also installed a new video card (for a moment... but then removed it when the problem occured). now when i power up, i get a steady...
what type of ram did you upgrade with it should have been DDR and keep the same brand/type of ram modules the same check the ram sockets make sure they are clean and the ram is securely seated The ram modules should have either of these 2 the same 1 GB 184-pin DIMM DDR PC 2700 memory module 1 GB 184-pin DIMM DDR PC 3200 memory module
Jul 01, 2011 | EliteGroup 661FX-M7 (661FXM7V11)...
  1. Memory Type:DDR266( PC2100) 184 pin (2.5v)
  2. 2 x DIMM
  3. Max capacity: Up to 2 GB
Expansion Slots
  1. 3 x PCI (PCI 2.2 compliant)
  2. You can only used PCI graphic card not PCIE Graphic card
  3. PCI graphic card is hard to find now but you can try to find at any computer surplus shop
May 22, 2011 | Intel Motherboard
Ram support for intel 845 motherboard
Hello. this website will show you the supported RAM for your Motherboard.
RAM Support
Hope this helps!
Apr 11, 2011 | Intel D845EPI (INTELKD845EPILPAK10)...
Memory installation
Most likely, it is a limitation of your motherboard. Not all motherboards or computers can physically read all types of memory or they may have memory limitations. For instance, I was working on an older Gateway this week. It had 2 memory slots but the maximum amount of memory the computer would recognize is 512 MB. Therefore, if I had put to 1 GB sticks in, provided the computer could use it, the maximum the computer would be able to see or use is 512 MB. In this instance, that is most likely the scenario. The best thing to do is to go to and run the system scanner. It will tell you how many slots you have, what the maximum per slot capacity and the total capacity of your computer is.
Thanks and please take a moment to rate as fixya.
Nov 06, 2008 | Intel Motherboard
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
Increasing Memory Ram
According to the memory configurator at your motherboard has two RAM slots that can handle one gig of PC2700 RAM each.
Look here for more information.
Aug 28, 2008 | Intel Motherboard
Regarding upgrading RAM
You'll need 184-pin ddr sdram memory
Supported speeds are 333, 266, and 200 mhz
Max memory for your motherboard is 2 gb, so the best you can get for your motherboard is:
2 x 1GB 333mhz 184-pin DDR SDRAM
May 21, 2008 | Intel D845GVSR Motherboard
Critical after DDR333 upgrade
I got your latest version (8.1) motherboard on my screen & ECS shows your board does not support PC2700, only PC2100.
Downloaded your manual to verify this.
Notice you started having problems after upgrading RAM.
Link to your manual:
This motherboard accommodates two 184-pin DDR DIMM
sockets for up to 1GB memory. Supports PC2100/PC1600
unbuffered non-ECC DDR DIMMs.|c:147|&Sort=0&Recs=10
Good Luck!
Mar 18, 2008 | EliteGroup P4VMM2 Motherboard
Intel ASUS P4 845 GL Motherboard
Hi, For an ASUS P4BGL-VM Intel 845GL Chipset Ultra ATA100 MATX CPU Type: Intel Pentium 4 478-Pin (OEM), the Asus site specifies max of 2 x 184-pin DIMM Sockets support max. 2GB PC2100 / PC1600 non-ECC DDR or SDRAM memory but not "and". Personally, I find it more practical to install 2 X 1Gb rather than a single 2Gb. Hope this gives you some idea. Kind regards.
Aug 07, 2007 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
Syntax SVX400 (SYSVX400) Motherboard Logo
198 people viewed this question
Top Syntax Computers & Internet Experts
Roy May
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
