Need cord that goes from TV to plug on a Sanya Model CLT2054 VIZON
  • 518 Answers
SOURCE: TV problem
Sound like either the Red or Blue driver transistor on the CRT board is intermittant.
Hope that helps...
Geno
Posted on Apr 04, 2008
SOURCE: Power Cord
Please let me know when I can get the power cord & AC adapter. I moved and lost them and cannot use my television. Thank you R. Werkheiser
Posted on Nov 03, 2008
SOURCE: sanyo lcd tv flat
I have researched this problem and it is so common we that own this piece of junk ought to form a class action suit and sue. It is caused by a bad part or bad connections to a part called a backlight inverter. It seems the LCD needs a higher voltage than supplied by the 12vdc power pack so this part re-chops the DC voltage to generate the LCD requirement.
The date of manufacture is on the back of these TVs and all the problems seem to be from those made in 2006 to 2008
Posted on May 05, 2009
  • 11 Answers
SOURCE: Sanyo CLT2054 - power cord has light but when I plug it into the
OK you need a volt meter to check the voltage output of your power pack as two things cause this now enough power out the pack to run your unit or the unit has a short both problems will unlight the light so you need to know if the power supply is working right first as it should say like 120 volts AC in and 12 volts DC 1000 ma out so you will need to mesure this with a volt meter. this is a common problem loading the load of the curcuit as in your TV is mor the the power pack is giving out thus shorting out the power pack of any voltage present, as the little LED light your seeing only takes 5 volts at very ittle current to light and dose not repersent the total voltage output of the power pack itself
Posted on Jul 03, 2009
  • 11 Answers
SOURCE: missing power cord 12v
go to radio shack get a 12 volt 1500ma power supply with I belive it is a N% plug end but any how 800 ma to 1500 ma should run this and the plug end is standard plug with plus 12 volts on the inner side and negitive on the outer case side look at the back of the TV or the old power supply it sould have info on voltags and amprage, and the plug as to inner voltage and outer voltage on the plug any old time radio shack or electronics shop should be able to help you bring in the flat screen if need be as if you know its 12 volts then It wont mater weather you use a 1000ma 1500ma 12 volt ubnaversale power pack as the tv will only use the current needed so more MA is good the only concrn you have is the right mini barrle plug and the right side of +/- voltage on that mini plug being most use + voltage in the inner most circle and - 12 volts on thje outer
I have a CLT2054 and lost the power cord. I bought a new power cord but when I plug it in the light on cord goes out and TV wont come on. If I un plug cord light comes back on
You have short circuits inside the TV, the AC goes into shutdown when it senses too much current being draw. Post some pictures inside the TV if you can, wee need to look for short circuits, another thing, you bought new AC adapter with the same voltage and current rating, right?
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 29, 2010 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
20 SANYO VIZON DOES NOT HAVE MENU BUTTON IN THE TV
The menu button is on your remote control, it is located at the bottom of the input button
May 13, 2010 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Sanyo Vison model CLT2054 - three years old. Screen goes black shortly after turning it on. Is this a common problem? Is there an inexpensive fix?
clt2054 Sanyo vizon 20" TV
At power on my screen blinked on for a second, then went black for a minute or so, then blinked back on, this repeated. I noticed the external 12 volt dc 5 amp power supplys green light blinked on & off with the TV but it blinked off just before the TV did, indicateing that the problem was a power supply problem. Then I put the PS transformer up to my ear and could hear it buzz as it powered on each time. The buzz increased in frequency rapidly then stopped as the internal heat fuze/thermister er something, shut it off for a minute untill it reset. A person could buy a new Power Supply transformer for $14 to $40, or could try to fix their PS. But I simply hooked it up to a 12v car battery & the TV worked. On the back of the transformer is the pinout for the 12v 4 prong plug that goes into the TV. On the TV the bottom 2 pins a 12v+ & the top 2 pins are 12v negitive. Nails with the burrs filed off fit into the sockets, a strip of thin card board between the pos & neg nails for an insulator, & aligator clip jumpers on them to the battery got me a working TV. So I now know it was a power supply problem. I could follow the advice of others on this great FixYa site & try to fix my PS capacitor problem ? Or buy a new PS, or just put the TV in my 12v veggie oil diesel magic buss, er camper thingie. AND please don't send anyone $19.99 for free advice.
I hope this helps someone in somehow.
bitdog
Dec 21, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
May 16, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
TV freaking out
can you check your AC Adapter? is it supplying exact 12V?
Feb 28, 2009 | Sanyo Vizon LCD-15A2 Television
Sanyo clt1554 has sound no picture.
I have a Sanyo CLT1554 (2 1/2 years old). Has perfect sound but no picture. The picture will come after several times turning it off/on and pressing the Reset button. It is very anoing to do this evey time. PLEASE HELP
Dec 15, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Power Cord
Nov 03, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
