Question about Epson Stylus Photo R200 InkJet Printer
Printer paper Allignment
My printer takes the paper then pulls it to the right hand side crushing then right side of the paper please help ...What can i do to fix this
  • rogerdodge Jul 18, 2008
    I've got exactly the same problem as you Angie804 and have been trying to find a solution as well. I can't really suggest anything as I've tried manually feeding it in and checking the rollers to see if any of them are stiffer than the others (which they aren't). I've also thought about cleaning them but I've got no idea how to remove the paper tray section on the back.
    I'm more putting this comment in to let you know you're not the only one with this problem and there's others who would like to know as well.
I hve tghe same problem. DId you gt it fixed?
Posted on Sep 12, 2008
HP LaserJet 3030 Paper is crushed from top right edge when printing/copying. How can/do I fix this? I have used a heaver weight paper and it does not get crsuhed, however the print is usually smudged right...
Try reseating your Ink Cartriges first then try printing to see if the error still appears, if it does try reinstalling your printer drivers... make sure you check your printer cables if they are conencted properly to your computer after reseating the cartriges.
May 21, 2010 | HP LaserJet 3030 All-In-One Printer
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
  8. Click 'OK'.
Roller Cleaning is completed.
Jul 02, 2008 | Office Equipment & Supplies
Paper jams on right side of printer
hi,
paper feed assembly allignment problem.
pls contact to any printer specialist for allignment.
Aug 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Epson stlus C88+ printer: paper pulled to one side during printin
Hi
Chances are the sensor for grabbing the paper on the left hand side is defective. Try to check if there are obstructions as well
Hope this helps
May 13, 2009 | Epson Stylus C88 InkJet Photo Printer
Cx3650 Problem with paper feeder
There could be an issue with the gear inside your printer now that is why it is not feeding the paper through properly anymore. Please try this basic troubleshooting steps:
Turn off the printer. Disconnect the USB cable from your printer. Open up the whole scanner unit to see if there are objects blocking the way of the printhead or if there are any objects down the paper feed area. Check if the cartridge cover is closed properly. Toggle the paper guide left to right back to the proper position. Load 10 to 20 sheets of regular paper into the printer. Turn the printer back on. Do a standalone copy.
If it does the same thing, please log on to support.epson.com. Click on help me find a service center to the right of the page to find an epson certified servicer near to your area.
May 12, 2009 | Office Equipment & Supplies
Printer printed paper with crushing sounds, but
You need to continually press the paper feed button (next to power) while applying gentle pulling pressure to manually feed the paper all the way through the printer. Hope this helped
May 09, 2009 | HP LaserJet 1300 Printer
Printer will only pull the paper in from one side.
Hi !!
Usually this problem happens if there is something wrong with paper feed rollers which is inside the printer .
But to fix teh problem you can try this ---
take out ink cartridges, all the cables, power adapter (black rectangular box at the back) and papers from the paper feeder . Then take the printer in your hands, keep it like upside down and shake it for a while .Then keep it back in its position
Afetr 10-15 mins , install cartridges, cables, power adapter and just 1 sheet of paper on the printer . try to print somethg if still it dows same thg then it means that This is a time to buy a new printer on this christmas !!
Regards
Priya
Nov 25, 2008 | Lexmark X5150 All-In-One InkJet Printer
Paper pulling
Be sure your paper guides are tight against the paper. If so, then clean the feed wheels with a damp cloth (just water). If this helps temporarily, you might need to replace the feed wheels.
Jul 28, 2008 | Lexmark X75 All-In-One InkJet Printer
Printer message "paper empty custom in MP"
Its asking for you to put some paper in the tray at the side of the printer. There is a small hatch on the right hand side which will turn in to a paper tray when pulled open. Put in the paper and it will print. You will then have to disable that tray to prevent it happening again.
Jul 02, 2008 | Samsung CLP-500 Laser Printer
Cannon mp780 paper pulls to right hand side and jams everry time
printer loading tray have problem /something struck at left side of tray /check if something/if none / sometime it connot be seen its hide five cents .
clean also the incoming roller and outgoing rooler w/cotton tips w/ rubbing alcohol. test the printer.
Jan 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Epson Stylus Photo R200 InkJet Printer Logo
52 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
