Question about RCA D52W19 52" Rear Projection Television
Rca 52" hdtv
I'm having problems with the picture color. There is absolutely no red and there is a blue ghost ring that seems to get smaller everyday, giving you somewhat of a tunnel vision affect. I had a repair man come out to check it out and he told me that the red projector is shot because it's leaking some sort off clear fluid and the blue projector is leaking as well. He said that's the reason for the blue ghost ring and eventually the picture will go out completely. He also said it would cost $700 to repair to replace the two projectors. Is he correct or do I have another less expensive repair option?
    Genius:
  • 1,030 Answers
Unfortunatey that diagnoses sounds correct. sorry when the "glycol leaks " it cause all sorts of damage. in theses sets the tubes cost about 250 a peice. plus very labor entensive to replace. these "value" sets cost about 800 new at your local walmart.
Posted on May 19, 2008
Converge off a little and screen has green tint
If you have the remote, go to the setup screen and move the picture. Converge has nothing to do with where the picture sits but, where the red, blue & green dots land. All you should see are pure white dots. There should be absolutely NO color ghost anywhere on the screen. If so, you need a bar / dot generator to set the convergence to center the dots.
Jan 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Apparent green tube/bulb failure on RCA D52W20
I THINK IT MIGHT BE YOR CONVERSION CHIPS IT COST AROUND 200 TO 250 DOLLARS TO GET IT DONE
Dec 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52'' Projection HDTV Blue ''ghosting''
Go to menu ,now go to setup see if convergence is on menu if not then fuse FL231 is opened 0.6 amps it is located on right side of flyback transfomer the fuse in the middle they look like small square capacitors brown there is 3 in a roll.
Dec 11, 2008 | Televison & Video
THE RED, BLUE, AND YELLOW COLORS SEPERATED ON A 52 IN HDTV. THE PICTURE SEEMS TO HAVE A GHOSTING EFFECT TO IT
Have you used the color convergence settings on your TV?When the settings are off you will get this effect sometimes if the TV was jarred pretty hard it goes out of alignment.There should be a setting on your menu.If that doesn't help it may need re aligned by a repairman.
Aug 10, 2008 | RCA Televison & Video
Ghosting in red ,blue & green
Sounds like an allinment problem with the color projection you can allin yourself via small screws on color tubes in rear. but be careful as tv needs to be on to do it.
Jul 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture Color
http://www.partstore.com/ModelDetai...close=1&exact=1
What do you think "CRT ASSY, Projection: Blue" might be?
CRT ASSY, PROJECTION: BLUE
RCA Part Number: 258486
RCA Model: D52W20
52" CRT BLUE P16LTG00BMB, DELTA 250
They want $183,
Jan 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
51 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
