Question about Pinnacle Dazzle DVD Recorder
Help my install cd is scratched how do i set up with no cd
  • bubbalici995 Dec 03, 2008
    I lost my installation cd and i have the serial number how can i get it on my lap top
I believe it is impossible to get it installed without the disc.
Posted on Sep 11, 2008
Tip
HOW to Recover Data from Scratched CD's
HOW to Recover Data from Scratched CDs
All CD or DVD are always get some scratches when you use or even if your carefully using it,there's time that accidentally make some scratch in it.this tip is a painless techniques on how to create a full working CD from the scratched one. I have personally tested this and had fixed a CD that would not read data at all. This tip works best with small unreadable scratches, as some hard scratches are too deep and loose the data permanently.
Requirements:
1:Alcohol 120% software [or similar]
2:Cooking oil
3:Small piece of cotton
4:Dry cleaner paper
Follow this simple steps to fix a scratched CD for repair purposes:
In step one you must do some preparation work on the CD. Begin by wetting the cotton with water. Begin to clean the CD in a vertical motion; three firm wipes shall be sufficient. Dry the CD with the dry cleaner paper.
Using another piece of cotton, apply oil to the CD surface. Be sure to do this with caution and not overuse oil. After a through cleaning, dry carefully. Particles from the oil will stay on the micro surface of the scratch. It appears that the oil helps the laser of the CD/DVD driver
to read the surface again.
After downloading and installing Alcohol 120% software, run the program and select to create an ISO - image making wizard. Attempt to read the CD drive and test if the program can read the Alcohol 120% software is recommended for this, as it is known to recover data more efficiently than other ISO software.
If a successful read is obtained, I recommended creating a new CD immediately. Copy all the data from the CD to the hard drive or create an ISO of the CD for immediate use. With a favorite burning utility, burn the ISO or data onto a new CD.
on Sep 09, 2011 | Audio Players & Recorders
My office 2007 soft ware was damaged, iam unable to run this on computer due to scraches on cdrom. kindly give me ms office 2007 version.
If the scratches are light then you can purchase a CD scratch removal kit to polish the scratches off the CD.
You may be able to download MS Office 2007 from the Microsoft WEB site. You will need the product installation code that came with your Windows installation CD.
Aug 21, 2011 | Computers & Internet
It will not start up, and I cannot restore to factory settings. Tell me the way to restore it to factory settings please.
Hope youve got your windows CD or can borrow one you need to boot from CD or DVD then format it and reinstall from scratch. Your windows product ID should be on a sticker under the laptop. Another thing once you reinstall is drivers because most times windows doesnt install all of them. If windows installs your internet connection you can get drivers from windows update otherwise use another PC copy the drivers to CD or flash drive and install them that. Feel free to message if you need more help cheers from Scott and plz vote
Jan 23, 2011 | EliteGroup 536 Notebook
My resource cd is scratched how can i install my wireless-n 300 usb adapter wna3100
could spread some toothpaste on the cd, wipe it off then try the install again. used to work for me when i had scratched cd's
Dec 28, 2010 | NetGear WirelessN 300 USB Adapter WNA3100
I think my cd for my sims deluxe edition is too scratch but i dont want to buy a new game plus it would be hard if not impossible to get this game again so i want to manually install it on my computer i...
if it is installed you just go to www.megagames.com, pc fixes on the sidebar and choose your game and download ano-cd crack =)
if you need to install it try find a torrent to download at www.thrpiratebay.org or www.mininova.org and since you have the key it wont be a problem installing it.
you can also try to set down your reading speed in the dvd-rw/rom so it dont "notice" the scratches =)
Jan 05, 2009 | EA - Electronic Arts The Sims Deluxe...
Keeps freezing during installation of xp
Ok, lets start from scratch.
If you can, connect a different CD/DVD drive and change your Boot Priority to boot from here first.
Insert your XP disc, and using the CD's settings, delete all partitions and reformat the drive (NTFS). Start the installation and see what happens.
If you have already done this, or it doesn't work. Check how scratched the CD is. As long as it's not a manufacturer's revovery disc, you could ask someone if you could borrow their XP installation disc.
A good way to get rid of minor scratches on your CD's, is to spray them lightly with furniture polish (with beeswax). Leave for a minute, then using a very clean dust cloth, gently clean the cd from the middle to the outside. N.B. never clean the cd in a circle motion, i.e rubbing.
Hope this works for you.
Tim
Dec 08, 2008 | Fujitsu Siemens LifeBook S7010 Notebook
UPDATION OF MSI ENGINE
Sounds like the installation file is corrupted on the CD. You could contact Nero and see if they can send you a new CD. If there are visible scratches on the CD, you could use a resurfacing machine to see if the scratches will go away. If this is being installed on a Vista Computer, it might not be compatible or it needs an update.
Aug 06, 2008 | Intel Motherboard
Need Help with Restore CD's
I suggest that you replace that optical drive and down load the restore disk from the manufacturers' website.
May 21, 2007 | E-Machines W4682 PC Desktop
Pinnacle Dazzle DVD Recorder Logo
78 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
