Question about Protron PLTV-32 Television
PLTV-32CM THE REMOTE HAS NO CONTROL ON TV THE BUTTONS ON TOP OF TV WILL RUN THE TV THE BATTERY ARE GOOD
HELP ME
  • hammerhead10 Jun 14, 2008
    exact same problem
Remote not working...turned t v on with it and then it stopped working...where can I get replacement??
Posted on Sep 26, 2008
Have protron pltv-32cm. model lt32c1m1. how do i shut off the v-chip block? i don't have the password.
Hello, there is a default password, if you source is in component 2 it can't be used here are some links to the pdf file pltv types.
V-Chip Lock When turned on, blocks access to mature television and movie content, based on the MPAA and TV PG ratings selected below, unless the viewer enters a password (set below). Set Password Sets the V-Chip password. To change the password, enter the current password followed by the new password. The factory-default password is '1234'.
PROTRON PLTV 32C User Manual Parental Controls
hope this can help.
Feb 21, 2015 | Protron PLTV-32 Television
Protron pltv-32cm
this may be due to misalignment.. else some problem in covergence/..
Mar 31, 2008 | Protron PLTV-32 Television
The buttons on the top of our television has quit working and the remote has too. We cannot turn it off or on or the volume up or down and cannot go to the DVD player. We have no code to use to put it in...
There may be an issue with the tuner itself because the remote and the buttons no longer work. You can try a method of programming called a powerscan the steps are below:
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Apr 12, 2011 | Protron PLTV-26 26 in. HD-Ready LCD...
Have a protron pltc-26 and the remote qiut working put in fresh batteries but will not turn on tv
The remote control is dead or the remote CPU chip that control all functions is dying and only some of functions buttons will work,some wouldn't anymore or the rubber insulater between the rubber buttons and the remote circuitry board are worn out and make no more contact.Can u take the remote aparts?Yes.Check all the rubber butttons insulater see if they're still good.Tries clean the remote PC circutries board with some rubbing alchahol also the battery - + connections too.Wait like about 20 mins for the rubbing alchahol to completely dries.Putting it back together again an putting in new batteries,the remote control might work again.If not have same result.Try website like Remotes.com to buy an original or very close compatible remote for a replacement.
Mar 23, 2011 | Protron PLTV-26 26 in. HD-Ready LCD...
I have a PLTV-32CM flat screen TV that I purchased new in 2006. I want to mount it on the wall now and I have a wall mount that I purchased at the same time but never used. When I went to put it on, it...
Yes, it can be mounted on the wall mount bracket system. You may not have bought the universal adjustable mounting bracket type to match the VESA mounting dimension (the four monting holes spacing measured in mm).
See example here:
http://www.affordablehdtv.com/advanced_search_result.php?osCsid=3q5p8vevt3jbjuj19qc2mu4rr1&keywords=pltv-32&x=25&y=9
Please leave rating if it helps.
Jan 20, 2011 | Protron PLTV-32 Television
CAN NOT FINDE PARTS
The coompany that produced this TV are out of business, so parts are not in any great supply. Try partsonline com
Thyanks for using fixya
Sep 22, 2009 | Protron PLTV-32 Television
Digital or not????
You can get the owner's manual at;
http://www.bottomlinelcds.com/manuals/PLTV-32CM-owners-manual.pdf
You need a converter box.
Specifications
General
Dimensions
33.07"W × 25.83"H × 9.09"D
Weight 45.54lbs
Panel Type Active Matrix TFT LCD
Screen Size 32" widescreen (16:9)
Color Range 24 bits (16.7 million colors)
Max. Resolution 1366 × 768
Pixel Pitch 0.51075mm (H) × 0.51075mm (V)
Sync Range Horizontal: 30–80kHz
Vertical: 50–85Hz
Contrast Ratio 800:1
Brightness 500 cd/m2
Viewing Angle Vertical: +/–85°
Horizontal: +/–85°
Response Time 16ms typical
Inputs 2 × progressive scan component video (RCA)
3 × composite video (RCA)
1 × S-Video
6 × stereo audio (RCA)
1 × SVGA (15-pin D-Sub)
1 × stereo audio line in, 0 dBV nominal (1/8" TRS)
Outputs 1 x composite video (RCA)
1 × stereo audio (RCA)
1 × subwoofer (RCA)
1 × headphone (1/8" TRS)
Video Formats Supported SDTV: 480i
EDTV: 480p
HDTV: 720p, 1080i
TV Tuner NTSC-M, CATV, 181 channels
TV Audio Mono, Stereo, SAP
Parental Controls V-Chip (TV PG, MPAA)
Picture-In-Picture PIP, PBP
Closed Captioning CC1–4, TEXT1–4
Speakers 2 × 10W
Plug and Play Compliance VESA DDC1, DDC2B
Power Supply 100–240VAC, 50–60Hz
Power Consumption Operation: 232W
Standby: <3W
Storage Temperature 0 to 60°C
Operating Temperature 5 to 35°C
Apr 08, 2009 | Protron PLTV-32 Television
Needs New LCD Panel
I have a screen but need the vga card if you want to contact will sell for 300
Sep 05, 2008 | Protron PLTV-32 Television
Sound/ no picture
Can't really help you with getting sound out of the tv speakers, but you may be able to use the audio outputs from the TV to a receiver as a work-around.
Nov 15, 2007 | Protron PLTV-32 Television
Protron PLTV-32 Television Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
