Question about EliteGroup PM800M2 Motherboard
Memory Stick Installation
Just bought a 1GB memory stick (PC3200 Major) for my Elite Group PM800-M2 motherboard. When this is installed, the computer does not boot. Have tried installation in both memory slots, all possible permutations with 256 MB and 512 MB sticks: PC does not boot when the 1GB is in. What gives?
  • 37 Answers
So it seems you got the DDR / DDR2 side of the equation correct, but unknown to most, there is 'low' and 'high' density memory.
The density of memory refers to the number of chips used to make the total amount of memory that your memory stick contains. e.g. High density memory has few, large capacity chips to make up the 1024MB of memory on the stick, whereas low density memory uses many, small capacity chips to make up the same 1024MB total on the stick.
Typically, if it is a low / high density conflict, it is the 'low density' sticks only that will boot.
Me, I purchase Kingston memory when I'm unsure what the motherboard will be, and it has never failed to work.
I fix computers.
Posted on May 19, 2008
Memory pc3200 ddr 400
With many mobos (motherboards) you must place a single stick in a certain slot in order for the mobo to post. In my Asrock it is the #2 slot for a single stick. If I put it in the other slot the computer will not post. Try moving your stick to the other slot and reboot.
Oct 12, 2013 | Asrock Computers & Internet
I have an emachine T5026. Emachine tech swears this machine only supports pc2700 ram but the stickers on the factory installed ram says pc3200 256mb x 2 so i bought 2 memory masters pc3200 1gb x 2 sticks....
PC3200 is backwards compatible with PC2700. Meaning you can install PC3200 into your motherboard but it won't run any faster than would PC2700, however it will not cause any harm and should work fine.
Emachine's would say you need PC2700 most likely because they're trying to sell you some.
One of your new memory modules or the memory slots on your computer may be defective. I recommend installing a single stick of memory and booting your system. If it is successful then shut it down, disconnect the power and install another stick. Boot again and keep doing so and by process of elimination identify the bad memory stick or the bad memory slot.
This is the "likely" cause and isn't too uncommon.
Good luck.
Sep 07, 2010 | E-Machines eMachines Desktop PC
What kind of ram does the pm800-m2 rev:1.0 motherboard take
Each memory slot can hold DDR PC2700 or DDR PC3200 with a maximum of 1GB per slot.
Here is the full info you need for your motherboard:
PM800-M2 Info
Thanks for using Fixya. Please take a moment to rate this solution.
Feb 05, 2010 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
How to insert sandisk memory stick micro 1gb to computer?
Yes, you will need an adapter unless you have a card reader that accepts that specific type of card.
Dec 05, 2009 | SanDisk 1GB Memory Stick M2 Memory Card
PC2700 or PC3200 DDR memory in this mobo ?
MEMORY ecs_buttom_03.gif 2 x 184-pin DDR DIMM socket support up to 2 GB ecs_buttom_03.gif Support DDR400/333/266 DDR SDRAM
Copied above from ECS website so the answer would yes as it supports up to 3.2GB/s transfer rates at DDR400
May 14, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
1gb DDR 400 not recognized
That board needs to have minimally memory in pairs .. get another 1Gb stick
Dec 06, 2008 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
1gb memory stick
the obvious are that it's bad or not seated right. The first thing I would try is moving the new stick to a different slot.
Mar 25, 2008 | Computers & Internet
Type of memory for e210882 motherboard
the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
hope this helps.
thanks.
Feb 05, 2008 | Dell (E210882) Motherboard
3x 1GB DDR400 Problem on booting!
the details for your case can be obtained in this site.....................
http://www.memory4less.com/m4l_results.asp?ref=mem&modelid=800121
read carefully to understand the limitations that arise with your motherboard.
cheers....................
Jan 22, 2008 | ASUS P4S8X Motherboard
EliteGroup PM800M2 Motherboard Logo
237 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
