Question about Garmin GPS
Idamaged the seven pin fixture on the back of my GPS 182c while removing the instrument from my boat for winter storage. It will not reconnect to the plug from the sensor/antenna. Is it possible to replace this plug? Where can Isend for repair or replacement of the part Edwin Waldman EdnCaroline@Gmail
  • edncaroline May 19, 2008
    It is a Garmin GPSmap 182C..it needs to have its damaged seven pin plug replaced. Where can it be sent to have this done?
    Master:
  • 555 Answers
What is the model type of your Garmin GPS unit?
Posted on May 19, 2008
  • 1 more comment
  • Matt Jurach
    Matt Jurach May 19, 2008
    Never mind, I see that is is a Garmin 182C. This product has been discontinued, and finding replacement parts might be difficult.
  • Matt Jurach
    If I understand correctly that the damage occurred to the receptacle on the unit itself (not to the plug on the antennae), I believe the whole unit will have to be repaired or, more likely, replaced by Garmin. The receptacle is not an interchangeable part that is made to be serviced or repaired.
    If it is just a matter of bent pins, try readjusting them so that they fit the plug once again.
    If it is more serious damage, you can open a support case with Garmin to get service for your unit.
  • Matt Jurach
    Garmin also provides in-warranty service, but since this unit has been discontinued for longer than Garmin's one year warranty period, I assume that your unit is out of warranty.
What is the best way to winterize this trailer
winterizing rv's and boats and big pools/fountains is what im very busy doing this time of year , so first let me say there are companys out there that's all they do ! look in your yellow pages 4 them \
now some of the services they preform are , drain and flush out all the black and grey water tanks/lines , flush and refill with foodsafe antifreeze the fresh water tanks , using this same liquid purge all the piping to all the water fixtures including toilets , add a rubber protectant to the tires (if has any) regrease and ck all wheel bearings / and wheel brakes if it has any , disconnect and seal all gas pipes from fuel tanks , boats need to have there oil changed and there engines anti freeze topped off , rv's /boats need to have there generators oil changed and there antifreeze topped off/replaced , all food needs to be removed from storage bays (even under seats) and last but not least a seal of some kind needs to be applied to entire outside to prevent animal/pest /water/ice intrusion we use polyester plastic as it can be heat shrinked to fit tight
Oct 30, 2015 | RVs
My garmin gpsmap 182c works when I have the consol tilted on my boat but the turns off when I tilt the consol back down
Possible loose socket connection or power wire broken inside power cable. Bend the power cable with your hand while the unit is on and try to reproduce the problem
Jul 02, 2013 | GPS
Transducer loses bottom at any type of speed greater than trolling. Worked fine last year with all the same setttings. All I can think of is , maybe the battery is low. The boat just came out of storage...
Check the transducer for any damage on the front part. Also make sure there isn't any damage on the bottom of the boat that is causing air bubbles to cross the face of the transducer. If it works at slow speeds there is definitely something causing air bubbles.
May 08, 2010 | Lowrance Lcx 27c 7" Gps Fish Finder Combo...
1996 suburban heater core, it is leaking?
PLEASE REMEMBER TO RATE ME THANK YOU RejakWilson
HEATER CORE
Remove or Disconnect
  1. Engine coolant.
  2. Instrument panel storage compartment.
  3. Electrical connectors, as necessary.
  4. Center floor air distribution duct.
  5. Hinge pillar trim panels.
  6. Blower motor cover.
  7. Blower motor.
  8. Steering column.
  9. Roll instrument panel back.
  10. Coolant recovery reservoir.
  11. Heater hoses.Screw on interior side of cowl, near the evaporator pipe (if equipped) while holding heater case to the cowl
  12. Four screws on the engine side of the cowl holding the heater case to the cowl.
    1. Two nuts on the engine side of the cowl holding the heater case to the cowl.
    2. Heater case.
      • It may be necessary to have an assistant when removing heater case.
    1. Heater cover.
      • Remove seven screws that hold cover to the heater case.
    1. Heater core from retainer
Install or Connect
  1. Heater core into retainer.
    • Install seven screws that hold heater cover to heater case.
  1. Heater cover.
    • Make sure heater cover is properly sealed.
  1. Heater case.
    • May be necessary to have an assistant when installing heater case.
  1. Nuts.
  2. Screws.
Tighten
  • Screws on engine side of the cowl to 1.9 N.m (17 lb in) .
  • uts to 2.8 N.m (25 lb in) .
  • Screw on interior side of the cowl to 11 N.m (97 lb in) .
  1. Heater hoses.
  2. Coolant recovery reservoir.
  3. Roll instrument panel forward.
  4. Steering column.
  5. Blower motor.
  7. Hinge pillar trim panels.
  8. Center floor air distribution duct.
  9. Electrical connectors, as necessary.
  10. Instrument panel storage compartment.
  11. Engine coolant.
    • Check the system for leaks.
Mar 28, 2009 | 1996 GMC Suburban
No power
Could be worth a look at the connector on the back of the unit itself. As I discovered a few weeks back, they aren't as saltwater resistant as the IP67 rating would lead you to expect. Compare the pins in the plug with the diagram on page 99 of your manual (also downloadable from http://www8.garmin.com/manuals/GPSMAP198CSounder_OwnersManual.pdf) and make sure all the pins that are supposed to be there actually are. In particular, make sure pin 15 is in a decent state. This one carries power to the unit, but will act as a sacrificial anode in the presence of saltwater, and can rapidly corrode to oblivion. If this is what has happened, you have a bit of a problem, because Garmin, don't appear to be very good at making spares available. I was lucky in that the GPS I was fixing was a lower end model that only used five of the seven pins in its connector, so I was able to rewire to provide a supply through the unused pins. The diagram suggests that the 198C also sports a few unused pins, so you may well be in luck. A.
Apr 14, 2007 | Garmin GPSMAP 198C GPS Receiver
Where can I buy spare parts?
http://www.gpsw.co.uk/cats/cl3_224.html try that one or ebay parts
Nov 14, 2006 | Garmin GPSMAP 182C GPS Receiver
GPS Logo
76 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
