Question about Kenmore 24032\24036 Top Load Washer
Kenmore 24032 washer
I just changed the coupler in my washer and now that i have put it back together the water will not stop filling on the small setting.
  • 1 more comment
  • gary lee kim May 19, 2008
    the water just keeps filling on the small setting but it stops on all the other settings.....also i already checked the hose that goes to the pressure switch and it's fine.
  • Anonymous Mar 02, 2009
    it doesn't matter where the switch is set, the water just keeps running till it eventually overflows.. it never stops when full
  • robert samples May 11, 2010
    does the washer run over or just keep filling and how does it do on the other fill settings
    President:
  • 1,314 Answers
I would advise replacing the fill switch then any of the three settings could be out of calibration making the switch need replacing
Posted on May 21, 2008
    Genius:
  • 1,073 Answers
When you reassembled the case you have pinched the clear tube that goes to the water pressure switch aginst the case and back panel, lift up the console remove the case clips and make sure that the pressure hose comes up through the curve part in the case if pinched off the pressure switch will not satisfy
let me know if you need any more help
Posted on May 19, 2008
I just replaced the motor to transmission coupler now the washer won't stop filling with water.
check the wiring as i think you have not replaced the water sensor wires two little small wires on a little plug.adrian,,,
Dec 03, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
WATER FILLS WONT SHUT OFF
The pressure swith (load size) is what controls that chang that. A small hose runs from the bottom of your tub and as the water fills a measerd amount of water fills that tube and pressure build up in their operates that switch and activates the timer to stop filling and start agitating.
Jun 06, 2010 | Kenmore 24032\24036 Top Load Washer
My kenmore 70 series washer filled up with water and then stopped. It will not drain or do anything. Is there a way to troubleshoot or do you know what I need to change.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If the washer does nothing after filling, I'd try it on a different cycle.
If it works on another cycle, the problem points to the timer itself.
If you can hear the motor trying to run but the washer will neither agitate nor spin, the problem points initially to a Motor Coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission. It's used as a fail safe device and consists of three parts. Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Oct 31, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer hums during spin cycle
Either the bearings are frozen, or motor is weakening and has hard turning belt and tub/agitiator
Sep 15, 2009 | Kenmore 24032\24036 Top Load Washer
The washer (Kenmore Top Loader Model# 24642300)
It most likely is the coupler. It is located between the motor and the transmission. It is an easy repair and only costs around 20 dollars. To change it out simply unplug the washer and tip it back so you can work under it. The first thing you will see is the pump. Take off the two clamps with a flat head screw driver and move it to the side. Do not take off the hoses unless you want water everywhere. Next you will see the motor. The motor is held up by two clamps. The clamps have 2 screws in each one. Remove the screws and with your flat head pop off the clamps. Make sure you hold the motor cause when you take off that first clamp the motor will drop. The motor coupling will come off with it. Put your new one on, (it only goes on one way) and put everything back together again. You will be up and running good as new in no time again. Let me know if you have any other questions and let me know if this was helpful. Good luck and glad to help.
Jan 17, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Washer leaks after installing new lid switch
Glad this was taken care of. I'm just closing out some old tickets here.
May 18, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore heavy duty 70 series model 82763110
set the load size to small, fill with water.
now after it fills with water do you hear anything? motor noise?
If you hear motor noise, it probably has a broken motor coupler.
if it doesnt do anything I would look at the lid switch and activator, the lid has to close and the switch has to know it closed. did the tab on the lid break off?
May 03, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
78 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
