Question about Panasonic Lumix DMC-TZ1 Digital Camera
Will not zoom
Camera will not zoom, I get a message of (Remove the lens cap and trun the camera on again) everytime I attempt to zoom in.
  • rcalampe Dec 08, 2008
    DMC-TZ1 WILL NOT ALLOW ZOOM MESSAGE STATES REMOVE CAP
  • mbradsh3 Dec 28, 2008
    mine does the same...I have been trying to remove the front cover to take a look but it will not loosen up near the lens.
Its broken mine dose the same
Posted on Jun 13, 2008
My Coolpix L320 was working fine, then all of a sudden got stuck with the lens zoomed all the way out and a message on the screen that says, "Turn the camera off, remove the lens cap, and turn the cam
after changing the battery and gently push back on the lens it should automatically close if not then check around it it must be something stuck in between it
Jan 18, 2015 | Nikon Coolpix L320 Black Digital Camera...
My camera keeps showing the message System Error (Zoom)
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Jul 14, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
Zoom in/out power off message
While zooming in-out camera gives error message means lens mechanism is either defective or lens drive motor is bad. In both cases, lens assembly will be replaced.
Contact nearest camera repair shop for fix.
Thanks.
Sep 04, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Lens keeps getting stuck/needs a good tug to zoom past 25 HELP!
Hi Rachael_amor, If the lens will not zoom on the camera will it off the camera? If not then it has some grit, dirt, and the like in the lens. You could attempt to vacuum around the zoom however, I suspect it will need to go in to Nikon. That lens is not well weather sealed, it is a inexpensive consumer lens.
Jun 02, 2009 | Nikon D80 Digital Camera with 18-55mm Lens
PANASONIC dmcfz8
try to help the lens go out by pulling it very very lightly...
Jun 30, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Panasonic DMC-TZ1
I just had this problem, too. I basically disassembled the camera by removing the back cover, front cover, and top assembly. The top assembly includes a plastic part between a circuit board and the top external metal piece that houses the button on the top of the camera. On the circuit board there is a switch for the zoom that looks like a pinball flipper. You have to make sure that it's working properly and you may have to remove the metal dust cap and remove any sand if it's lodged in the mechanism. It's pretty tough if you're not good with your hands because it's extremely small. I did this and the zoom began working like normal again, but then I got the message that the camera needs to be turned on and off every time I turn on the camera...
Sep 26, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Zoom lens jammed
this is a protection mechanism against further damage when the zoom/lens mechanism is obstructed. It's a very delicate mechanism, and it's not easy or cheap to fix. The gears probably got misaligned or broken when you dropped the camera. You should get a repair estimate, and only if you decide you'd rather trash it try opening it up again. Good luck
Jun 22, 2006 | Samsung Digimax 420 Digital Camera
Panasonic Lumix DMC-TZ1 Digital Camera Logo
154 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
