Question about Logitech Cordless Mouse
Mx 610 Receiver Part 831417
Broke the 2.4 ghz transmitter. need replacement
  • kwp217 Jul 11, 2008
    I also broke the receiver for my Mx 610 mouse and need replacement. Was unable to find it on Logitech website.
I also broke mine (tip for diary "don't walk round house with reciever plugged into side of laptop as it hits door-frames and breaks!) so rang Logitech customer services and they have said they will send replacement free of charge if they have them in stock - even though this is not a warranty covered problem. That's what i call v.good customer service, well done Logitech.
Jon B.
Posted on Sep 04, 2008
Does anyone have an installation manual for an Autopage RS-610 Plus? I need to program a new remote.
Note: This system can keep up to 4 remote transmitter in its memory. If
more than 4 transmitters programmed, the system will keep only the last
4 transmitters.
PROGRAMMING THE REMOTE TRANSMITTER
Enter:
1. Turn the Ignition 'switch 'OFF/ON' 3 TIMES and stay in the 'ON'
position. Within 15 seconds.
2. Push the Valet switch 2 times (Holding in on the 2nd push) until you
hear a long chirp. The transmitter is ready to program.
Program:
1. Press any button on transmitter until the siren responds with a
confirming chirp the first transmitter is now programmed.
2. Press button on the second transmitter until the siren responds with a
confirming chirp, the second transmitter is now programmed.
3. Apply the same procedure to program 3rd and 4th .
Exit: Turn Ignition to 'OFF' position, or leave it for 15 seconds. A 3 long
chirps & 3 parking light flashes to confirm exit.
Apr 12, 2017 | Autopage Vehicle Parts & Accessories
Tip
Genie Intellicode Remote Transmitter Programming Instructions
USE ONLY WITH SERIES II ELECTRONICS.<br /> Older Transmitters and Receivers will not work with these new electronics. There are no Security Code Switches inside the Door Operators, Transmitters and Receivers.<br /> <br /> <br /> To Program Receiver <br /> Step 2-1 Locate the Learn Code Button and Radio Signal Indicator on the Power Head Receiver of your Door Operator.<br /> <br /> Step 2-2 Press a Transmitter Button once within 30 seconds.<br /> <br /> Step 2-3 Press and release the Learn Code Button<br /> &bull; The Radio Signal Indicator will blink approximately 2 times per second.<br /> &bull; The Radio Signal Indicator stays lit - SOLID.<br /> <br /> Step 2-4 Press the same Transmitter Button within 30 seconds.<br /> &bull; Radio Signal Indicator will go out.<br /> <br /> NOTE: If a second Transmitter Code is not confirmed within 30 seconds or if a different Transmitter Code is sent, the Radio Signal Indicator will blink approximately 4 times per second, then programming will stop. If programming stops, repeat Steps 2-2 through 2-4.<br /> <br /> Step 2-5 Repeat Steps 2-2 through Step 2-4 for each Transmitter, Wireless Keypad or other access device to be learned.<br /> <br /> NOTE: A maximum of 7 Transmitter, Wireless Keypad and other access device Codes can be stored into Receiver Memory at one time. If a Transmitter becomes lost or if you want to delete a Transmitter, Wireless Keypad or other access device, proceed to ERASING ALL RECEIVER MEMORY.<br /> <br /> <span style="font-weight: bold;">Multi-Button Transmitters</span><br /> <br /> NOTE: Only ONE button of a Multi-Button Transmitter can be programmed into a single Receiver. The other buttons are to control other Door Operators.<br /> <br /> NOTE: If you are replacing a lost or stolen Transmitter:(1) Erase ALL Transmitter Codes from the Receiver memory. (2) Reprogram the Receiver with the remaining Transmitters Codes.<br /> <br /> <span style="font-weight: bold;">Erasing All Receiver Memory</span><br /> <br /> Step 4-1 Press and HOLD the Learn Code Button for 10 seconds or until Radio Signal Indicator goes out.<br /> <br /> <span style="font-weight: bold;">ALL Transmitter Codes are erased from Receiver memory.</span><br style="font-weight: bold;" /> <br /> Step 4-2 Reprogram the Receiver with the remaining Transmitter Codes (Repeat Steps 2-2 through 2-4).<br /> <br /> <span style="font-weight: bold;">Step 5-1 Battery replacement</span><br /> &bull; Slide Battery Cover off of Transmitter back.<br /> &bull; Replace with new batteries.<br /> &bull; Slide Battery Cover back on.<br /> <span style="font-weight: bold;"><br /> Step 5-2 Visor Clip installation</span><br /> &bull; Slide Visor Clip into back of transmitter until it snaps into<br /> place.
on Jun 21, 2011 | Genie Company IntelliCode GICT390-1BL...
Erratic mouse movement
the mouse battery is getting low on juice, or the mouse may have short in the wire if you have wired device, the mouse maybe getting ready to dye.
you could go into the control panel open up mouse folder check all the settings and you have the right boxes checked of your needs and wheel adjustment is set low.
if you have usb with transmitter make sure the mouse is in sight of transmitter and you could try sync them by pushing the button on the bottom of mouse ( any color} and pust the transmitter button at the same time and reboot the computer
i hope that helps
thank you rod
Mar 05, 2015 | Logitech MX 610 Cordless Laser Mouse...
