Question about Acer Aspire 3610 Notebook
Problem with screen
At the bottom of the scren there are a few faint lines straight across from left to right ,have to use the taskbar on top of the screen as the lines are opaque and distort viewing.every thing else is functional has'nt been dropped or damaged in any way.
  • 100 Answers
First, plug a external monitor and toggle the screen with ALT+F5 to check that the video card and drivers are OK.
If the image in the external monitor is correct you probably have a hardware problem in the LCD panel or its cabling.
You can get the replacement parts and change it yourself here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Pantallas%20portatil%22
Posted on May 23, 2008
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
Faint red lines in a curved arch like pattern
For this problem, what you have to do is here I found this solution: Right below your speakers on the right and left side are tabs. Pull out the tabs and remove the screw on eachside. Once that is done remove the speaker cover and you will see a fiber board cover in the middle of the tv, there will most likley be twist ties holding some wires, to make it easier to work remove the ties. Now remove the screws on the fiber board and pull it off. You should see 3 adjustments on the top for focus, do not touch those. Below the focus adjustments on the bottom is the blue, red, and green adjustments (they should be labeled). All you have to do is turn adjustment screw slightly to the left(or counter clockwise) and it should clear right up. That should do the trick, Hope this is helpful. Please dont forget your rating.
Jan 26, 2008 | Sony KP-51WS500 51" Rear Projection...
Start is at top
First see if your taskbar is locked. Right-click on an empty area of the taskbar, for example right next to (but not on) the Start button. You should see a menu with "Lock the Taskbar" near the bottom. If there is a checkmark next to it, your taskbar is locked and can't be moved. Click on "Lock the Taskbar" to remove the checkmark. If it isn't checked, leave it alone. Release the right-click.
Next left-click on an empty area and you can drag the taskbar to any side of your display you want - top, bottom, left or right. If you have a multi-display setup you can even drag it onto a different monitor screen.
Once you have the taskbar where you want it, right-click and check "Lock the Taskbar" so it doesn't accidentally get dragged someplace else.
Aug 11, 2014 | Microsoft Windows 7 Ultimate for PC
Windows start bar has completely gone
Sympton
You cannot see the taskbar (which contains the "Start" button) anywhere on your desktop.
Causes
  1. The taskbar may be hiding at the bottom of the screen after being accidentally resized.
  2. If the presentation display was changed, the taskbar may have moved off of the visible screen (Windows 7 and Vista only).
  3. The taskbar may be set to "Auto-hide" (Windows XP with Service Pack 2 only).
Solutions
  1. Put the mouse pointer on the bottom border of your screen.
    • If the pointer turns into a double-arrow doublearrow.gif, click and drag upwards.
    • If your taskbar isn't hiding at the bottom of the screen, try moving the mouse to the right, left, and top edges, looking for the double-arrow.
  2. Press the Windows logo key and the P key on your keyboard to bring up the presentation display mode options.
    • Make sure "Computer Only" is selected.
    • Use the arrow keys to toggle between options and Enter to select the correct display mode.
  3. Press the Windows key on the keyboard to bring up the Start Menu
    • Right-Click on the taskbar and select Properties.
    • Toggle the 'Auto-Hide the taskbar' checkbox and click Apply.
    • If it is now checked, move the cursor to the bottom, right, left, or top of the screen and the taskbar should re-appear.
    • Repeat step three to return to your original setting.
Dec 04, 2012 | Computers & Internet
Task bar that should be on the bottom is on the left side
right click on the taskbar and see if
"lock the taskbar" has a check next to it. if it does, click on that and it unlocks it and you should be able to move it then
Apr 28, 2010 | Microtek C893 18.1" Flat Panel LCD Monitor
Windows XP taskbar has "relocated itself"
Right-click the taskbar and ensure it's not locked..
Then just click on the taskbar and drag it to the bottom of the screen..
But i didn't understood the iconzied windows thing.. omg
PS: Please rate this solution
Mar 11, 2009 | IBM Lenovo ThinkPad T60
Taskbar problem
drag it to the right then to bottom. first make sure its not "locked" by right clicking it.
Nov 29, 2008 | Computers & Internet
Screen
HI, need to see a picture of the line and need to know if you see it on all inputs and whitch ones are you using and does it do it on all of them.
If you cannot send me a picture then let me know what color is the line,is it from left to the right end of the screen and the top and the bottom of the line are they straight all the way horrizontally.
Wait your response then I will do my best to find the solution.
Sep 13, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
TASKBAR PROBLEM
*Right click the taskbar and make sure the "Lock the Taskbar" option is NOT ticked
click and hold a blank space of the taskbar and move the cursor to where you would like it to be sitting so if you would like it to run across the bottom of the screen move the cursor while still holding down to the bottom of the screen, this should make it look more like what it should :)
Thanks!
Apr 03, 2008 | Gateway GT4022 PC Desktop
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Acer Aspire 3610 Notebook Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
