Windows Vista does not come on the screen when I turn on my computer.
I switch on my computer and the screen is just dark blue, and blank.  I have Windows Vista.  the battery is fully charged, but I cannot use the computer.  Same issue. I have tried command prompt in safe mode, safe mode with specific config/command. I don't know what to do , It was fine last evening . I unplug laptop, turn it off, keep it on for hours while drive light is flashing hopeing something will jar it.
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
I think this is setting problem. Check the monitor setting Use “blank screen” as a screen saver option. This option will be removed. If it not clear the problem plese follow these steps to solve the problem...
1) Right click on your desktop or background, go to properties>appearance tab>advanced. Now select “window” in the list and select a light gray color instead of white. Play around with schemes, use your creativity. Refer to the article
http://support.microsoft.com/default.aspx?scid=KB;en-us;q307855
checked following things
* CRT monitor consumption vis-à-vis LCD monitor consumption
* Brightness settings varied 0, 50, 100
* Contrast settings varied 0, 50,100
* Screen background changed black, gray, white
* Soft power off (off using power settings of computer) and hard power off (off using switch) consumptions.
2. If your computer allows power setting control (all laptops usually do), then change power settings to “turn monitor off” after 2-5 minutes. These setting are usually accessible somewhere around screen saver settings
3.Reduction brightness settings, increase contrast settings. This also be checked.
Thanks
"Don't Forget To Rate the Solution"
Posted on May 19, 2008
  • 3,037 Answers
This sounds like the blue screen of death that happens to computers many times. This is a feature built in to protect your computer. The problem can come from many things such as your RAM cards to software. Can you do a system restore while in safe mode and restore to a day before this happened. Please update me on your situation of whether you can do this. Thanks
  • Benjamin Patri
    Benjamin Patri May 23, 2008
    Were you able to fix this, if so then please give me some feedback by rating my solution. If you need any more help, I would be glad to assist you, just ask.
    thanks and Have a Great Day!
    President:
  • 2,712 Answers
Could be a problem with either the display driver/card or the RAM.
Try reinstalling the display driver, hopefully this will resolve the issue..
    Master:
  • 555 Answers
Try removing the battery and using the laptop only with wall power.
Suddenly I cannot boot up my computer. I get the sign on screen and type in my password and click ENTER and watch the welcome screen which spins the little circle for a while and then the screen goes...
Which OS are you using? Windows xp, vista, or windows 7?
You can try this:
turn off and turn it back on
as soon as you turn it on, keep pressing F8, you will see another screen which gives you options, choose option says Last known good configuration to see if it takes you all the way to your desktop. Let me know.
Thanks
Apr 27, 2011 | HP RX881AA PC Desktop
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
I have a windows vista which keeps having blue screen and is unable to be turned on sometimes after the blue and i have to wait for a while to be able to switch it on again. any ways to fix it ? thanks
Look at the power settings. The system may be going to sleep, the hard drive shutting down, display blanking by the computer and the monitor itself all can play a part in your problem.
The delay in recovering from sleep in considerable, hybernate is worse, meaning delay.
Oct 08, 2010 | Computers & Internet
IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
Screen goes blank after hibernation - Dell Inspirion 530 Vista
Turn off vista hybrid sleep and hibernation mode. It causes more problems then it helps.
Jun 25, 2009 | Computers & Internet
Windows Vista
What you need is Disable and Turn Off ClearType Fonts in Windows Vista
Windows Vista by default applies ClearType effect to the fonts displayed on screen, in order to improve the appearance of text on certain types of computer display screens, especially LCD flat-panel monitors. As ClearType text actually sacrifices color or chrominance details aspect of image quality for light and dark or luminance detail, some people may not like the blurry font style in ClearType. Here’s a easy way to disable or turn off ClearType in Windows Vista.
1. Right click on any blank spot of desktop, and then select Personalize on pop-up context menu.
2. Select Window Color and Appearance.
3. Click on “Open classic appearance properties for more color options” link located at the bottom of the page.
4. Click on the Effects button.
5. Do one of the following:
Uncheck (untick) the “Use the following method to smooth edges of screen fonts” box.
or
Select “Standard” to replace ClearType in the drop down list under the above title.
6. Click OK, then click Apply, and finally finish with clicking OK again.
To enable or turn on ClearType effect again, simply reverse the setting in the Effects step.
< Please Rate :) >
Apr 12, 2009 | Compaq Presario R3000 Notebook
Blank light blue screen (NOT blue screen of death)
hi...some times norton uninstallations create this problem, in which norton also uninstalls some system file like virtual driver file, etc.! u can try these things :
1. use systen restore to restore ur previous settings
2. IF it don't works, reinstall window !
let me know if it helps....
Jan 01, 2009 | Compaq Presario 700 470024-192 Notebook
Blinking of screen background
DOES YOUR COMPUTER MEET RAM MEMORY AND PROCESSOR REQUIREMENTS REQUIRED TO LOAD VISTA
Jan 18, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
