Question about Minolta DiALTA Di520 Laser Printer
Error C-133B I have an error multifunction on the display screen, can you help me clear it?
  • Minolta Master
  • 1,297 Answers
Please check cables for proper connection and if they OK change the Finisher CPU board.
Posted on Jul 31, 2009
I replace my machine for fuser flim unfortunately the screen shows 'E000000' How do I correct this error code?
  1. Try first to clear the error
    clearing the error may not fix the fault
    Press the *with a circle around it then press 2 and 8 at the same time then press *again /press copier touch button/function/clear/error/ok button then switch off m/c on hope it works
    also:
    Additional Functions: Click the Additional Functions button once. Do not hold down.
  2. Two and Eight Buttons: Click the 2 and 8 buttons at the same time once.
  3. Additional Functions Revisited: Click the Additional Functions button once again. Do not hold down.
  4. Copier Button: The System Management screen will open. Click the Copier button on the screen.
  5. Function Button: Click the Function button at the top of the screen.
  6. Clear Button: Click the Clear button on the screen.
  7. ERR Button: Click the ERR button to highlight it.
  8. OK Button: Click the OK button at the bottom of the screen.
  9. Power Off/Power On: Power the unit off and back on using the switch on the side of the unit. The error will be cleared.
  10. Restart eCopy:Once the unit is back up, restart the eCopy machine.
    https://www.question-defense.com/2008/11/10/canon-imagerunner-error-code-reset
Apr 14, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
Failing to receive a fax it says received in memory but not printing even when I want to print. Could you please help
Dear Barati
The printer may have some error. pl. check on the display of the printer. After clearing the error the received fax will printed.
Thanks.
Mar 16, 2015 | Samsung CLX-3305FW Color Laser...
How do i clear ERROR 355-0005
Dear
This error may be cleared with the company people.
Communicate with them.
Thanks.
Feb 02, 2015 | Canon imageRUNNER 1133 Laser Multifunction...
How do I fix error code E000001
sir
do the error clear in service mode.
COPIER-FUNCTION-CLEAR-ERR.
Thanks
Dec 21, 2014 | Canon imageRUNNER 2520 Laser Multifunction...
Canon mp600 pixma; it just started doing this when I tried to print; now I can't seem to be able to do anything with it. I assumed it was due to one of the ink cartridges being out and so I replaced...
"Issue: ERROR LCD: Error Code 5010
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the button again.
3. Wait until the device has completed its cycling process before submitting another job request."
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 20, 2011 | Canon PIXMA MP600 all-In-One InkJet...
SC 571 error
Hello sir; The error code you have display, its means the fuser oil waste bottle full, check it out and dump it out, otherwise that's senser problem.
Feb 02, 2010 | Lanier Office Equipment & Supplies
Xerox Workcentre C226 - Error H5-01
This might help, but I don't know how to put it in tech mode.
"The fuser error reset code will reset the machine so it will run after the problem is fixed.First remove any jam in the fuser then enter tech mode;
press program, * ,clear, * enter 1 4 press start then turn machine off and then back on."
Jul 29, 2009 | Office Equipment & Supplies
Canon mp830 error code 5010
Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
Nov 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Cant get rid of blinking error message, nothing works
H4-00 is a fuser related service code. you need to get into the simulation programs and run sim 14 to reset the code. Make sure there is no paper jammed in the fuser. (The hot part on the right side inside the door)
Dec 02, 2007 | Sharp AL-1655CS Copier
196 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
