Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Power problem (switches to standby)
Pioneer Model SD-533HD5 Projection TV, working fine one day, the next, when powered on, within 2-3 seconds the green light switched to standby and remains there with no picture.  Audio is fine through surround, does not work with any other input setting either.
  • 2 more comments
  • Anonymous Nov 04, 2008
    Same Problem! Main power supply on (red light), but normal power (green light) comes on only for 1-2 seconds AFTER I shut down Main...
    Just began happening yesterday 11-3-08.
  • Begster Nov 28, 2008
    I hit a couple buttons on the remote last night and it was almost like I hit them too fast or something (changing the TV settings to go from playing DVD to watching TV) and I heard a "click" and now, my red standby light is on and when I turn it on via the remote, NOTHING happens, when I turn it on at the unit, the green light comes on for a second and goes off.
  • Anonymous Nov 30, 2008
    my Tv won't turn on..it stays on stand by..It comes on for about a second and then it goes off again...what can I do
  • Anonymous Dec 09, 2008
    My TV has been working fine since new, then just shut itself off. (Green light goes to Red light)
    I pulled the plug and plugged back in and turned tv on again. Green light lit for about a second then went to Red again. (Standby)
    No sound or picture.
    Can you help?
    Thanks
    Scholar:
  • 136 Answers
Its the problem of the ics on the main power supply board
Do the IC heat sinks get warm??
If they do not, check fuses F852 - 2AMP, F853 - 1.25AMP, F850 & F851 - ALL 5AMP on the power deflection pcb. THESE ARE NOT GLASS FUSES. They are usually about the size of a 1 watt resistor and either green or orange in color. They are soldered in. The nomenclature is printed on the component side of the board. They are all about centered on the opposite edge of the PCB as the high voltage transformer.
If you have cleaned up the mess you describe you most likely have one of these fuses blown.
if dont have any technical knowledge its advisable to call a technician as it is worth getting it fixed.
thanks.
Posted on Oct 12, 2008
Try to turn on..green light for 2 seconds the goes to red light off
This model like others near it have soldering problems on the power board.
9 out of 10 times when the power board is removed (follow power cord to it) and resoldered the set again works fine.
Once in a while there will be a blown fuse on that board, bad soldering gets the fuse--very common in these sets.
If you need more input comment here BEFORE you rate my help and I will assist you.
SD TECH
Jun 15, 2011 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD533HD5 repair, blown STK's or bad power assy?
Go back recheck everything 6amp fuse in middle of power supply board that will blow, also solder everything that looks like poor connection pioneer always has a lot of cold solder jionts.CK all pico fuses they are green,yellow look like resistors but are fuses.
Jun 15, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Red convergence bowing
Replace both of your STKs if they are STK392-110s upgrade to STK392-180s these are the convergence ic big black ics 2 of them. Electronix Parts 1-800-223-3205
Dec 15, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
My sd-533hd5 keeps blowing the 5 amp 125v fuses
Yes! it sounds like a power supply problem! or the flyback in the main board needs replaced ( part is in the $70.00 range
Dec 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Not turning on
Power supply board pull,then remove original solder on 5 volt
regulator pins then resolder + replace 4 amp fuse........T.
Oct 25, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
349 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
