Question about Whirlpool Washing Machines
I have a duet HT. No codes showing but unit wiil fill with water on its on. But not very often, maybe 7 times per year. It has happen when we were out of town. Now we look before we open the door. Have you heard this one befor. Thanks,Jim McSwain
    Genius:
  • 1,073 Answers
You have a seat in the water valve that is not all the time totally sealing replace the water valve assy
this is done by rempving the top and you will see the water inlet valve make sure that the wires are put back on the same way you remove them make a diagram first
Posted on May 19, 2008
Tip
WHIRLPOOL Duet & Duet HT washing machine shows F/02 error code on display?
This error is shown on the display due to:--
Drain time exceeding more then 8 minutes, the water valves will stop functioning and the the water valves turns off and "F/02" will be displayed on the screen.
NOTE: in some cases it has been noticed that 4 minutes the "Suds" error displays, and then 4 minutes later the F02 error displays.
This Will Help.Good Luck.
on Mar 11, 2010 | Washing Machines
My Whirlpool Duet ht Washer starts washing fine, it drains then it starts flashing FH and wont take in water for the rinse cycle. It does this for every cycle, it will wash fine but after it drains and is...
The first thing I would check is shut off the cold water valve at the wall and remove the hose at the washer.carefully pry out the little screen in the inlet and clean well,reconnect hose and turn water back on FH is a water inlet issue I am hoping that what is happening is that when the washer starts its wash cycle it is probably filling with warm (hot) and cold water at the same time even though it might be mostly hot,but when it comes time to rinse (cold water ) there is not enough to make the computer happy and you get your FH error.. Hope this Helps,,If not your probley looking at a new fill valve assy
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code Sd (or 5d)
It means Suds Lock(Overdose of Detergent Detected During The Wash Cycle).If suds are detected continuously by the pressure switch during the drain or spin phases,the washer will fill 4 litres of water and during 5 minutes the unit will rest without tumbling,the water will be drained and it will try to spin or drain again.
If too much detergent was used:
– Run the unit through a Rinse/Spin cycle.
– Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,pressure switch and Central Control Unit(CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test.
Apr 11, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Cold water keeps filling even when washer is off
if it still flows with the unit unplugged then replace the cold side inlet valve for the fix , it my be called the mixing valve on a part search. Phil
Jun 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer fills up with water
Jamesbestor,
The water fill selenoid had junk in it holding the valve open or the seat in the valve is damaged.
Turn off the power and water, remove two screws on the back of the machine and remove the lid.
On the back left top corner are the water fill selenoids. Remove these and disassemble by undoing the 6 or 8 screws ( depending upon model ) holding the unit together. Clean and reassemble, it should take care of the problem. If not, replace the selenoid.
Feb 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a DUET HT . I have been having "H" & "F" problems for the last 2 months and been turning off and unpluging to reset. This time i pushed Control On but when I hold to starty nothing happens.
"H" & "F" means no water is coming into the washer, check that your faucets are on, hoses & screens on hoses,if all this is working properly, it could be your water valve or if the washer has water inside and the pump is not pumping it out, for safety reasons the washer will not fill and you will get the codes f h or l d.
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal De