Skytech 1410 fireplace remote (8 yrs. old) has stopped working. Replaced batteries in the transmitter. The red light lights up when
It may need to be re-synchronized:
Make sure the receiver's slide switch is in the REMOTE position.
Press and release the LEARN button on the receiver.
When you hear the "Beep", press and hold the ON or OFF button for about 2 seconds on the transmitter.
You will then hear a series of beeps that indicate that your new transmitter has been accepted by the receiver.
If you press the LEARN button on the receiver and you hear no beeps, the receiver is unable to retain any more transmitter codes
(make sure the transmitter battery is properly installed and fully charged).
To delete all of the transmitter codes on your receiver, press and hold the LEARN button for 10 seconds. Then you will hear a
series of beeps, indicating that the receiver's memory has been cleared.
It could also be dead after 8 years. A new unit can be purchased here: Skytech Remotes. I would even suggest on of the new styles with a built in timer or thermostat.
Nov 08, 2012 | Skytech 1001-A Fireplace Remote Control...
I am looking for a baby monitor with 2 transmitters and one receiver . i have not seen such a thing. i am willing to buy 2 baby monitors if either receiver will 'communicate' with either transmitter. ...
There are MANY products available that will suit your needs, begin your search HERE.
MORE
MORE
If more options are needed search your favorite search engine with the phrase:
"Multi Room Baby Monitor"
May 05, 2011 | Graco Direct Connect Monitor
Netgear wndr3400 is only pushing 2.4 instead of 5.0, my laptop and ps3 won't even pick the 5.0 up, Can anybody help?
PS3 does not have a 5.0 ghz network card so it will only see the 2.4. I suspect your laptop also lacks the hardware for 5.0 ghz.
Dec 10, 2010 | NetGear WNDR3400 N600 Wireless Dual Band...
I have a 2001 Accord and if I hit the unlock button and do not open any door within a certain amount of time (2-5 minutes) it automatically re-locks it. Is there a setting I can change to prevent this...
Hope the following procedures helps.
TRANSMITTER TEST
NOTE:
If the doors unlock or lock with the transmitter, but the LED on the transmitter does not come on, the LED is faulty; replace the transmitter.
If any door is open, you cannot lock or unlock the door with the transmitter.
If you unlocked the doors with the transmitter, but do not open any of the doors within 30 seconds, the doors relock automatically. ?
The doors do not lock or unlock with the transmitter if the ignition key is inserted in the ignition switch.
1. Press the lock or unlock button 5 or 6 times to reset the transmitter.
If the locks work, the transmitter is OK.
If the locks don't work, go to step 2.
2. Open the transmitter and check for water damage.
If you find any water damage, replace the transmitter.
If there is no water damage, go to step 3.
3. Replace the transmitter battery (A) with a new one, and try to lock and unlock the doors with the transmitter by pressing the lock or unlock button 5 or 6 times.
If the doors lock and unlock, the transmitter is OK.
If the doors don't lock and unlock, go to step 4.
NOTE: The transmitters for LX models and EX models are different and are not interchangeable.
4. Reprogram the transmitter, then try to lock and unlock the doors (see Transmitter Programming ).
If the doors don't lock and unlock, replace the transmitter.
TRANSMITTER PROGRAMMING
Storing transmitter codes:
The codes of up to three transmitters can be read into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps.
1. Turn the ignition switch ON (II).
2. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (II).
5. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 4 sec., turn the ignition switch ON (II).
8. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 4 sec., turn the ignition switch ON (II).
11. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
12. Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again.
13. Within 15 sec., aim the remaining transmitters at the keyless receiver unit (up to two additional ones) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation of the transmitters.
Cheers!
Ryan
Jun 11, 2009 | 1998 Honda Accord
Lost 2.4 GHz micro-receiver for my Logitect wireless mouse
Search the web for a receiver for your mouse is about all I can suggest. You might want to start with E-bay or other auction sites. Best of luck on this quest.
May 31, 2009 | Logitech MX620 Mouse
Remote contoller mode light flashing controller not working?
Hold down the connect button on the receiver and the mode button on the controller at the same time for approximately 10 seconds. This is a 2.4 GHz wireless transmitter and receiver (connection is somewhat like your WIFI router and laptop computer) and they need to reconnect sometimes.
Dec 31, 2008 | Logitech Cordless Action Controller for...
Hampton bay ceiling fan with built-in remote receiver
In case someone else stumbles upon this:
I replaced the remote receiver on one of these fans. jb is right just the top housing that touches the ceiling needs to be removed. Twist it counter clockwise and pull down. You'll see all the wires and the remote receiver. It might not seem like much room to work with, but you can remove the wires and slide the receiver out sideways to replace it or if you can't see the dip switches. Too bad Home Depot is too cheap to even provide instructions when they send you the replacement remove receiver.
May 23, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Logitech Cordless Mouse Logo
1,145 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
