Question about Whirlpool Duet GHW9150P Front Load Washer
Water in the baskedt
Our Whirpool Duet washer basket (drum) appears with water a day or so after the last time it was used. After the wash\rinse cycle, the basket is dry and the clothes do not have excess water. The problem comes a few days later, when we find clean water in the basket. Could it be a faulty fill valve? Please help.
Thanks,
    Genius:
  • 1,073 Answers
Yes it is the problem replace the water inlet valve
this is done by removing the top you will see the valve that the fill hoses connect to
make a diagram of the connections so that you get it right when you reassemble the unit
Posted on May 19, 2008
I have a whirpool stack duet washer and dryer mod wfw9250ww01 it wont fill all the way it sounds like the water pressure level switch do you have to take the dryer off before you can get to the part?
modern front loaders dont use a lot of water when washing clothes since the diagnostic board doesnt allow for too much water to flow into the washing drum this is fully normal for eco reasons
Apr 21, 2017 | Washing Machines
My Whirpool Duet front loader will begin a wash cycle, but stops when cycle switches to rinse with water in the drum. Door remains locked & light by the 'wash' flashes 9 times...
when the machine is stopped can you empty the residue water that remains by the programme selector? if not check for blockage in the pump(coin), the hose internal blockage ,or at the outlet under sink. I hope this help
Jan 15, 2015 | Whirlpool duet Washing Machines
I have a Duet Whirlpool Front-Loading Washer and the last couple of days I've noticed there has been water in the drum. I ran it through just the drain/spin cycle it appears to remove the water only to...
Sounds like you have a seal issue. Try and shut the water from the back connection off after you do a load. I believe that it sounds like you have a leak from the gasket and it is letting water in when you don't want it there. If the water isnt there then we have narrowed the issue. Please let me know what happens. Hope it helps!
Dec 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water seeps into Whirpool Duet washer
If your washer is leaking water when it is not in use, the following link explains how to troubleshoot to isolate the cause:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
The problem is either attributed to a defective pressure switch or a water inlet valve that is leaking by. The link I provided will explain how to determine which one.
If you still require assistance, please let me know.
Jan 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet - Soap not getting into wash cycle
O.K. Is the water draining out properly? If the filter is blocked then your washing will be churning in dirty water as the machine will drain for a maximum time then rinse etc. in the used water.
May 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet front loader ghw9100lw error code F02
if your hearing clackling try and clean the pump and the hose leading into the pump for a coin ,,small ,,(dime),,,hair clip,,also its a must that you use he detergent,,or you sude up,,if you do use he your using to much,,now bleach the unit out on a normal cycle hot wash cold rinse with about a pint of bleach...and no you can purchase part of a pump..it comes as you see it in unit..onthejob
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water does not drain
is your pump clogged if not check the lid switch
Dec 20, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Whirpool Duet won't spin clothes at high speed
Thinking of 2 things either the transmission is out or the clutch is burnt out and the drum basket and possibly the drive shaft broken as well. Prices vary greatly by how many of these things are broken but should run between 100-200 including labor.
Dec 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Spinning problem
I believe there is either a loose pulley or on the other side of the pulley spindle is a spoke assembly that holds the basket on is broken. If you see water leaking at the spindle you have bearing and seals that have faulted. Either one of the last two are expensive to fix, if you have a home warranty that blankets your appliances with a deductible I would recomend getting a tech out to fix those problems.
Sep 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Low water level
It depends on how old the machine is, the newer machines by law,take in way less water but still wash ok. TIP.try it with out load and check water level Ire bye
Nov 04, 2007 | Whirlpool GHW9200L Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
71 people viewed this question
Dan Webster
Dan Webster
Sal De
