Question about Emerson Televison & Video
Emerson dual screen dvd player reads " bad disk"
Used the unit twice ...on our last trip worked fine.....on our way home the unit would turn on, loading , then it read bad disk. I tried a cd and that skips and jumps all over the place.
  • 3,037 Answers
Alright, sounds like either you bumped the laser loose a little bit or try laser lens needs to be cleaned with some rubbing alcohol and a q-tip.
You will need to open it up to check it or clean it.
If this system is brand new and still under warranty, then Don't open, merely return it and get a different one.
Please update me on the situation. thanks
Posted on May 19, 2008
  • Benjamin Patri
    Benjamin Patri May 23, 2008
    Were you able to fix this, if so then please give me some feedback by rating my solution. If you need any more help, I would be glad to assist you, just ask.
    thanks and Have a Great Day!
    President:
  • 2,712 Answers
Try using a CD lens cleaner and see if that helps resolve the issue. If not, it could be that the lens/laser has misaligned, and you will need to take the machine for servicing.
  • Swilin Sampson
    Swilin Sampson May 19, 2008
    Since you say that this is a new player, I'd recommend taking it back to the shop to get it replaced under warranty, instead of oopening it up and trying to replace anything.
I have a Sylvania 32 inch DVD not reading the DVDs what's wrong???
How To Fix a Portable DVD Player That Is Not Reading or ...
? 17:12
https://www.youtube.com/watch?v=ucNedtR256g
Jan 18, 2015 - Uploaded by orly lando argallon
How To Fix a Portable DVD Player That Is Not Reading or Loading Discs. ... 2:32. How To Clean A DVD ...Missing: inch
Amazon.com: Sylvania SDVD9805/SDVD9805-C 9-Inch ...
www.amazon.com/Sylvania-SDVD9805-SDVD9805...
Amazon.com, Inc.
Rating: 2.9 - ‎916 reviews
Sylvania SDVD9805/SDVD9805-C 9-Inch Twin Dual Screen DVD Player. Sorry .... 5.0 out of 5 stars32+ hour car trip ... One remote does not work on both, only works for the one it came with. .... Garbage, 3 months in the first of the two DVD players stoppedreading the DVD's so we only used the one and now 5 months in the ...
Sylvania SDVD9805/SDVD9805-C 9-Inch Twin Dual Screen ...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Sylvania SDVD9805/SDVD9805-C 9-Inch Twin Dual Screen DVD Player at Amazon.com. Read honest and ...
Jan 20, 2016 | Sylvania Televison & Video
Why won't the players read a disk
Hello, Get your operators manual and make sure that you have the right type of cd's in your player. If it is ok then you have a bad player.
May 30, 2014 | Philips PD9016/37 9-inch Portable LCD Dual...
The GPS portion of the Pioneer Unit in my motor home does not work. The screen indicates a disc reading error. Everything else on the unit seems to work fine. Can you give me any ideas on fixing the...
Sounds as if the disk is bad. You'll need to find a torrent download for the disk (there's one for the eastern part of the continent and one for the western part). If it's an .iso file you can burn it directly (as a disk image, of course, not as a file). If it's a .uif file, you can convert it to an .iso with uif2iso (http://aluigi.altervista.org/mytoolz/uif2iso.zip), then burn it. You'll need a dual-layer DVD (and Pioneer products seem to prefer DVD+R disks to DVD-R ones.) Or you can just buy a new disk for the exorbitant Pioneer price.
Aug 01, 2011 | Pioneer AVIC-N3 GPS Receiver
Emerson AV50 says ''NO DISK''
Hi, sounds like you have a dirty laser eye on the DVD player. The eye gets dirty and it won't read movies or function properly. I would recommend a DVD Cleaner CD. I would have you try this before I have you open the DVD Player to clean the Laser Manually. Please try this and Post the Result for me to Review. Thank you
May 19, 2009 | Emerson Audio Players & Recorders
Playing recordable dvd
My Emerson won't play anything except DVD Movies, never has, wasn't suppose too. Make your movies in DVD Video format and it will read them fine (unless it's broke). I make movies all the time and play them back in mine. It reads DVD-R, DVD+R, and in duel layered. It will not read RW disks!
Man I've every problem you can imagine with DVD Players. I've found when the disk gets stuck, as long as it's not jammed. You can turn the unit off or unplug it. Plug it back in but DON'T TURN IT ON! Instead hit the eject button and the drive should open the drive without trying to read the disk.
Feb 24, 2008 | Emerson EWD7003 DVD Player
Disk holder will not open when open/close button pushed
a switch outside or inside is broken, dirty, or somewhat that get inside a switch.
Jan 13, 2008 | Emerson EWD2203 DVD Player/VCR
No Disk
There are several causes for this problem.
1) Faulty DVD drive. Most drives have a dual laser, one for CD, and one for DVD. Check the player with both CD, and DVD. If it reads one and not the other, then it is most certainly a faulty laser. The laser assembly or whole mechanism will need changing.
2) Dirty or dusty lens. If the unit is kept in a dust environment, dust and dirt can be drawn into the machine by the fan. Try using a DVD lens cleaner. If this doesn't work try a CD lens cleaner. (Dual laser - see 1))
3) Condensation. Condensation can build up on the laser lens if the unit is kept in a humid environment. Also, this can be caused by a cold environment. In this case, condensation forms as the unit warms up. In either case, leave the unit in a warm dry environment for an hour.
Dec 27, 2007 | Philips HTS3450 System
Invalid disc
contact alco electronics at1-800-252-6123 cost is 80.00 flat fee to repair the problem
Oct 30, 2007 | kawasaki PVS1965 Portable DVD Player
Televison & Video Logo
96 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
