Question about Whirlpool GEW9250 Electric Dryer
Dryer controll panell wont work but light inside does
  • 3 more comments
  • herrsiegrist May 22, 2008
    My Whirlpool Duet has absolutely no power...on the panel or inside the drum for the light. I've: reset the breaker, checked for excess lint, unplugged and replugged the unit, checked the power cords connections on the inside. Should I check the thermo fuse next?
    Alex
  • Anonymous May 27, 2008
    Yes the control panel has conrol locked lit up. There is power because the inside light comes on when the door is open. Help,,,,,,
  • Anonymous May 28, 2008
    at times there is no power then later the power comes on and the dryer will run, then it will quit and display a PF power failure! I have checked my breaker it is not tripped nor have we had a power outage, I have also checked at the outlet and I am getting a 240 supply, is there a sensor or isoverheating in the motor taking place? any suggestions
  • launjanae Aug 13, 2008
    my drier wont come on i keep holding the end of cycle signal for a couple seconds but nothing the light on the inside is on and the control locked light is on but dim
  • HRodriguez Feb 16, 2009
    We have a Whirlpool Duet, Model # GEW9250 PW1.  The control panel power appears to be intermittent, and has been happening for a couple of years already.  The normal fix in the past was to disconnect power at the power cord and reconnect.
    Our dryer has been powered off for a few days.  The last load done was a heavy load.  The light in the dryer is out, but I believe that this is a bad bulb.  I have verified that the circuit breakers are not tripped, that there is power to the dryer control board, and have reset the connectors at the control board.  I have not been able to verify that there is 5 volts at the control board, or that the 5 volts is getting to the front panel board.  We bought our dryer on the year 2006.  Could it be possible that there is a bad batch of control panel boards that have been installed during a certain time period?  I have not been able to fid a concrete solution for this intermittent problem.  I would greatly appreciate any help on this problem.
    Thanks
Light on the inside of dryer comes on but the outside panel lights do not come on to be able to get the dryer to start
Posted on Aug 10, 2008
  • 27 Answers
Sometimes the control knobs that you set your dryer to different heating sets will go bad but it is in the control panel some where i whould say it is the heating setting
Posted on Jun 29, 2008
5 Suggested Answers
  • 262 Answers
SOURCE: Maytag Neptune Dryer
is the drum light on while the door is closed?? look on the teck sheet found in the lower front panel for a wiring diagram momery servers me there is a thermal fuse chances are this is bad if you cant find this tech sheet I will look in my invoice book and see if I can find the sheet for it good luck let me know what you find out
Posted on Jan 17, 2008
SearsTechToo
  • 261 Answers
SOURCE: control panel does not work
This is a process so right down everything, remove the 3 screws on the rear of the dryer for the top panel. Be sure you unplug the machine first before attempting this as high voltage is present. The front user panel is clipped to the chassis and we need to check two items. First the wire harness from the motor control unit to the panel and how well is the board attached to the panel. Look inside and you will see catchs bottom and top, with carefull lifting up and out the top loosens and then the bottom. We want to check the assembly and how well the wires are attached. If all looks sound unplug the board from the motor control unit and replug the unit. Now reattach to the chassis, make sure all is clear of the top and plug it in. Try to power up the unit, if not the panel is dead.
From when you mentioned the dryer light worked I know power is there for the board but I will not say off hand just buy a board, test always look for loose panels and wires then we go broke buying the part. Last is the machine new? If less than a year call sears, 1800for my home and have them fix it!
Posted on Sep 12, 2008
  • 659 Answers
SOURCE: Maytag electric dryer MDET446AYW no lights on
There should be a wiring diagram located where the electronics are in an envelope. Check for a fuse to the control board. Sometimes the fuse doesn't look like an ordinary fuse that we typically see on cars and things like that. It will appear to look more like a resistor. You need a volt meter to check if there isn't an obvious fuse on the control board.
Posted on Apr 18, 2009
ginko
  • 19396 Answers
SOURCE: Whirpool GGw9250Pw3 no power on Control Panel Inside light works
Hi.
Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool dryers and washers.
The front light lit on my Whirlpool.
Regards.
Posted on Feb 22, 2010
Front panel wont light up, why?
I have the same issue. Dryer lights when door is opened, but no panel display, and no function.
Jul 26, 2014 | Kenmore Elite HE4 Electric Dryer
Thermal fuse location
It's not a thermal fuse..You're getting power so issue is either the board or the fuse inside the board..that's what you should be looking at..All switches are mainly for safety
Mar 16, 2014 | GE Profile Harmony DPGT750EC Electric...
Lights on control panel wont go off
Very likely the unit is fried. Start with a electrical tester and go to town inside the back and the bottom of the machine. Also, before you even do that, check the current at the dryer plug. The two hot wires or for 1) the motor and controls, and for 2) the heating elelent. Then check the wire/cord connection at the rear of the machine with the tester. I've been doing this a long time, and my suspicion would be the timer is toasted. The timer is really sensitive to power surges. If not, do the motor.
Most dryers have a wiring schematic on a piece of paper inside the rear of the control panel to help you pinpoint the problem.
Be blessed.
Jun 20, 2013 | Kenmore Dryers
How do i remove the control panel cover to see why the control lights wont come on? the inside light works and the breakers are not thrown so i checked the door switch and it clicks when i push it so i am...
UNPLUG UNIT remove three screws in back of dryer holding top, from in front of machine slide top to back of unit to remove, now you will see secrews securing panel to unit also two secrews come from inside unit to the front after these 4 screws lift user innerface panel straight up..
Now after that ck for connectors loose or unpluged hopefully, if not your going to need the tech sheet and a elec . meter to test system
Aug 06, 2010 | Whirlpool GEW9250 Electric Dryer
Kenmore Dryer light comes on but control panel not operating
Your thermal-fuse is located on the back side of the bulkhead upper right hand cornerb68bc9a.jpg
Electrolux family of dryers newer models Dryer Service manual
I have repair photos and more HERE
Jun 15, 2010 | Dryers
Dryer wont run but lights are on
check the door switch.or you may need to replce the main control panel. but you also need to check the thermal fuses inside the dryer cabinet,one of those can be bad.
Sep 26, 2009 | Frigidaire Electric Dryer
Dryer control panel wont light up and told I need a new panel
You can buy the control board yourself for about $200 and install it yourself. It could be a fuse inside that had blown too, Email me at buffalonymann@yahoo.com if you have any questions
Aug 31, 2009 | Kenmore Elite HE4 Electric Dryer
Control pannel wont cut on and dryer wont start
We are having the same problem. We have the Neptune dryer MDE5500AYZ. The control panel doesn't come on. We know it's getting electricity as the light in the dryer is on. Is there a reset button in the dryer?
May 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
No power
check the door switches
Apr 28, 2008 | Whirlpool GEW9868K Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
307 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
