Question about Whirlpool LER7646E Dryer
Help please my whirlpool elec. dryer(LER7646EQ) is spinning slower than usual. it seems that the barrel is hard to rotate by hand as well.it is also making a loud noise. how do i fix it.
    Problem Solver:
  • 14 Answers
You may have to replace the drum guides. Reach into empty drum (tumbler) and push up on the top of the drum gently. If it has a travel space of more than 1/4 to 1/2 inch the guides needs to be replaced.
Posted on May 19, 2008
How do I fix my Whirlpool dryer that tries but won't spin the clothes or turn on?
The overheat sensor may be defective. In addition, the belt may have stretched resulting in uneven rotation of the drum. If you use softener sheets, there may be residue clogging the discharge of the drum.
Jan 19, 2015 | Whirlpool Dryers
The motor on the Maytag Neptune MDE7550 Dryer is very hard to spin by hand. Is this normal.
You should not need to spin the motor by hand. Check if the belt is not to tight or the motor itself could be defective.
Apr 15, 2008 | Dryers
Duet dryer is making a humming noise when cycle starts a d during
whenever i hear a humming sound in a dryer it's usually the motor or something caught in the blower wheel stopping the motor from spinning.open the door and see if you can spin the drum.if it spins by hand try this,open the door,push in the door switch with one hand,have someone push the start button while you hold in the door switch and spin the drum by hand helping it move,if it runs you have a bad motor,if it doesn't remove the bottom panel and see if the belt is broke and stuck in the motor but like i say usually it has something to do with the motor not spinning.hope this helps
Oct 21, 2013 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Dryer spontaneously turns on, barrel doesn't spin
If the dryer is more than 10-15 yrs old its probably a good idea to get another one...from what you told me it sounds like a pretty serious electrical problem or short with the Motor or control switch...I wouldn't suggest you try and fix this one yourself...
Apr 20, 2010 | Kenmore Dryers
Dryer makes a sound as if there's a marble loose in some rotating part. It doesn't seem to be coming from the drum, because when I disconnect the band from the motor and hand rotated the drum at speed...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ghhgfhf
Mar 21, 2010 | Kenmore Elite HE3 Steam 8676 Dryer
Whirlpool duet dryer does not run
You did not say if the motor is running, I have to assume that it is not.
You can try this...
Turn off the power to the dryer, reach inside the drum and try to rotate the drum 1/4-1/2 turn. Then turn your power back on and push the start button.
Sometimes motors will get a dead zone in them and this will move it from the dead zone.
If that doesn't help then you need to check a little farther into why it is not working.
Could be a faulty motor, faulty start switch, broken belt, or maybe a faulty timer switch.
I hope this helps
Oct 03, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool elec dryer starts when button pushed, but stops when button released . Has happened before, but seemed to solve itself.
There is a centrifugal switch on the motor that maintains power to the motor if the motor is indeed spinning and the belt intact. If your belt isn't broken, check the switch.
Jul 14, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer will not spin
Since your dryer is "new" it is under warranty. I will explain the possible reasons why it will not spin. Then you can decide whether to make the warranty call or not.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
May 21, 2009 | Dryers
Dryer not rotating
sounds like a belt or idler pully needs replaceing. what brand?
May 18, 2009 | Whirlpool Dryers
Clothes dryer doesn't spin
The way most domestic clothes dryers are made, it's usually hard to determine that the heating part works without the drum turning.
But, chances are, the drum belt is broken.
Please give the specific model number of your unit for a more complete response.
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Dryers Logo
101 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
