Question about Harman Kardon SoundSticks II Computer Speakers
Sound output only <10%
I've had my soundsticks II for about a year, took them out of the closet after 3 months of storage, and they sound output only seems to be about 10%. I tried several different audio sources (TV, laptop, ipod) and nothing gets them loud enough. The volume sensors seem to be working (volume up, down, and mute) but nothing else works to get them any louder... Suggestions?
  • 1 more comment
  • Anonymous May 25, 2008
    I've had the same problem. Soundsticks worked great until I moved. Now there is zero sound output. I've tried several input sources, with no luck. The subwoofer is getting power. The satellite speakers work.
  • Anonymous Oct 10, 2008
    i have the exact same problem, also the sound was a bit fuzzy, it was also after they were in storage
  • Anonymous Nov 19, 2008
    i have the same problem , i moved mu computer from one room to another,,,,, when i plugged it in after i moved them ,,,they does not work anymore, there is still light in the sub,,,,anyone????
Hi there
Toward the base of one of the satellite speakers are two chrome finished plates...these are touch volume plus and minus pads! It seems that these units default to low level if not used for some time. Just try touching the + pad!
Cheers
Pete Dolman
Posted on Jul 13, 2009
Just found this thread as same problem
Happily, also found a thread on different forum with solution that works for me: look for + and - buttons on one of the satellite speakers. Woah! - now get volume all the way up to 11!
Posted on Apr 29, 2009
I found the + and - buttons that I didn't know these had and with one touch of the + the speakers came back to life!
Posted on May 06, 2009
I have this identical problem.  Only I unplugged and re-plugged only to now have NO sound output.  Since I had a tiny bit of sound before, I don't think this is a setup problem. Somebody somewhwere . . . what is up?  Can someone please answer or provide the Harmon Kardon contact?  I'm no longer under warranty.  Everything was peachy until I packed them and moved.  Soundsticks seem to be a bit too sensitive for my liking.
Posted on May 24, 2008
  • msfusha May 04, 2011
    same here. i unplugged to move them from one room to another and when i plugged them back in they didnt work. i left them unplugged for a few days tryed again and still nothing. i know about the volume biutton and nothing
Harman kardon soundsticks ii Hi my dog chewed and ate the DC power plug power, luckerly for the dog it was not the AC end. Now I have had my dogs teeth removed I want to fix the sound system. I can find...
https://www.shutterstock.com/image-photo/muzzle-17780320?src=W0JhB6uuAnfBtLF2bzYYqg-1-42
There should be an international standard number with the plug.
example IEC 60906-3:1994
Search on your plugs number and it will tell you all about the plug that you have.
Usually
https://en.wikipedia.org/wiki/Coaxial_power_connector
The outside on the plug is negative and the inside of the plug is positive on most DC plugs .
With a continuity device like a multimeter you could work out which pin connects to the outside of the plug sleeve that inserts into the device. Being negative .
Jul 14, 2017 | Harman Kardon SoundSticks II Computer...
Harman Kardon Soundsticks III
unfortunately my man you've burned the amplification board of your device..You ought to contact the dealer you've bought it.There is a warranty for a period of usage.Good Luck!
Mar 12, 2013 | Harmon Kardon Harman Kardon Soundsticks...
Hello
It seems that the power supply section of your speaker systen has the fault. Check the fuse inside it. If it found blown out, never replace an other fuse in place. Check the power supply circuit board for any short circuited components in it, before replacing an other fuse.
Mar 21, 2012 | Harman Kardon SoundSticks II Computer...
I've lost all sound completely. The speakers worked fine for like a month and then started to loose volume and now there's no sound at all.
It is possibly that either you raised the output volume too high and blew out the speakers. Or it is also possibly that there is an issue with the input cord. If it is connected to a computer wiggle the connector around to check for faulty wiring. Do this will some sound is playing. If the connector is the issue you should either hear proper sound or static. If this is the issue you can try and replace the connector end yourself or have a service center do it for you. It is a relatively simple repair for a trained professional.
Mar 06, 2011 | Harman Kardon SoundSticks II Computer...
Low sound coming from soundsticks II
On the right stick, there are two metal pieces at the bottom of the stick. The right one is + for volume up, and the left is - for volume down.
Press the + one a few times with your finger as they are touch activated. Be careful though, as it can get loud very quickly. Play some music and set the computer volume to about half way. Then press the + speaker on the right hand side until you are happy with the volume.
Hope this helps,
Nathan.
Apr 08, 2009 | Harman Kardon Harmon Kardon SoundStick II...
No audio from my Harmon Kardon SoundSticks II
mute the inbuilt speakers you can hear the sound from the external speaker
Mar 22, 2009 | Audio Players & Recorders
Speakers not listed in sound output options
I would try un-installing the driver/ application that controls the speakers and re-instaling.
Jan 24, 2008 | Harman Kardon SoundSticks Computer...
Harman Kardon Soundsticks II left speaker
Hi, Kazim
Firts things First:
1) check connector for 2 way sound. you can use a headphone for this.
2) you also buy Ipod dock sound speakers, there is Ihome speakers, great ones, for less than 25.00 dollars.
3) you have to see balance on those speakers.
good luck
Jan 21, 2008 | Harman Kardon SoundSticks II Computer...
One speaker not working.
Suggest you swap the right speaker into the left output if it works the the amplifer in the control unit is faulty. IF still on sound then the rigth speaker is faulty.
Oct 03, 2006 | Harman Kardon SoundSticks II Computer...
Harman Kardon SoundSticks II Computer Speakers Logo
784 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
