Question about Acer TravelMate 4150LCi Notebook
Vertical red line on notebook screen
I have a red line running vertical in near centre of my screen can it be that the VGA controller is starting bust or drivers is incorrect? Where do I find the drivers for this laptop since Acer don't have on their site?
  • 502 Answers
I'd advocate that the red line indicates that the screen needs to be replaced. As much as I would like to be able to tell you a quickfix that will solve the problem . The reason is that the flexcable that leads the signals into the actual LCD panel came loose, it is not an external connector issue, but rather related to how the internal signal flow of the LCD panel. It is not a solderable connection that on that can otherwise be repaired. I work for a Laptop Repair shop and if a solution popped up for removing this problem without having to replace the screen, we'd be very curious to find out about it.
Brian
Laptop Repair NYC.
Posted on Jan 04, 2009
  • 36 Answers
Unfortunately, a red line of pixels is usually caused by a short in the controller array of the LCD panel itself. Its also possible (but not likely) the cause can be due to a bad video cable or lose connection. It wouldn't hurt to try taking apart your laptop display and checking it out. Aside from that your only alt. is to replace the LCD panel. Sorry for the bad news, hopefully your still under warranty.
Jason @ jrdtech.net
Posted on May 19, 2008
    Champion:
  • 207 Answers
Send teh laptop for the repair most probalbly the port haas gone bad
Thin black vertical line near the centre of the screen what is the cause?
ok go to menue if still you have this problem your panel is not good
but if this problem disappera then this the problem of your T-CON BOARD for falt cables that attached to T-CON board
Oct 14, 2014 | Samsung PS50Q97HDX 50 in. Plasma TV
On the centre of the screen of my laptop there is a vertical line whch appeared yesterday. How can I remove it?
You cant! one circuit in the vertical lines has burned.
You need to replace the screen.
This is the solution. Please vote!!!
May 13, 2010 | IBM ThinkPad X31 2672 Notebook
Black blob on bottom rh of screen,vertical & horizontal lines
The blob is a phisically damaged part of the LCD screen. Unfixable, the screen must be replaced and it will be expensive.
May 04, 2010 | Lenovo 3000 N200 Intel Pentium Dual Core...
Vertical red line about 3mm wide near centre of screen of tevion 32'' lcd tv
Any fault of this description is normally a fault with the screen. The only way to remedy is to have the screen replaced.
Jun 28, 2009 | Televison & Video
Vertical red lines on screen
try a dif game and send me a msg at kickop1@ymail.com
Jun 27, 2009 | Microsoft Xbox 360 Console
Coloured vertical lines down lcd screen
To isolate the issue, i strongly recommend to connect the notebook to the external monitor by VGA port which had BLUE colored on the notebook. So that if it is normal then you need to confirm the issue is with the LCD display.
Apr 01, 2009 | Sony VAIO VGN-FS640W Notebook
Vertical lines in my laptop screen
Have you tried hooking it up to an external monitor?
This would ensure that it's the screen and not the video card..
If you do that and you receive a good picture then it could be something as simple as a loose video cable. Or it could also mean something like a bad video card or the expensive one, a bad screen.
Mar 08, 2009 | HP Pavilion dv8000t Notebook
Desktop computer monitor (flat screen) has a thin red vertical li
Detach the monitor from the cpu and turn it on. If the same vertical line appears then take it to the repair centre.
Dec 17, 2008 | IBM NetVista PC Desktop
I have a 1983 popeye arcade machine. the circut board that controls the vert hold for the monitor has 4 knobs for vert., sound, horiz., and bright. thevert. hold knob is busted off and the screen has...
VR353 is a 200k pot that feeds directly in to the vertical oscillation input of the chip on the main board at connection B1. If this pot is broken, you must replace the pot in order to get any vertical oscillation at all.
Sep 10, 2008 | X-Gaming X-Arcade PC Joystick (XGMPC)
Red line across top half of screen
Inverter board is bad or video cable loose either behind LCD panel or near video adapter.
Dec 02, 2007 | Gateway MX6438 Notebook
Acer TravelMate 4150LCi Notebook Logo
147 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
