Question about Kenmore 23812 Top Load Washer
Could the lidswitch be causing the problem as well
It will only drain and spin if you turn the selector knob and push in the lidswitch
    President:
  • 1,314 Answers
Yes could be the lid switch depending on the model they are held on by two screws ive seen one break and let the switch hang at an angle so that the lid strike cant fully depress it
Posted on May 19, 2008
Maruti/ertiga how to set clock.there is no any botton to set the clock
How to set Clock When the ignition switch is in the "ON" position, the display (D) shows the time. 2) To change the hour indication, turn the indicator selector knob (2) left or right repeatedly when the hour indication blinks. To change the hour indication quickly, turn and hold the indicator selector knob (2). To set the hour indi- cation, push the indicator selector knob (2) and the minute indication will blink. 3) To change the minute indication, turn the indicator selector knob (2) left or right repeatedly when the minute indication blinks. To change the minute indication quickly, turn and hold the indicator selector knob (2). To set the minute indication, push the indicator selector knob (2). To change the time indication: 1) Push the trip meter selector knob (1) and the indicator selector knob (2) together. w WARNING If you attempt to adjust the display while driving, you could lose control of the vehicle. Do not attempt to adjust the display while driving.
Hope this helps.
Bob
Feb 08, 2015 | Cars & Trucks
I have a Kenmore washer #11026002010. I am having problems with the water overfilling and not progressing to the next cycle. Would you have info on the fault codes and also the recalibration procedure
Does it sound like it wants to spin? If so more than likely the motor coupler broke causing your washer to not spin. It is one of the most common parts that fail.
Anyhow Sears is the best bet for your answers they even list all the steps needed to trouble shoot.
Model 11026002010 Kenmore Automatic washer Repair
This one is from the link above and credit to:
Natasha12,November 17, 2014
Thank you for choosing Searspartsdirect.com and being a valued member. I can certainly assist you in locating the diagnostics for your washer.
ACTIVATING THE SERVICE
DIAGNOSTIC TEST MODES
1. Be sure the washer is in standby mode
(plugged in with all indicators off).
2. Perform the following sequence of
movement using the cycle selector knob.
NOTE: AFTER RESET, sequence "a" through
"e" must be completed within 6 seconds.
RESET - Rotate cycle selector knob
counterclockwise one or more clicks
to clear sequence.
a. Rotate cycle selector knob clockwise
one click and wait ½ second.
b. Rotate cycle selector knob clockwise
c. Rotate cycle selector knob clockwise
d. Rotate cycle selector knob
counterclockwise one click and
wait ½ second.
e. Rotate cycle selector knob
clockwise one click.
?Successful activation of Diagnostic Test
Modes will be indicated by all status
LEDs (except for Lid Locked) flashing
ON and OFF in half-second intervals.
NOTE: LED names may vary between
makes and models.
FAULT CODE DISPLAY MODE (Pgs 6-7)
To access fault/error codes, perform steps 1
and 2 of Activating the Service Diagnostic Test
Modes. Turn the cycle selector knob until the
status LEDs or display correspond as follows:
?"Done" LED On, "01" Displayed on 7-segment
01
Sensing Soak Wash Rinse Spin Done
Press the START button to enter Fault Code
Display Mode. The status LEDs will flash
ON and OFF and "cl" is displayed on the
7-segment (if display exists).
1. To view last 4 fault codes:
? Turn cycle selector knob clockwise to view
fault codes in the order of most recent to
oldest. (Refer to Fault/Error Code charts
on pages 6 & 7.)
NOTE: A fault/error code will be removed
from memory if it does not reoccur after
10 consecutive wash cycles.
2. To clear fault codes:
? Turn cycle selector knob until the status
LEDs flash ON and OFF or "cl" is displayed
on 7-segment. (See figure 2, page 2).
?Press and hold START button for 3
seconds to clear all fault codes. Press
POWER to exit Service Diagnostic Mode.
You can also visit searpartsdirect.com for parts, diagrams, and repair information.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website: Sears Home Services .
Thank you for your question. Have a great day.
Jan 10, 2015 | Kenmore Washing Machines
Motor sounds like it is turning the drum but drum is not turning
Check your timer. Jiggle the selector knob,then move it to a position just prior to the spin cycle, see if this helps.
Oct 27, 2012 | Bosch Washing Machines
My machine doesn't turn to wash or spin to push out all the water. Can somebody help me.
if the machine fills up and washes but will not drain and spen and is a top loader its mostlikely a bad lid switch. its an easy fix. Just DO NOT bypass the lidswitch. its worth the 40 bucks for the correct part.
Feb 19, 2011 | Kenmore Washing Machines
After the washer machine fills with water it does not drain or spin, the clocking mechinism /switch does not match the cycle.
Look for signs of a broken lidswitch.
Flip up the controls unplug the lidswitch and check it for continuity or jump it out to see if the washer will start working. As far as the dial indicator being broken To replace that you yank out the retaining rod in the rear to release the knob then you can replace the skirt easily2cc26e6.jpg
Their are four videos and a tech service manual here: How it works Direct drive washer
Oct 19, 2010 | Kenmore Washing Machines
WHDSR209DWW on/off button will not engage to spin the cycle selector dial
The cycle selector is not engaged onto the timer shaft. Need to remove the on/off knob by removing the plastic "U" clip. Remove the cycle selctor knob and check that the steel spring clip on the selector is fully seated. Re-install the cycle selector onto the timer shaft aligning the selector key with the with tthe notch on the timer shaft. Re-install the on/off knob.
The cycle selector and on/off combination is a poor design. Users press the on/off knob in and turn clockwise to set the wash cycle. If you're not gentle this action wears the teeth on the timer shaft and the user has to press harder and harder to set the wash cycle. This pressing causes the cycle selector to be pushed off the timer shaft and you can no longer operate the machine.
VERY IMPORTANT:
Stop using the on/off knob to set the wash cycle. Press on the cycle selector to set the wash cycle. Use the on/off knob only for starting or stopping the machine. Don't press or pull too hard on the on/off knob or you will wind up pushing the cycle selector off the timer shaft.
Jan 12, 2010 | General Electric WHDSR209DWW Top Load...
Washer stopped spinning mid cycle does drain and fill whats the problem
Check to see if you advance the selector knob to the spin cycle. If it does spin at this time, then you have a problem with the selector knob. If it does not then you have a problem in the motor area.
Nov 28, 2009 | Whirlpool LXR5432KQ Top Load Washer
The cycle selector knob turns very fast and the wash goes from the fill mode to the drain mode and does not wash or spin.
the problem is with the selector.behind this,ther is a wheel with teeth.one of the teeth must be broken,causing the selector to turn too fast.
Nov 07, 2009 | Frigidaire ATF6000ES Front Load Washer
Ariston margherita wont drain and selector knob keeps turning
Plug off the wall first. The spin normally does not work when the outlet filter is clogged; be prepared for a flood of water. If the filter is clean you should then check your pipe coming out from under the tub. Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
You can also drain water from the tub thru the rear hose in the wall. Keep bucket handy. The outlet pipe into the wall stands at a particular height, refit exactly to this height, about 3 feet from ground. Do not push the pipe too much down the stand pipe.
Nov 29, 2007 | Ariston Technologies AWD120 13 lb. Washer...
Kenmore 23812 Top Load Washer Logo
65 people viewed this question
Sal De
fordexpert
Robert Rankin
