Question about Proscan PS60690 60" Rear Projection Television
I have sound but no picture!
I recently acquired a PS60690 and the screen no longer works. I turn it on and there is sound, but no picture at all. I'm trying to figure out if it's the picture tubes or something else.
    Novelist:
    Champion:
  • 203 Answers
Usually a loss of picture problem on this set is caused by parts on the circuit board failing. Most often a repairman will find the problem around regulator in power supply or around main output transistor in horizontal circuit. Either way, solder work and test equip. are required.
Posted on May 19, 2008
Hi, I recently acquired a WD-52525 for free from a garage sale. The woman told me they just recently replaced the bulb but it no longer turns on (was working up until 2 months ago apparently). When I got...
If the TV's are noted for bad caps, and the description of the error makes that possible, the only fix is to remove all bad capacitors from the boards and replace them with new ones.The bad ones are easy to spot because they usually are either bulged at the top or have goop running out of them, or both.
May 22, 2011 | Mitsubishi WD-52525 52" Rear Projection...
RCA TV. No picture yet has sound.
I unplugged the tv and the cable box and pulled out the battery of controls for 12 hours. When I turn on again, the tv and cable box back to normal.
Jan 24, 2010 | RCA Televison & Video
My 32" LG takes about 3hrs to get a picture when turned on
Most likely you have capacitors in the power supply that have dried out or as we say vented. If your handy and want to replace the power supply I suggest " Shopjimmy.com ". If not, then take into your local service center for an estimate first.
Jun 07, 2009 | LG 32LG30 32 in. LCD HDTV
Colors on the tv are dark
the screen control on the flyback transformer needs to be turned up a little
Nov 10, 2008 | GE 24GP653 24" TV
ProScan 60 " Rear projection T.V..
power supply,safety protection has kicked in
Jun 23, 2008 | Proscan PS60690 60" Rear Projection...
ProScan Projection TV PS60690 shuts off
It won't turn back on now? Any clicking, indicator lights, etc?....accordianman
Feb 15, 2008 | Proscan PS60690 60" Rear Projection...
Tv won't turn on
Usually this problem is caused by part failure on circuit board. Most often in power supply or deflection circuit. You will need test equip. and soldering/desoldering tools to fix this set. Most repair services charge 275.00-475.00 to do this repair on a PS60690. Crate is removable by removing rear cover, disconnecting spk. plugs and keyboard plug. Loosen two screws and whole thing slides out. This can save you service call fee.
Jan 24, 2008 | Proscan PS60690 60" Rear Projection...
Blank Picture, Sound OK on Sony TV
Hello, there can be a contact problem in power supply, deflection or RGB stage. Please ask the tech to repair it for you. Best regards, Arpi
Apr 22, 2007 | Sony KV-27V22 TV
Open Questions:
Proscan PS60690 1st turns off then on by itself. Then 3 on-off cy I've had this exact problem twice. The 1st time I replaced the RCA part number 205064, which I believe is called the HV splitter. I used a generic non RCA part. The TV worked great for several months but went out again and it has been broken for 2 years. I finally ordered the new true RCA part number 205064 HV splitter. The TV, again seemed to be fixed, and what I a beautiful picture it had through our cable box. But, no happy ending at this point. It worked for a couple of days and then turned off and back on while my wife was watching it a few minutyes ago. It cycled off then back on twice in a 3 minute period so with the picture showing and tv still on she went ahead and turned it off. This is how the problem began several years ago the 1st time it went out. I don't want to turn it back on anymore in case the brand new HV Splitter is still OK. Does anyone know what other parts may be going out, causing the HV splitters to go bad and start shorting out. I know the HV spitters have been an ongoing problem with these sets, but since I just put a brand new RCA one in only 2 days ago I'm wondering if something else goes out first and causes the splitter to go bad after a period of time. I would appreciate any help. I can't afford a new set right now and the picture looks so great on this set using a cable box I feel it's definately worth fixing. ps Could missing o-rings cause this? I've never seen the o-rings. Even the first time I replaced the HV Splitter. Thanks
Feb 28, 2017 | Proscan PS60690 60" Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
