Right channel for my GX365D will not record but does playback OK.
    Genius:
  • 1,550 Answers
La pastilla de la grabadora esta danada.
Posted on May 19, 2008
How to dub tape to tape
Hi Dale,
You're kind of light on details of the equipment you're going to use - so the best I can do is provide generic instructions. You'll need two devices - one must be able to perform playback for source media and the other for recording or copying duties. Inspect the jacks provided on the rear of both units. Most provide standard RCA type "Phono" jacks for left and right audio channels. Connect a stereo patch cable (with plugs that match the jacks of the playback and recording devices) between the left and right OUTPUT (or "PLAY") jacks on the source device and the left and right INPUT (or "RECORD") jacks on the recording device. Insert the source tape, cd, album, etc. in the device that will playback the original and insert a high quality blank media into the device that will provide recording capabilities. Begin playing the source. Set options such as tape bias, Dolby Noise Reduction, etc. on both source and recording devices to match media in each. Advance the playback source to a point that contain the loudest sections. Set recoding levels by monitoring the VU meters on the recoding device and vary the input adjustment levels so that only the loudest prortions of the program just begin to briefly "flirt" with the 0Db or red zone of the meter. Signals that cause the meter to indicate into this area and beyond begin to overload the amount of information that can be recorded on the blank media and often result in muddy audio quality during playback, later. You should also record the same section repeatedly with differnt options (bias, noise reduction, etc.) to actually hear the difference to determine which sounds best to you. Once levels are set, queue the playback device and start recording. In the case of tape, allow enough recording time to let the leader section of the tape to pass beyond the recording heads for several seconds or more. Once the desired amount of silence has elapsed, play the source program. Allow it to run to completion using both sides in the case of tape and then playback the entire new recording to make sure it recorded without any issues.
Apr 09, 2015 | Televison & Video
Playback background noise
Undo the previous recording after each take
Dec 23, 2013 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Teac a-3340 not recording on channels 1and 3
You need to set the various RECORD switches correctly -- both the ones on the lower right and the playback ones between the meters.
Mar 05, 2012 | Audio Players & Recorders
Same prob, using control panel sound mic off does not work
Right click on the speaker in the bottom corner (or go to sound in the control panel) and go to playback devices. Then click speakers, then click properties. Go to the levels tab and mute/lower the volume of the microphones.
Aug 28, 2009 | Compaq PC Microphone (Black or Beige)...
Playback distortion
Good day sir, distortion can be caused by several factors, 1. overdriven audio source, try tuning down the volume to half. 2. the speakers are defective due to driver's coil scratching the magnet. need to replace the speakers, better swap first any good known speakers. hope this may help. if you may have any more questions, feel free to ask again. thanks
Jul 18, 2009 | EMC Zotac GF6100-C-E MCP61P GeForce 6100...
My son dropped my vcr and now when I record all I get is a bluescreen during playback, was something damaged, can it be fixed or should I just toss it out?
Have you checked that your signal input eg. aerial connection, cable connection etc has not fallen out from the rear of the VCR. If this is ok does it still play pre-recorded tapes ok? Make sure the channel indicator is still showing a tuned channel such as 1 or 2 etc. If still a problem please get back to me.
Jun 06, 2009 | Philips VR330 VHS VCR
Wont record or playback picture
Go to the menu. Select "setup". Then "Channel". Let Auto Channel Memory record your channels. I had the same problem and this worked for me.
Jun 21, 2008 | Samsung DVD-V5500 DVD Player/VCR
Samson co1u recording issue
you first 3 people are idiots... maybe if you had worked with the hardware you would know how the mic works because its obvious you don't. The 4th person is correct because this is exactly how i use the mic and it captures sound in stereo format beautiful when set up rite. Using it in mono, whether use keep on one channel or two drastically reduces the crisp sound that this mic can record.
Mar 18, 2008 | Samson C01U - USB Studio Condenser...
VHS playback - no picture
Do you have a scart lead connected ? if so it is not in properly, and it would not be channel c26, but the av channel on your TV that you would need to be on.
Feb 17, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Audio on DVR recordings on non-digital channels squeals on playback
Try a system reset by unplugging the unit from all power, wait for 5 minutes and retry. This is an unusual problem...accordianman
Oct 13, 2007 | Arris DCT6200 DTV Receiver
 Grubhead
Grubhead
