Question about LG WM-3677HW Front Load Washer / Dryer
Lint I'm having a problem with lint. After washing my white towels, a lot of lint is left on the rubber around the door, which then gets all over my darks. The first time this happened, I realized what was happening, so I started cleaning the rubber before my next load. Which is no easy task. Today, the problem happened again even after the rubber had been cleaned. This is very frustrating because after my darks are done, I have to spend a considerable amount of time lint rolling all of my clean darks. My questions are: what is the best way to manage the lint that collects on the rubber and where else could lint be hiding? I really wish there were some kind of easily cleaned lint system on this machine. Didn't the product development team research this? I have really no other complaints about this machine. But, I'm frustrated because I don't have time to laboriously lint roll every piece of clothing I own.
How do you suppose to open the unit up?  Have a link to instructions?
Posted on Jun 05, 2008
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
Unfortunately that is one thing the engineers forgot to put on this unit, a lint trap. Over time the other thing that will happen is the plastic venting will clog and your drying will take longer. When this happens you have to open the unit and clean it out, not that easy a task.
Sgt 48
Posted on Jun 03, 2008
  • erictinker Sep 07, 2010
    I agree with Sgt 48. Seems to be no lint trap. I experienced slower and slower drying and finally a dHE error code and no drying at all. I had previously replace heating element and thermistor about 2 years ago - machine is about 4 years old. After taking top off the unit there is a metal duct piece over the drying element and connected to it also the plastic fan housing. Both these units can be removed quite simply with a phillips head screwdriver. Check that the ducted areas revealed are clear of lint - especially the "hole" at the end of the fan duck that returns to the washer/dryer drum. I fished out a tennis ball sized chunk of link from the hole with a bent coat hanger. After replacing fan and metal duct covering heating element the dryer seems to be functioning again. The big question is why LG engineers provided no regular lint trap accessible without disassemble of the unit - bad design. Don't buy one of these.
Calypso stains load
Hi there
I wonder why "dark streaks" on white towels. I presume that you have made sure that there is no dirt flying around in the machine.
Try to let the machine go a circle -without any washing in it- just to see if the water takes color. There are also in the shops washing powder
that remove stains of different types.
Also powder for "only whites"
good luck
Kolbrun
Apr 23, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
Black marks appearing on towels. Look like marker, smudged.
hi.
it could be the seal on the front of the drum starting to break down.
clean the seal at the front of the drum that seals the door. then rub a white cloth/towel around the seal
if there are any marks left by the seal then the rubber compouds are starting to break down and the seal needs to be replaced.
please feel free to ask for detailed instructions on changing this seal if you need them
Apr 13, 2011 | Frigidaire GLTF1670A Front Load Washer
Whites are grey
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@@**
May 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Lg washer/ frontloader
Take a hand towel soaked in vinegar, then run it around the rubber seal around the front of the door, making sure you get all the way under. Then run a load of whites with javex or vinegar. Always leave the door ajar after you are done washing, or that mildew smell will re-appear.
Nov 13, 2009 | Washing Machines
Can i put both whites and colours in a tumble bryer?
Yes, with two caveats. 1) If you put in a dyed fabric that is leaching dye you might get stains on the whites. Anything that has been washed more than three times before should be safe enough. 2) You may end up with some dark lint on your white clothes. You may want to avoid dark clothes that produce a lot of lint, like towels or sweatshirts.
Oct 11, 2009 | Dryers
Heavy towels don't come clean & smell of mildew - all whites and colours are gray after bleach has been used.
Did you add detergent to the dispenser?
For best results, add detergent to the detergent
compartment. Do not add detergent to the washer drum.
 Did you sort properly?
Sort lint givers (towels, chenille) from lint takers (corduroy,
synthetics). Dye transfer can occur when mixing whites and
colors in a load. Sort dark clothes from whites and lights.
 Did you overload the washer?
Do not overload the washer. The washer can be fully loaded,
but not tightly packed. The wash load must be balanced. Lint
can be trapped in the load if overloaded.
 Check the following:
Was paper or tissue left in pockets?
 Did you use enough HE detergent?
Follow manufacturer’s recommendations for the type of load
you are washing. For best performance, use only High
Efficiency detergent. Use enough HE detergent to remove soil
and hold it in suspension.
 Do you have hard water?
Use more detergent for washing heavy soils in cold or hard
water.
 Is your water colder than 60°F (15.6°C)?
Wash water colder than 60°F (15.6°C) may not completely
dissolve the detergent. Use hot or warm washes if safe for the
fabric load. Make sure your hot water system is adequate to
provide a hot water wash.
 Have you run the Clean Washer Cycle lately?
To freshen your washer and to avoid odors, see “Cleaning
Your Washer.”
 Are you using HE detergent?
Use of non-HE detergent can cause a film residue which can
result in odor.
 Did you leave the door open after use?
This washer has a tight seal to avoid water leaks. To avoid
odors leave the door open to allow the washer to dry
between uses.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10117768.pdf
(see page 20 for washer cleaning instructions)
Oct 10, 2009 | Whirlpool Duet Sport HT WFW8400TE Washer
Musty odor removal; also "mold" black in color around rubber seal
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$^*#
Sep 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Deposits on clothing
Be sure to seperate lint givers with lint taker, do not mix towels etc with clothes that are attracted to lint. Also be sure water levels are sufficient
Jan 13, 2009 | Kenmore 24032\24036 Top Load Washer
Lint marks left on clothing
hello are you washing new items new items tend to create more lint within the first few washes check all pockets to see if there is anything left in them there maybe to much wash action for the size and type of load try selecting a less aggressive wash cycle
Mar 10, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Musty odor
Unfortunately, this is a common problem with front load style washers. Now...if you pull the rubber boot back where it meets the wash tub there should be several small holes that allow any residual water to drain back into the wash tub. If these holes become clogged with lint and/or debris water will accumulate and mildew. The best advice I can give you when it comes to this type of washer is to become diligent about ensuring nothing gets caught in the the seam of the rubber boot. Routinely inspect this area after each wash for loose items like socks and underwear. In addition, clean this area periodically. What I often recommemd to people is to wait until you get ready to do a load of towels and wash cloths. Clean this area with a dirty towel or wash rag and throw it into the wash to be cleaned. This way you don't have to worry about having any old rags lying around. If you are not in the habit of using hot water settings you should also run a cleaning cycle about once a week on the hottest setting available. Pour a small amount of bleach into the soap dispenser and run the unit with nothing in it. This will help in killing any bacteria. Some of the newer models have now been equipped with a "Clean" cycle just for this purpose. Due to the design of these washers they become breeding grounds for mildew because the wash tubs are dark and if you leave the door closed when not in use it seals out any air that could allow the tub to dry out. When you are not using the washer leave the door slightly ajar to allow the tub to air out. I hope you find this information is helpful. Post back with comments and let me know if this works for you, or if I need to give you better advice.
Jan 14, 2008 | Frigidaire GLTF2940ES Front Load Washer
LG WM-3677HW Front Load Washer / Dryer Logo
396 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
