Question about Sharp R-23GT Microwave Oven
Error code on touchpad....
We have tried to reset the touchpad for the microwave oven, and all it shows is EE4 as a code, which we are assuming some kind of error code. We've tried to unplug the unit and re-plug it in again, but nothing seems to work. What can we do to fix it?
  • Sharp Master
  • 8,973 Answers
EE4 means that the unit is not set to the proper level for the line voltage at the place where it's installed, or that may have a faulty outlet or power line.
Assuming yours is a Sharp R23-series, we have uploaded the full service here.
But I've attached an excerpt to show you how to check / set your proper voltage level.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 22, 2008
How do I reset the lg microwave. It's asking reset date but my touch screen
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Jan 07, 2015 | LG LMV1630ST Microwave Oven
Microwave showing FO1 when turn on all switches
this code normally means defective keypads. test it and replace if necessary, follow this steps . God bless you
  1. Controller is confused A power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switches This can result in the controller thinking the door is open and ignoring you.
  3. Cleaning Cleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave
Dec 10, 2013 | Miele H187MBALU Convection/Microwave Oven
Power 100 code
you must try this:God bless you
If you are unable to adjust the power level, there may be a defective triac or a problem with the circuit board.
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switchesThis can result in the controller thinking the door is open and ignoring you.
  3. CleaningCleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Nov 14, 2013 | Kenmore 66469 / 66462 / 66464 Microwave...
Je1540wv002
follow this steps and fix it use the VOM 4f0e2859-427b-40e9-9e89-e7e7bb5bc8da.gif. God bless you
1. Door is not closed (some models).
2. You waited to long (open and close door to wake it up).
3. Controller is confused (pull plug for a minute or two to reset).
4. Defective interlock switches.
5. Faulty controller or its power supply.
6. Touchpad or controller board contaminated by overenthusiastic cleaning.
7. Defective/damaged touchpad.
Jun 11, 2013 | GE JE1460 Microwave Oven
GE JVM1440SH001 f3 error
see the commentaries and repair:
F3--Shorted key panel(touch pad), will occur if a shorted key panel is detected continuously over 60 seconds.
test the following:
Jul 31, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore Gas Range model # 362.75491990 F3 error Oven will not hold temp - error message displays and beeps I Replaced the oven temp sensor same issue Is the control panel bad?
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect.
these are some other code error that will help you in case of next time.
  1. Step 1 Press "Off/Cancel" (or "Cancel/Off" depending on your model) to clear the error code. Note the code if it reappears.
  2. Step 2 Replace the touchpad if the code displayed is "F0," "F7" or "F10." A function key is stuck or shorted.
  3. Step 3 Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
  4. Step 4 Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
  5. Step 5 Replace the ERC if "F5," F6" or "F8" is displayed. The ERC is the main control unit. "F5," F6" and "F8 are codes that indicate problems in the ERC functions.
  6. Step 6 Inspect the door-lock assembly and circuit if "F9" is displayed. The door must lock when the oven is in use. If the lock mechanism is not functioning or if the detection circuit is malfunctioning, the stove will display "F9."
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); NOTE:
"F3" codes mean your oven temperature sensor has failed or shorted out. The only thing you can do is to replace the sensor.
Take care.
May 11, 2010 | Microwave Ovens
The unit is beeping and has a code showing F3
Is it difficult to change a touch pad on my ge profile eterna spacemaker microwave. F3 Error, Bought it new in 2006. Touchpad Part No# WB07X10959 Twinsinger asked.
Feb 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave touchpad does not respond but clock is showing
You need to unplug the microwave and leave it like that for a day or a few hours it probaly just needs to be reset !
Nov 11, 2009 | GE Microwave Ovens
GE JVM 2050BH001 does not heat but everything else works
hey! you told that everything working in your microwave oven! inside the microwave oven! transformer only producing heat! that transformer only fault in your oven! try to repair or change the transformer!!!!!!!
Sep 29, 2008 | GE JVM2050 Microwave Oven
Sharp R-23GT Microwave Oven Logo
290 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ed Mac
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
