Question about Pentax ME Super 35mm SLR Camera
Loading film in my vintage camera..help!
I inherited a ME Super SE 35mm Pentax camera, and I do not know how to load film properly without ruining it. I am new at this and this camera means alot to me. Please help, Thank you. =)
  • Anonymous May 22, 2008
    I am having the EXACT same problem. I am not an idiot, and truly feel like one. The manual is not helpful enough.....help!
The "magic needles" while making the camera easy to load are about as intuitive as a dead skunk, I had a similar confusion when I got an ME Super. Put the film can in the left side of the camera back (the side with the little thing sticking out is the bottom, it looks upside down this way, but that is correct). Next push the film winder down, this will semi-lock the can into place. Now pull the film-lead across the camera and push it down between some of the white "magic needles on the opposite spool(push it in a bit so that it will stay). Next advance the lever; release the shutter. If the spool starts to turn you are doing it right. Now close the door and continue advancing and clicking until the little frame number window on top reads 1.
Posted on Jul 03, 2008
    Problem Solver:
  • 18 Answers
I found this site. Someone has scanned in the user manual for the Pentax ME Super and put it on-line.
Here is the link.
http://mcfaddenphoto.com/camera_manuals/me-s_man.htm
Hope this helps!
Take care & Happy Imaging!
Glen
Posted on Jul 26, 2008
I have a Pentax ME super and the film door will close when there is no film but when i load it with film its not closing properly?
I really loved your camera type though it was 35 years ago I had one. I envy you.
Not sure why you should be having trouble unless you have a bad film. Have you tried more than one film?
If the film cassette has dropped in properly and is laying flat, the film rewind has to be raised, I think, to allow that and the sprocket holes in the film are properly engaged with the sprockets and the free end of the film engaged onto the film wind-on reel then everything should be well below the door aperture.
I would wind on maybe a frame and fire the shutter prior to closing the film door just to observe everything moving as it should and then close the door.
The last quarter inch the door must be closed against the pressure of a spring but if the little spring-loaded device behind the door which is intended to keep the film perfectly flat against the camera body is working correctly only a light pressure will be needed to compress those springs and close the door.
Perhaps something is wrong there?
I don't remember any problems closing the film door.
I hope this helps but if it doesn't please come back again and describe your actions and the feel of the door more fully.
Feb 04, 2015 | Pentax ME Super 35mm SLR Camera
Pentax ME super advance film doesn't get caught
This is a known fault with this retro model, I'm afraid - over time, the plastic gears get worn, and eventually fail. Solutions are mentioned on the Pentax Forums.
Aug 19, 2017 | Pentax ME Super 35mm SLR Camera
When i tried to load my Pentax ME super i had trouble winding it through the sprockets and then after not being able to get it, the winder wont click over and the button will not press! any help would be...
I would say the film in the camera is lost.
Take it out with as little damage to the film as possible. If required cut the film and remove from the camera spool.
Try the camera with no film, does it work.
It could just be a bad roll of film, unlikely but possible.
Mar 21, 2010 | Pentax ME Super 35mm SLR Camera
Camera repairs
loading mechanism,gear system must be defective,so u r not able to load the film,while loading shutter gets charged,stops running,so the shutter mechnism also be chaqued.
Mar 06, 2010 | Pentax SF1n 35mm SLR Camera
Pentax me super camera, not working wind on lever
The clip spring broke jambing the advance gear. by forcing, the tab on the advance shaft broke.
take or send your camera to a camera repair shop for an estimate cost to repair.
there are no new parts for this model so the repairs could be expensive.
there should be no cost for an estimate.
Dec 10, 2009 | Pentax ME Super 35mm SLR Camera
Pentax ME wider II problem
It should stop advancing the film when the camera counter is on #1 exposure with or without film.
Dec 08, 2009 | Pentax ME Super 35mm SLR Camera
I loaded the film but display window shows a flashing zero
Go ahead and try anyway. A ruined film is far cheaper than a useless camera or a professional repair. In any case, if the film hasn't loaded properly it will only be the first short length of film which is ruined. As this is a newly loaded film you haven't any risk of losing any undeveloped photos.
Auto spooling film systems are great when they work, but sometimes are a real pain and some cameras seem really picky about having a film leader of precisely the right length. See if you can engage the the film onto the spool manually.
May 14, 2009 | Canon Prima Super 105X - Point & Shoot /...
Pentax mz 60 unable to load film error message
error messages are for camera repair technicians and are found in repair manuals. have your camera checked by a camera repair shop tech.i would get an estimate first.
Dec 15, 2008 | Pentax MZ-60 QD 35mm SLR Camera
Film Advancer loose
Hi., rotate the rewinder clockwise until the film will tightened , hold the film rotator , observe the rewinder knob moving , it means the film are engage will. then shoot for favorite angle.
Feb 18, 2008 | Pentax ME Super 35mm SLR Camera
Pentax ME
A simple fix might be to borrow a page from movie cameramen. Tape it shut with some black hockey tape. I was considering doing this eventhough my ME Super works fine. If you think that looks too getto, then it sounds like a service repair shop is the other answer.
May 02, 2007 | Pentax ME Super 35mm SLR Camera
Pentax ME Super 35mm SLR Camera Logo
201 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
