Question about Nikon D100 Digital Camera
Error code eFF
Not  a clue why the error code is showing up.
  • BillPoulos May 19, 2008
    Nikon D100 error code eFF.  Can't find solution.  Thanks.
  • laurarush Mar 18, 2009
    I have an f EE showing up, AND my shutter button won't engage.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
Hey,
which lens are you usuing?
it means that the F is not set, and you neet to set in manually. usually there is a tiny button in the backside of the lens.
Posted on Jun 25, 2008
Have a Samsung RF4287HA, sd by sd on top,middle drawer and freezer drawer. My panel shows OF on Refrig temp and OF on Freezer temp????? Tried unplugging and plugging back in, no help. Dusted back, no...
Do a little internet reasearch on your modle and get the error code listings. If that does not give you what you need the get back to me with that error code definition.
Oct 12, 2013 | Samsung RF4287HA
Error Code on DCR22E E:61:10 Code comes up immediately recording starts screen turns black & turns off. Any clue how to solve this or has this died?
hi,
1) this is lance problem ,the error 61:00 shows lance error
2)open your camera body carefully
3)you must be careful when you remove the cables of lcd and other one
4)now you see lance asambly , remove the lance asambly and clean contact properly and fix it back
this will 99.99% help you to remove this error otherwise tell me more i will solve your problem
thx for reading
May 28, 2011 | Sony Handycam DCR-HC21 Mini DV Digital...
I have a Mitsubishi WS-65511 with error code 22. I have been to http://www.tvrepairworld.com/mitsubishi_repair_kits and to TVrepaitkits.com and have no clue which kit I need, please let me know which...
You need a convergence repair kit - blink code 22 is almost always a convergenc issue. Sometimes it will look 3D and sometimes it will not show any video and have a 22 error code. TV Repair Kits has what you need.
May 17, 2011 | Televison & Video
94/95 jeep 4 lt. Seem to have error code 12 followed by 55. Manual we have doesn't show 12 as an error code - any clues, please?
12 indicates that the battery has been disconnected recently. 55 shows the end of the code sequence.
Therefore, whatever problem you are having, it isn't generating a code.
Apr 21, 2011 | Jeep Cherokee Cars & Trucks
Error code eFF
This normally indicates that you're using a lens with an aperture ring, and the ring is not locked in position. Turn the aperture ring on the lens to its smallest setting (largest f/number) and lock it if the lens has a lock. Control the aperture from the body, just as with a lens without an aperture ring.
If the lens doesn't have an aperture ring, could you reply to this post and specify what lens you do have on the D100?
Dec 05, 2010 | Nikon D100 Digital Camera
My kenmore washer showes sud code
If it is similar to the Whirlpool duet,
Try using less soap (hi eff machine)
try using more fabric softner
to clear the occasional Sud warning, I run the machine on "quick wash" with no detergent/additive. gives it two more quick spin cycles in 30-35 minutes, usually clears it.
Jul 14, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Goodman high-eff furnace, 115 BTU/hr. The fan runs constantly but it has stopped blowing warm air. I'm getting 6 flashing lights as error code. What's this mean?
Remove the lower panel and look for a wiring diagram pasted to it. On that diagram there will be an error code diagnostic chart. Depending upon which model you have it could be an open overheat switch caused by a dirty filter or a bad fuse.
Feb 13, 2010 | Goodman GMS90703BXA Heater
Xerox 8500n with error 13323.47:23971
13,323 is a Printhead Reservoir Temperature Faults . One of 3 things. In order of likeliness.
1. Print head has failed
2. Cable to the back of the print head is loose.
3. Electronics module has failed..
What that code means is that once the ink melts and flowes into the print head, the print head is not maintaining the proper temperature.
Nov 13, 2008 | Xerox Phaser 8400 Laser Printer
Minolta CF900 error C0660
There should be a lamp regulator PCB check the fuse on it. Also, if you move the scanner out of HP will it find HP again? Also, how offten does it show up scines the last time?
Feb 20, 2008 | Office Equipment & Supplies
Any clue what error code 6030 is?
I had the same problem. Pull the Fuser and check Conector.Sometime pieces of paper inside the Conector raises an error.
Please Rate .
Jan 11, 2008 | Kyocera FS-2000D Laser Printer
Nikon D100 Digital Camera Logo
480 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
