Question about Samsung Televison & Video
I have a Samsung 1080P 7 DVD player and Samsung LN-T4071F television. I have them connected via an HDMI cable. Nearly all, if not all DVD movies I play get to a certain point and the picture starts "breaking up," stops, skips, to the extent that i cannot finish watching the movie. I have cleaned the DVDs, cleaned the player, sent DVDs back for replacements, but still have the same problem. Is this a problem with the player?
  • 476 Answers
If you have changed the DVDs and the problem is still there, then the problem can only be the DVD player.
The symptoms you describe cannot be caused by the TV or the connection.
Posted on May 20, 2008
Picture jumps
Sounds like a fault with the connection to its T'Con board to display panel. Check for any loose contact at the both ends of connection sockets to LVDS cable. (Low Voltage Differential Signaling) {that involves transferring a signal on a wire and its opposite over a second wire to allow the receiver to reconstruct the signal by difference}. Re-seat all the cables that comes to and goes from the T'Con board once, and check. Contact any service technician. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. http://electronicshelponline.blogspot.com/
Jan 24, 2014 | Samsung LN-T4071F 40 in. LCD HDTV
Won't play 1080p discs?
From this problem's description I have to assume that either the blu ray player will not play blu rays or the blu ray player will play blu rays but only in 1080i/720p or that you want to know if this blu ray player supports the 1080p resolution.
If the blu ray player is not playing blu rays then you update the firmware and try multiple purchased discs to make sure nothing is wrong with the ones you have been trying. If blu rays that played once will no longer play, then you will need to reset the blu ray player from its menu and possibly by holding down the power button on the front of the unit until the word reset displays on the unit before trying to play the disc again.
If the television is not showing 1080p make sure you are connected with an hdmi cable and that it is the right version hdmi cable for this blu ray player and for your television. Make sure you have chosen 1080p as the resolution to display in the blu ray player's menu. If all of that has been done and 1080p will still not display then it is a case of incompatibility between manufacturers--Sharp and whatever the television is. It would display in 1080p on a Sharp television and most likely on a Samsung and Sony as well. With other brands and even some models of the aforementioned brands (except for Sharp) its a toss up.
Mar 05, 2011 | Sharp Aquos BDHP50 Blu-Ray Player
I can watch movies on my samsung LNT3242HX/XAA but I am unable to see or hear anything if i hook it up to cable, i know something needs to be replaced but not sure what? the tuner maybe?? ;p
1. Make sure you have connected the cable to the correct input on the set.
2. Access the User Menu and do a "Scan for DIGITAL" channels.
That should do it...
Jun 13, 2010 | Samsung LN-T4065F Television
Samsung LN-T4071F WASHED OUT ON LEFT SIDE WITH LINES GOING THRU SCREEN AND PICTURE FLICKERS
CHECK LVDS CABLE FIRST, TAKE IT OUT OF THE T-CON BOARD FIRST AND RESEAT IT, THEN TAKE IT OUT OF THE MAIN BOARD SECOND, COULD GET LUCKY AND FIX IT, OTHER WISE THE SCREEN IS PROBABLY BAD
Dec 30, 2009 | Samsung LN-T4071F 40 in. LCD HDTV
I have a Samsung 46''B6000 tv hooked up to a samsung Blu ray player B-1590 via HDMI cable. During the course of watching a BR disc, the volume had to be increased all the way up to 100 (max), to be able to...
This happens on our samsung too with some dvd's.
It is not the tv's fault (in my case) but have to turn the volume button on the dvd remote up full first then adjust from the tv remote as required.
Oct 19, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
UPCONVERT DVD PLAYER HDMI PROBLEM
I have the same issue with this player hooked up to a Samsung 58 inch 1080p plasma.
Jun 06, 2008 | Televison & Video
Help for a friend; ln-s4095d, hdmi and blu-ray.. no picture
email141.
I had the exactr same problem with P#3 and the same model of TV, I turned of the 24 hz setting as you suggested and it si workign great! The only thing I am wondering is what ewxactly the 24 Hz setting is. The actual title is "BD 108P 24 HZ output. I didn't turn off 1080P did I? Don't think so as picture looks great. Even though I didn't ask the original question I REALLY appreciate the answer!
Dec 24, 2007 | Samsung LN-S4095D 40 in. LCD HDTV
You may want to try a good, Monster Cable, HDMI cable. Visit this page: http://www.monstercable.com/HDMI/advancedhdmi.asp
If you have a standard HDMI cable, it will not support 1080P.
So this is one of the few times that I will recommend spending the money for a better cable.
The better cable improves picture color quality, from 8 bit to 12 bit and it improves audio quality.
Dec 24, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
Hdmi Issue
Most new HDMI DVD players use High-bandwidth Digital Content Protection (HDCP)on the HDMI output.If you try to play this on an older TV that is not compliant with these new standards it will not work.This standard came out late in 2004 that is why your older player still works. There is also a service bulletin from JVC about upgrading the software on your TV for HDMI compatiblity issues.If you want a pdf file of the bulletin I can send it to you.
Sep 11, 2007 | JVC HD-56G886 56" Rear Projection HDTV
Problem with 1080p via hdmi?
are you hooking up a 1080p source..if not then the set will not display the best picture in 1080p mode..
May 07, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
Televison & Video Logo
102 people viewed this question
Henry  Thomas
Henry Thomas
